RidgeRunner 2,232 #1 Posted March 20, 2017 Hi all, Seeking a view. Given that the Hasegawa kit is expensive and rare, how is the Heller? I know it has raised lines of dubious placement but does it build to a reasonable model with a bit of care? I really need a TF and this is the only way I can see oher than shelling out for a pricing Hasegawa plus shipping and customers charges! As always, I'd appreciate your views. Thanks. Martin Go to top Share this post Link to post Share on other sites
Des 194 #2 Posted March 20, 2017 (edited) I brought one down from the attic stash recently with a view to building it , raised panels and detail quality patchy and not as good as the Hasegawa kit. Detail in the main undercarriage bay but not the doors whereas the nose undercarriage bay has no detail but the doors do , also the forward edge of the air-brake doors look a little out. Raised console and panel detail in the cockpits and the seats are vaguely similar to the C2 , canopies are single piece. Tanks provided for the wingtips and underwing positions but they are rather thin looking , detail on the inside face of the afterburner and rear engine face but not on the jet pipe. Undercarriage detail reasonable with the main gear and wheels being perhaps better detailed than the nose gear. In general it seems a fair enough kit and is sharply moulded although I have not removed any of the parts to check the nose/fuselage/wing joint yet but no doubt if it is awful someone will be along soon with dire warnings. Edited March 20, 2017 by Des Problems with URL Go to top Share this post Link to post Share on other sites
junglierating 461 #3 Posted March 20, 2017 Funnily enough I also have this in the stash...bought from the online gambling shop😉 I thought that it looked like a two seater....not that i can recall seeing one...not recently anyhoo. Have aspirations of a Danish one. Be good to see how it turns out. Ps did Frog do one? Go to top Share this post Link to post Share on other sites
Scott Hemsley 67 #4 Posted March 20, 2017 It's a nice kit and when it first came out, it was my go-to '104, until I tried to put it next to a Matchbox F-101B ... it was as large or larger than the Voodoo! It was then I found out that as good as the kit was, it's not 1/72. Just thought someone should point that out. I think way back soon after it was first issued, I read someplace that stated it was actually more like 1/67(?). In any case ... if you plan on using AM 72nd decals for the '104, they won't fit the Heller kit properly. They'll be much too small. On the other hand, if you choose to build it OOTB and display it on it's own (where size comparisons aren't easily done), it's a great little kit. junglierating: Frog only released the single-seater (F-104G) and it was the same plastic as the original Hasegawa tooling - not the best rendition of the a/c by any means - as the two companies frequently swapped moulds during the late 60's and 70's. I'm only aware of two companies that offered the dual version ... Heller and the 'new tool' Hasegawa (1990). However, where Heller managed to offer both the single and the dual versions in the same boxing, Hasegawa later did it In two (but they are 1/72). I'm working on both Hase. kits, right now,. FWIW: If you're looking for a good 'inexpensive' F-104G (single-seater), it may take some looking in the secondary market, but ESCI did a nice 72nd kit for it's time. IMO, it was only surpassed when the 1990 tooling of the Hase. F-104's appeared on the scene. Scott Go to top Share this post Link to post Share on other sites
Don McIntyre 340 #5 Posted March 20, 2017 I can't comment on accuracy, or details beyond those items Des has mentioned above. When I built mine a couple of decades ago, I don't recall any major construction issues. Decals may need replacing, unless you get a newer release than the one I had (looks like Des' photos above). Go to top Share this post Link to post Share on other sites
Jure Miljevic 350 #6 Posted March 20, 2017 Hello, Scott I thought Revell did TF-104 G a decade or so ago. I have one and I doubt it is re-packed Hasegawa. Cheers Jure Go to top Share this post Link to post Share on other sites
Scott Hemsley 67 #7 Posted March 20, 2017 You're correct, Jure. The key phrase to my post was "that I'm aware of" and having never seen the Revell offerings, that still applies. But having said that, one of the modellers I email fairly regularly mentioned his Revell kits, so I stand corrected for the over-sight. Thanks for pointing that out. Scott Go to top Share this post Link to post Share on other sites
junglierating 461 #8 Posted March 20, 2017 Who'd have thought this thread would balloon like this.Just like sorting out the hassles of real aircraft. What we need now is a kit comparision anybody? ☺ Go to top Share this post Link to post Share on other sites
Seahawk 1,442 #9 Posted March 20, 2017 39 minutes ago, Scott Hemsley said: FWIW: If you're looking for a good 'inexpensive' F-104G (single-seater), it may take some looking in the secondary market, but ESCI did a nice 72nd kit for it's time. IMO, it was only surpassed when the 1990 tooling of the Hase. F-104's appeared on the scene. Are you saying you prefer the ESCI/Italeri kit over the Revell one from the 1990s? Would be interested to know why: I have both but Starfighters are Not My Subject. Go to top Share this post Link to post Share on other sites
Hamster Volant 20 #10 Posted March 20, 2017 Effectively the Heller kit fuselage is a bit overscale, quite obvious when putting it close to other Starfighter kits. Nevertheless it looks the part if you're not going to line it up with other F-104... I built it about 35 years ago and used Microscale sheet 72-180 decals for the bicentennial TF-104G in Luke AFB - I believe they were designed for the kit as they fit quite well. I wonder if Matchbox did not issue a two seater too? Their single seater was a good base (even with the trench-like panel lines) for detailing in the hands of a good modeller - may be the Revell was a re-pop of the Matchbox? Go to top Share this post Link to post Share on other sites
Des 194 #11 Posted March 20, 2017 (edited) I was not aware of the scale discrepancy that Scott mentioned but a few minutes with a craft knife to release the parts from their sprues and some scrap masking tape enabled the following comparison of the single-seat parts as I do not have another twin-seater. I am presently working on a Hasegawa F-104G kit and assuming that this is more accurate taped some parts of this (in light grey) against the Heller parts (in tan) and discovered that the problems are not quite as simple as being merely different scales. Both kits share a fairly similar radome shape but then it goes all wrong with the Heller forward fuselage being much deeper and much longer. However using the quite similar fin leading edge and height for comparison albeit with no rudder on the Hasegawa part the rear fuselage lengths are almost exactly the same but again the Heller is much deeper. Comparing the wings both kits seem to share the same span but the chord on the Hasegawa kit is deeper. Sadly the major sub-assemblies for the twin-seater version of the Heller kit come together well as when roughly taped as shown below and obviously with more attention it could result in a good looking but maybe slightly distorted model. If accuracy is essential then maybe the old Matchbox twin-seater or its Revell rebox as mentioned along with the Heller kit for some of the detail parts such as the cockpits could be an alternative. Edited March 20, 2017 by Des Remove repeated word Go to top Share this post Link to post Share on other sites
RidgeRunner 2,232 #12 Posted March 20, 2017 Thanks chaps. Having considered the cost of purchasing the Heller and an Esci (for conversion, which I now know wouldn't work) I have gone for a Hasegawa TF ;). Expensive but no more than the other options. Even the Revell is expensive and that has accuracy issues too! Martin Go to top Share this post Link to post Share on other sites
Scott Hemsley 67 #13 Posted March 21, 2017 Seahawk asks "Are you saying you prefer the ESCI/Italeri kit over the Revell one from the 1990s? Would be interested to know why: I have both but Starfighters are Not My Subject.' As I stated above. I've not touched the Revell kit. However, the chap who recently mentioned his Revell kit in an email, also sent along a couple of sprue shots for me to look at. Quite frankly, I was not impressed by some of the parts break-down and as a result, I'm even more satisfied with how my two Hase. 104's are turning out. One of the main areas I found rather unnecessary concerned the fin. I realise that to accommodate the shorter fin of the F-104C, they had to break-up the fint to provide the option for the shorter "C" fin vs the longer "G' fin. It's where they chose to make the join. I guess a convenient panel line was just to obvious and they ended up vertically splitting the fin fwd of the rudder hinge-line, in a most awkward place for sanding. It might have been better to split the fuselage vertically cut the fuselage at the fwd tip of the fin and offered a complete fin/engine for either the (shorter) F-104A/C or the later F-104G, etc.. A lot of flak has been made of the Hase. kit and the tooling that vertically cut the fuselage just behind the intakes. This allowed common tooling with a complete front of the fuselage for either a single-seat or a dual, depending on the boxing. In my experience, this join can mate perfectly ... it all depends on how you assemble the previous step which include the MLG bay. It's that single assembly that determines the fit of the vertical join as it plays a major role in lining up both fuselage halves. But getting back to your question, the ESCI single-seater became my go-to kit until I managed to score my Hase. kits in a blow-out sale at my LHS. Unfortunately, I was denied a dual-seat Starfighter, until the Hase. came along. I got both of my Hase. kits in a blow-out sale my LHS had back when the kits were released. Seems people preferred to pick up the other F-104G boxings with either the Canadian or German boxart rather than the Japanese boxart, despite all the "G" kits having identical plastic, only differing in the parts marked 'do not use' on the part schematic. Returning to the Revell kit - I've never seen one in a LHS around me, either back in the 90's or now ... so it was never on my radar. Having said that, from the sprue shots I've recently seen, I'd say it comes a close 2nd to the Hase. kit, if only for some questionable part break-down. I can't comment on how it goes together or the resulting build. As I recall, I found the ESCI kit to be simple by comparison to the Hasegawa kit (surprise!), but it built up into a nice kit. Scott Go to top Share this post Link to post Share on other sites
Seahawk 1,442 #14 Posted March 21, 2017 Many thanks for your thorough answer. Won't bin the ESCI kits yet, then! Go to top Share this post Link to post Share on other sites
Giorgio N 4,875 #15 Posted March 21, 2017 5 hours ago, Scott Hemsley said: Seahawk asks "Are you saying you prefer the ESCI/Italeri kit over the Revell one from the 1990s? Would be interested to know why: I have both but Starfighters are Not My Subject.' As I stated above. I've not touched the Revell kit. However, the chap who recently mentioned his Revell kit in an email, also sent along a couple of sprue shots for me to look at. Quite frankly, I was not impressed by some of the parts break-down and as a result, I'm even more satisfied with how my two Hase. 104's are turning out. One of the main areas I found rather unnecessary concerned the fin. I realise that to accommodate the shorter fin of the F-104C, they had to break-up the fint to provide the option for the shorter "C" fin vs the longer "G' fin. It's where they chose to make the join. I guess a convenient panel line was just to obvious and they ended up vertically splitting the fin fwd of the rudder hinge-line, in a most awkward place for sanding. It might have been better to split the fuselage vertically cut the fuselage at the fwd tip of the fin and offered a complete fin/engine for either the (shorter) F-104A/C or the later F-104G, etc.. A lot of flak has been made of the Hase. kit and the tooling that vertically cut the fuselage just behind the intakes. This allowed common tooling with a complete front of the fuselage for either a single-seat or a dual, depending on the boxing. In my experience, this join can mate perfectly ... it all depends on how you assemble the previous step which include the MLG bay. It's that single assembly that determines the fit of the vertical join as it plays a major role in lining up both fuselage halves. Agree on the Hasegawa kit, that joint can be made good with only a bit of care. The Esci kit itself has a potentially awkward joint where the designer decided to cut the fuselage to allow both C and G to be made. In the several Esci kit I've built, this joint often tends to result in a step where the fuselage sections meet, particularly if followinf the instructions. My solution is to eliminate the flange on the rear part of the front fuselage section and glue front and rear separately on each fuselage half, keeping the outer surfaces properly aligned. But getting back to your question, the ESCI single-seater became my go-to kit until I managed to score my Hase. kits in a blow-out sale at my LHS. Unfortunately, I was denied a dual-seat Starfighter, until the Hase. came along. I got both of my Hase. kits in a blow-out sale my LHS had back when the kits were released. Seems people preferred to pick up the other F-104G boxings with either the Canadian or German boxart rather than the Japanese boxart, despite all the "G" kits having identical plastic, only differing in the parts marked 'do not use' on the part schematic. Not all Hasegawa kits contain the same parts. All the boxes I've seen of the Japanese variant don't include the thicker wheels and the bulged wheel well doors of the G. At the same time not all the G boxes include the parts for the S and none of the G/S boxes include parts for the CF RWR system. Personally I'd always buy the G/S box (the one with the Italian aircraft on the cover) for any G or S, but also works for a J or an early CF while the box for the Japanese/Canadian variant is the one to buy for a later Canadian aircraft. These two boxes are today the easiest to find 1 Go to top Share this post Link to post Share on other sites
Hook 425 #16 Posted March 21, 2017 21 hours ago, Des said: If accuracy is essential then maybe the old Matchbox twin-seater Considering that the Matchbox TF-104G had a Vulcan gun port, I would hardly call it accurate... Also,it featured a nosewheel that was on the rear of its bay, as on the singleseaters. Cheers, Andre Go to top Share this post Link to post Share on other sites
Des 194 #17 Posted March 21, 2017 7 minutes ago, Hook said: Considering that the Matchbox TF-104G had a Vulcan gun port, I would hardly call it accurate... Also,it featured a nosewheel that was on the rear of its bay, as on the singleseaters. Cheers, Andre I would have thought 'accuracy' was obviously being used in a relative rather than a literal sense to provide something a bit closer in proportions to the TF-104 with the removal of the gun port and reversing of the nosewheel arrangement being fairly obvious to anyone attempting such a project. Go to top Share this post Link to post Share on other sites
Scott Hemsley 67 #18 Posted March 21, 2017 Thanks for the clarification on the contents of each of the boxings. Giorgio.. My comment in that regard, stemmed from my understanding of comments from other club members during a club build, back in the day. The two I currently have on the work table are the CF-104G boxing (#1005) and the TF-104G/F-104DJ boxing (#1004). Scott Go to top Share this post Link to post Share on other sites
tempestfan 406 #19 Posted March 21, 2017 I am not aware of a Revell rebox of the Matchbox TF, apart from possibly in a Matchbox "black box ". Revell' is their own mould based on the early /mid 90s mould. I had a feeling AMT may have done a twin in similar fashion to their F-100F, but a quick Google yielded only a boxing with an orange bird, probably the one I was thinking about. There aren't many possible newer boxings of the Heller kit, as the mould was sold to Argentina ca. 30 years ago. For a time, the Heller kits used to be quite expensive on ebay, at least here in this country where we don't speak English 😆 (sorry, couldn't resist ). Unless found cheap, I'd definitely prefer Hase or Revell. 1 Go to top Share this post Link to post Share on other sites
Hook 425 #20 Posted March 22, 2017 13 hours ago, Des said: I would have thought 'accuracy' was obviously being used in a relative rather than a literal sense to provide something a bit closer in proportions to the TF-104 with the removal of the gun port and reversing of the nosewheel arrangement being fairly obvious to anyone attempting such a project. Still - with the Hasegawa and RoG kits, why seek out the old Matchbox which hasn't ben in production for ages..? The fuselage of both single- and twoseaters have always struck me as being too narrow. Cheers, Andre Go to top Share this post Link to post Share on other sites
RidgeRunner 2,232 #21 Posted March 22, 2017 (edited) Hi all, On the well known auction site the Revell is the same or more expensive than the Hasegawa. I'd therefore go Hasegawa every time. I still believe that the Revell is to drawn out at the front end of the canopy - but that may be my eyes! . The Hasegawa, on the other hand, is good all round. This is what I mean: Revell - it even looks a little oversized to me. Hasegawa Martin Edited March 22, 2017 by RidgeRunner added images 1 Go to top Share this post Link to post Share on other sites
Rob de Bie 68 #22 Posted March 22, 2017 1 hour ago, RidgeRunner said: On the well known auction site the Revell is the same or more expensive than the Hasegawa. I'd therefore go Hasegawa every time. I still believe that the Revell is to drawn out at the front end of the canopy - but that may be my eyes! . The Hasegawa, on the other hand, is good all round. This is what I mean: Revell made the same error on the single-seater canopy: the division line between the windshield and the canopy is 1 mm too far forward. That makes the windshield too small, and the canopy too big. Once you know it, you keep seeing it.. Rob Go to top Share this post Link to post Share on other sites
Giorgio N 4,875 #23 Posted March 22, 2017 The difference is clear in those pictures. I'd say that if the two are at the same price, then it's a no brainer, hasegawa all the way ! I never realised how hard to find the hase 1/72 TF was, I checked that well known auction sites a couple days ago and found that there were more 1/48 ones for sale Go to top Share this post Link to post Share on other sites
RidgeRunner 2,232 #24 Posted March 22, 2017 10 minutes ago, Rob de Bie said: 1 mm too far forward too far back, I reckon Absolutely, Giorgio..... I've gone Hasegawa!!! I'm broke but its fun, eh? Martin Go to top Share this post Link to post Share on other sites
RidgeRunner 2,232 #25 Posted March 22, 2017 So now I'm set up for a G (Hasegawa), an A (Revell) and a TF (Hasegawa). I just need the time now!!!! M Go to top Share this post Link to post Share on other sites
