Welcome to Britmodeller.com
Register now to gain access to all of our features. Once registered and logged in, you will be able to contribute to this site by submitting your own content or replying to existing content. You'll be able to customize your profile, receive reputation points as a reward for submitting content, while also communicating with other members via your own private inbox, plus much more! This message will be removed once you have signed in.
  • Announcements
    • Mike
      Switched Identities   18/06/17
      If you are still having problems logging in and remaining under your own username following the DDoS attack last week, you need to log off, clear your browser's cache, and restart your browser to ensure you clear all the old files from your temporary area.  Then you should be sorted.
giemme
The Macchi's! "Folgore" and "Veltro" in 1/48, Hasegawa plastic
445 posts in this topic
Hi everybody;
inspired by some very interesting multiple builds I recently saw here on BM (see for instance by @Cookenbacher, @Procopius and @rob85, to name a few), I decided to start my own.
I'm going to build Macchi's C202 FOLGORE and C205 VELTRO (I don't think they need any introduction, but I'll probbaly mention something along the build)
I acquired the two kits I'm going to use off BM, second hand; they were pristine, though, with only the C202 having the main parts (fuselage and wings) removed from the sprue.
Here are the boxes:
MC202_BOXART
MC205_BOXART
and the schemes I'm going for:
MC202_SCHEMA
MC205_SCHEMA1
Aftermarkets: SBS resin cockpit set and Eduard Brassin exhaust stacks for the C202
AM1
and again SBS resin cockpit and Quickboost exhausts for the C205
AM2
Here are some details of the cockpit sets:
AM3
AM4
AM5
Not bad, uh? :)
Instruction sheet:
AM6
AM7
Same for the C205
AM8
AM9
and the paint set I'll be using:
paints1
paints2
Last night I washed both kits and the resin parts in warm soapy water and let them dry overnight.
More progress during the WE, I think.
Ciao
16 people like this
Great subjects. These two are such sleekly styled machines, they  suggest the designers would have rather been continuing on their line of speed record breaking Schneider Trophy racers!
Clever designs too: I seem to recall one at least has slightly longer wing on one side to provide a little extra lift to offset the effects of torque from the propellor.
Good luck with the build!
1 person likes this
They're both like that. In fact, if you follow my build you will see that Hasegawa basically used the same mould for the two models, with just a few different bits for the specific version; this will lead to filling panel lines and removing various bumps from the C202 fuselage and wings ... :frantic:
Thank you for your comment, greggles! :thumbsup:
Ciao
1 person likes this
Really looking forward to this, the Italians know how to make good looking aircraft!
Rob
2 people like this
Looking forward to these !
There's a very thorough explanation of the modifications needed for the 205 on the Aviolibri book on the type, let me know if this can be of use to you
1 person likes this
I'll watch this with interest. The C.202 is one of my favourite aircraft and I built a couple of the Hasegawa kits in both 1/72nd and 1/48th  a while back, I still have a 1/48th one in the stash but it will never get built:idea:
1 person likes this
Looking forward to seeing what you do with these two! :popcorn:
Kind regards,
Stix
1 person likes this
Rob
Somehow I knew I'd have had your attention on this project ... :hmmm:  :D  :D  Glad to have you on board, Rob :thumbsup:
Cheers Giorgio, thanks for joining! :thumbsup: The book you mention would definitely be of use, also because then C205 I'm modelling is part of the first series, without wing cannons, and I seem to recall I read somewhere that the access panels for the wing machine guns are different from the ones moulded by Hasegawa.
Thank you for joining Silver Fox :thumbsup: I must warn you, I'm not the fastest builder ever ( :chair: quite the opposite, in fact) so, don't expect a quick build :shrug:  :)
Kind regards,
Stix
Hey Stix, welcome on board, great to have you here!  :thumbsup:
Ciao
Edited by giemme
2 people like this
Looking forward to this also :)
1 person likes this
Wow, a double build Giemme, and since you put about 17 times more detail than I do, that's like 34 simultaneous builds.
1 person likes this
Armchair : check !
Whisky : check !
Ready for these 2 beauties !
BTW 1/48 is not your favorite scale....is there a reason for this change ?
3 people like this
Cheers Clive, thanks for joining :thumbsup:
:D :D:D Cheers Cookie, that made me laugh a lot, thank you! :thumbsup: But it's a lot easier to put details into a 1/48 model ... I think :confused:  :D Welcome on board!
2 minutes ago, basket said:
Armchair : check !
Whisky : check !
Chocks off then, basket :D Welcome on board to you too :thumbsup:
As for the scale, it is actually the opposite: I'm mainly a 1/48 guy, but since I did my F-4J in 1/72 a couple of years ago, I found it good fun .... and space saving, so the idea is to do jets in 1/72 and propellers in 1/48 (with exceptions, of course :winkgrin: )
Plus, a 1/72 propeller fighter is normally very tiny :frantic:  (apart from some US WWII fighters, which look like they've been under steroids ... )
Ciao
2 people like this
Hello Giorgio :).
I am normally a 1/72 builder because I have very little space, but I always have wanted to build in some larger scales.
I'm looking forward to this build, I am sure that I will learn things that can be used to enhance 1/72 models. I had thought of buying the Italeri ones.
Really stylish aircraft, plus I'm looking forward to seeing you do the colour schemes with the Lifecolor set (I like Lifecolor paints) :thumbsup2:
Good luck for enjoyable builds,
Best regards
TonyT
1 person likes this
Thanks Tony, and welcome on board! :thumbsup:
The color schemes are quite tricky, especially the smoke rings one; I'll very likely have to resort to Tamiya paint for them, but I'll first give it a try with the appropriate Lifecolor green.
I love Lifecolor, especially for brush painting, but they give a very smooth finish also when airbrushed :thumbsup:
Ciao
3 people like this
I too love the sleek lines of the Italian fighters such as the Folgore, but by contrast the bombers are some strange, ugly beasts... still very interesting subjects though!
2 people like this
Wow Giorgio, what a wonderful wip, two beautiful propellers in the same page! :clap2:
I love these Macchi fighters... and Lifecolor too. :yes:
Ciao.
Davide
1 person likes this
Lovely choice, I'll take a seat at the back if you don't mind!
Ian
1 person likes this
This looks good, I'm definitely up for this one! :popcorn:
Martian
1 person likes this
This will be cool to watch. One of the most beautiful planes built IMO. I have two or three on the TD Shelf!
1 person likes this
Love the look of these aircraft! Mind if I tag along?
1 person likes this
Like the SM79, right? :D That was my very first model, built when I was just a kid. I'll have to build another one, sooner or later  .... :coolio:
Ciao.
Davide
GRazie Davide, benvenuto a bordo! :thumbsup:
Ian
I certainly don't mind, Ian! Welcome on board :thumbsup:
Martian
Welcome to you too, Martian! :thumbsup:
The C202/205 are indeed eye-catching. Thanks for joining! :thumbsup:
I don't mind at al, the more the merrier :D:thumbsup:
I should have some update to post on Monday, meanwhile happy WE everybody
Ciao
Edited by giemme
1 person likes this
That was the very beast I was thinking of... Looks that only a mother could love! Although I am fortunate enough to have one in my stash, obtained from eBay a few months back. I want to get a BR20 also, but to finish it in Japanese markings. I was convinced I had a Folgore also, but I was wrong; it turns out that I have a Reggiane 2005 kit - a very similar outline though!
1 person likes this
I'm not sure how easy it will be to use the lifecolor paints for the smoke rings.. they are not the finest and when thinned beyond a certain limit they just separate in droplets. I'll watch your experiments with interest !
One possible solution is to add Vallejo's glaze medium, that makes the paint more transparent while retaining the standard thinning ratios. I've used this to make my own washes using Llifecolors and seems to be working, may be worth trying
1 person likes this
Re2005 is very similar indeed, with some notable differences in the rudder, elevators and wings shape; great looking airframe too, I'd love to have a decent 1/48 kit of it.
Thanks G.  Hard to spray fine lines with Lifecolor, I know, but I'm going to experiment a few different thinners, like a mix of Future and Windex (veramente userò Vetril e la Emulsio 6 mesi) and see what I get. I'm also prepared to brush paint the smoke rings :frantic:
Can you please expand on the Valleyo glaze medium? What is it exactly?
Ciao
Oh damn, looks like I am sitting at the back again.
Ah well, might as well put the kettle on.
:popcorn::popcorn::drink:at the ready.
I am in.
Simon.
1 person likes this
