keefr22 Posted August 25, 2017 Share Posted August 25, 2017 Giorgio - FANTASTIC....!! That's all, carry on....!! Keith 1 Link to comment Share on other sites More sharing options...
Thom216 Posted August 25, 2017 Share Posted August 25, 2017 Great update that was worth the wait! 1 Link to comment Share on other sites More sharing options...
giemme Posted August 25, 2017 Author Share Posted August 25, 2017 2 hours ago, 73north said: Hi Giorgio I have posted an ' expert packing guide ' to the Buy and Sell section ' That details my methods and how I pack - I have sold 10 Aircraft Kits all over the world , including Japan and Italy , from Scotland and they have all arrived safe and sound plus you make a nice profit when you sell a rare Pro-Built Model on ebay ( always say its ' pro-built ' ) you might like this ??http://www.arcair.com/Gal11/10801-10900/gal10812-Ki-84-Walker/00.shtm Thanks David And the Frank looks great, too 2 hours ago, keefr22 said: Giorgio - FANTASTIC....!! That's all, carry on....!! Keith Cheers K, glad you like it! 1 hour ago, Thom216 said: Great update that was worth the wait! Thanks Thom, more to come on Monday Ciao 2 Link to comment Share on other sites More sharing options...
The Spadgent Posted August 25, 2017 Share Posted August 25, 2017 Wonderful update G. all those little bits really make all the difference. Bravo. Have s great weekend. Johnny. 1 Link to comment Share on other sites More sharing options...
Biggles87 Posted August 26, 2017 Share Posted August 26, 2017 I too had forgotten how detailed the wheel wells are until I saw them again. Waiting impatiently for Monday now. John 1 Link to comment Share on other sites More sharing options...
Fritag Posted August 26, 2017 Share Posted August 26, 2017 16 hours ago, perdu said: your painting IS AWESOME, no doubt about it Giorgio, I agree with my above mentioned elder and better. Always learn something from your finishing Link to comment Share on other sites More sharing options...
giemme Posted August 26, 2017 Author Share Posted August 26, 2017 (edited) 12 hours ago, The Spadgent said: Wonderful update G. all those little bits really make all the difference. Bravo. Have s great weekend. Johnny. Cheers Johnny, thanks Have a great WE you too 4 hours ago, Biggles87 said: I too had forgotten how detailed the wheel wells are until I saw them again. Waiting impatiently for Monday now. John Thanks John, too bad they are on the underside ... More progress done last night, the bottom side is now completed. Alas, no pics till Monday, and I think I should be able to complete the whole thing by then. Fingers crosses. 2 hours ago, Fritag said: Giorgio, I agree with my above mentioned elder and better. Always learn something from your finishing Thanks Steve, much appreciated Ciao Edited August 26, 2017 by giemme 1 Link to comment Share on other sites More sharing options...
Massimo Posted August 26, 2017 Share Posted August 26, 2017 (edited) Hi Giorgio, Nice little touches that can make the difference! Well done!!! Edited August 26, 2017 by massimo2 1 Link to comment Share on other sites More sharing options...
giemme Posted August 28, 2017 Author Share Posted August 28, 2017 (edited) On 26/8/2017 at 15:33, massimo said: Hi Giorgio, Nice little touches that can make the difference! Well done!!! Thanks Massimo, it is nice when you get at this point of a build, adding the final details Hi everybody, I think I can call the C202 completed But let's see the last few steps. First off: look, she's on her legs!! Main wheels ant tail wheel were installed using drops of CA gel to hold them in place and Tamiya Green Cap to secure the bond. The steel rod used to represent the actuator arm were glued in place with a tiny amount of CA gel, bot sides. Inner side bay doors and their brackets: HASEGAWA has molded a mounting peg on each of said brackets, which doesn't have a corresponding receiving hole in the door so I did cut the pegs out and glued those bits in place, adding also the yellow pipes overlapping the brackets The brake lines were then glued to the wheels Last details; there's a fuel tank vent, port side; here's the kit part along with tits replacement, a segment of brass pipe cut and bent to shape In place and brush painted with Italeri Flat Steel Tail planes: if you squint, you may see I have brush painted two little red arrows (supposedly) used to check the alignment, since they had variable incidence Pitot tube: I replaced the kit part with a scratch built item, using a prescription needle and a steel rod: Here it is, compared to the plastic bit painted and in place Canopy opening handles: I sourced two suitable leftovers from a PE fret, glued in place with CA gel and painted accordingly Then, with the help of some blue tack, I glued the canopy in position - again, CA gel drops and some Tamiya Green Cap along the joint, applied with a fine brush Antenna mast and its wire which is, as usual for me, one of my daughters' hair Then I just needed to glue in the propeller, and there she is: I'll post an RFI thread soon-ish, meanwhile all comments welcome Ciao Edit: I forgot to mention that work on the C205 (remember this is a double build? ) will resume soon. Meanwhile I'll take a short break off this thread and try to complete the bust I started long ago Edited August 28, 2017 by giemme 13 3 Link to comment Share on other sites More sharing options...
Jamie_Graham Posted August 28, 2017 Share Posted August 28, 2017 Those final photos of the model are really nice!!! As usual, those final details have given life to the model! Congratulations on the work done with this macchi!! 1 Link to comment Share on other sites More sharing options...
AlexN Posted August 28, 2017 Share Posted August 28, 2017 Bellissimo! 1 Link to comment Share on other sites More sharing options...
Spookytooth Posted August 28, 2017 Share Posted August 28, 2017 Fantastic build Giemme. So you are off to play with a BUST eh? Fnar Fnar Simon. 1 Link to comment Share on other sites More sharing options...
Massimo Posted August 28, 2017 Share Posted August 28, 2017 That's it!!! RILLI RILLI UELLDON!!! 1 Link to comment Share on other sites More sharing options...
Fritag Posted August 28, 2017 Share Posted August 28, 2017 Beautiful aircraft and a superbly executed build Giorgio. You make it look effortless. 1 1 Link to comment Share on other sites More sharing options...
giemme Posted August 28, 2017 Author Share Posted August 28, 2017 1 hour ago, Jamie_Graham said: Those final photos of the model are really nice!!! As usual, those final details have given life to the model! Congratulations on the work done with this macchi!! Thansk Jamie, glad you like her! 53 minutes ago, AlexN said: Bellissimo! Thanks Alex 35 minutes ago, Spookytooth said: Fantastic build Giemme. Thanks Simon 35 minutes ago, Spookytooth said: So you are off to play with a BUST eh? Fnar Fnar Oh, stop it! 3 minutes ago, massimo said: That's it!!! RILLI RILLI UELLDON!!! Thanks Massimo! 2 minutes ago, Fritag said: Beautiful aircraft and a superbly executed build Giorgio. You make it look effortless. Cheers Steve, thanks - much appreciated I surely had fun in building it Ciao Link to comment Share on other sites More sharing options...
keefr22 Posted August 28, 2017 Share Posted August 28, 2017 Really lovely little Italian beauty G, gorgeous stuff! One of the models of the year so far on BM for me! K 1 1 Link to comment Share on other sites More sharing options...
giemme Posted August 28, 2017 Author Share Posted August 28, 2017 48 minutes ago, keefr22 said: Really lovely little Italian beauty G, gorgeous stuff! One of the models of the year so far on BM for me! K Thanks K, way too kind Ciao Link to comment Share on other sites More sharing options...
Thom216 Posted August 29, 2017 Share Posted August 29, 2017 Lovely job. She looks great. 1 Link to comment Share on other sites More sharing options...
Cookenbacher Posted August 29, 2017 Share Posted August 29, 2017 Just beautiful Giorgio. 1 Link to comment Share on other sites More sharing options...
airbus320 Posted August 29, 2017 Share Posted August 29, 2017 Magnificent! I have four of these in the stash and when I get round to building them I will return to this thread for inspiration and tips! Chris 1 Link to comment Share on other sites More sharing options...
Leonl Posted August 29, 2017 Share Posted August 29, 2017 (edited) Beautiful! I've really enjoyed this build. As usual a display of excellent modelling with plenty of tips along the way.... I did laugh a litttle at you using your daughter's hair for the wire as I always use my wife's hair! Edited August 29, 2017 by Leonl Correcting a typo 1 1 Link to comment Share on other sites More sharing options...
giemme Posted August 29, 2017 Author Share Posted August 29, 2017 6 hours ago, Thom216 said: Lovely job. She looks great. Thanks Thom! 3 hours ago, Cookenbacher said: Just beautiful Giorgio. Cheers Cookie, glad you like her! 57 minutes ago, airbus320 said: Magnificent! I have four of these in the stash and when I get round to building them I will return to this thread for inspiration and tips! Chris Four? You sure like these Macchis, don't you? Thanks for you appreciation 33 minutes ago, Leonl said: Beautiful! I've really enjoyed this build. As usual a display of excellent modelling with plenty of tips along the way.... I did laugh a litttle at you using your daughter's hair for the wire as I always use my wife's hair! Can't beat women hair for this kind of job, can you? Thanks Leon Ciao Link to comment Share on other sites More sharing options...
giemme Posted August 29, 2017 Author Share Posted August 29, 2017 Hi everybody, RFI posted here: Ciao 2 Link to comment Share on other sites More sharing options...
Gene K Posted August 29, 2017 Share Posted August 29, 2017 1 hour ago, giemme said: Hi everybody, RFI posted You could have been a surgeon. Gene K 3 Link to comment Share on other sites More sharing options...
giemme Posted August 29, 2017 Author Share Posted August 29, 2017 2 minutes ago, Gene K said: You could have been a surgeon. Gene K Nobody ever told me anything like that ... Ciao 1 Link to comment Share on other sites More sharing options...
