Nachtwulf Posted March 9, 2017 Share Posted March 9, 2017 Were all the P-40B iron gun sights offset to starboard? I am working on the 1/48 Airfix kit and I have chosen to use the markings for R.T. Smith's #47. Now Airfix has you use the windscreen with the review mirror and no reflective gun sight panel . Does this mean that this particular plane had only the iron sights? I don't know, but if it did only have the iron sights would it still be offset? Or would it be centered? I have exhausted my resources. Link to comment Share on other sites More sharing options...
72modeler Posted March 9, 2017 Share Posted March 9, 2017 Funny you should ask.... Mike http://www.britmodeller.com/forums/index.php?/topic/235014194-h-81a-avg-windscreen-gunsight-photo/#comment-2584437 RT's airplane is my very favorite AVG mount- happy modeling! 1 Link to comment Share on other sites More sharing options...
Nachtwulf Posted March 9, 2017 Author Share Posted March 9, 2017 Thank you. I have seen that picture as well. However I am still in the same spot regarding R.T. Smiths #47 Link to comment Share on other sites More sharing options...
72modeler Posted March 9, 2017 Share Posted March 9, 2017 Nachtwulf, I found another link that shows numerous photos of AVG Tomahawks; if you examine the ones that show the external ring and bead sights, including RT Smith's fighter, you will find that they all show the ring and bead sight offset to the right of the centerline, including the photos that show the same sights on P-40E's. To the best of my knowledge, the external sights were mounted on the RH side for both variants. Mike https://hiveminer.com/flickr_hvmnd.cgi?method=GET&search_type=Tags&page=1&sort=Interestingness&textinput=avg,p40&noform=t&search_domain=Tags&tag_mode=all&photo_type=250&photo_number=50&sorting=Interestingness&originput=avg,p40 1 Link to comment Share on other sites More sharing options...
BS_w Posted March 9, 2017 Share Posted March 9, 2017 On P-40 BC/H81, the bead and ring had 3"25/32 right offset. (3"5/8 on P40D & up/H87) On the H75/P36 the offset was 3"25/32 also, except when there wasn't optical gunsight. In this case bead and ring were lined up with airplane centerline 1 Link to comment Share on other sites More sharing options...
Nachtwulf Posted March 10, 2017 Author Share Posted March 10, 2017 Thank you for the response that is good info! so... Were there any P-40B's that did not have the reflector gun sight and where would the ring and bead be located if it did not? Link to comment Share on other sites More sharing options...
