Fishbone Posted February 17, 2017 Share Posted February 17, 2017 This is a Hobbyboss F-14D Super Tomcat. When the box is opened, one sees the usual high quality Hobby Boss engraved detailing on this one. The upper and lower fuselage sections are segregated behind a cardboard shield to keep damage during shipping at a minimum. Kit has fine engraved surface features, well detailed tandem cockpits, optional swept or extended wings, multi-part canopy, detailed wheel wells and landing gear and your choice of open or closed exhaust nozzles. Also includes external stores: AIM-54 Phoenixes (x4), AIM-7 Sparrows (x2), AIM-9 Sidewinders (x2) and drop tanks. Decals and color painting guide for 3 USN aircraft: BuNo 159630 of VF-2 onboard USS Constellation (low-vis); BuNo 163894 of VF-2 onboard USS Constellation (CAG high-vis) & BuNo 164603 of VF-31 onboard USS Theodore Roosevelt; Includes instrument panel and console markings, stencil data and weapons markings.I'll use the VF-2 CAG scheme, I love planes which fought a lot. Let's do this. Cockpit, the ejection seats are quite awkward, no details. So I decided to add some details onto them. One more benefit for adding weight on nose - you can deny physic like this. Adjust the height of seats, they are way much taller in real world. And then slowly adding details onto those landing gears. That's all for the day, will keep update this thread. Thank you. 2 Link to comment Share on other sites More sharing options...
neil5208 Posted February 17, 2017 Share Posted February 17, 2017 Nice start, will follow Link to comment Share on other sites More sharing options...
Crossofiron1971 Posted February 17, 2017 Share Posted February 17, 2017 Lovely work sir! Link to comment Share on other sites More sharing options...
Fishbone Posted February 17, 2017 Author Share Posted February 17, 2017 6 minutes ago, neil5208 said: Nice start, will follow Thanks, actually I have 2 Tomcats and they're on the work station now, the other one was Academy F-14A with VF-51 marking decals but I decided to go "what-if" theme - JASDF 3rd Air Wing F-14J Kai "Samurai Cat" (航空自衛隊 F-14J改 第3飛行隊 93-4986 "武士貓") Here's some basic concept done in Photoshop, the decals are actually done and I've already sent to print. I will continue working on this What-if F-14J Kai Samurai Cat after I finish this F-14D. Decals size-proofing before send to print. Will continue after I finish current F-14D. 3 Link to comment Share on other sites More sharing options...
Fishbone Posted February 20, 2017 Author Share Posted February 20, 2017 Hi, some updates. PRIMED. Some new experiments: Ultimate Black - spray randomly including pre-shading on panel lines. Covered with Brown & blue for warm/cold colors. Belly/undercarriage, mostly Ultimate Black, very minor of Brown and Blue. Intake to exhaust. Done drop tanks, Gunze 308 FS36375 + Gunze 1 White. Gunze 9 - Gold, applied onto those exhaust nozzles. 2 Link to comment Share on other sites More sharing options...
Jackman Posted February 20, 2017 Share Posted February 20, 2017 I really like the Neko Samurai scheme. How did you create the decals? Link to comment Share on other sites More sharing options...
Fishbone Posted February 20, 2017 Author Share Posted February 20, 2017 25 minutes ago, Jackman said: I really like the Neko Samurai scheme. How did you create the decals? Design then print it, will keep updating about it here! Link to comment Share on other sites More sharing options...
Fishbone Posted February 22, 2017 Author Share Posted February 22, 2017 Some updates: Not sure right or wrong, let it be and will touch up during final stage. 2 Link to comment Share on other sites More sharing options...
Fishbone Posted February 23, 2017 Author Share Posted February 23, 2017 Made adjustment and color correction with Tamiya Black accent color, XF-2 Flat White & XF-10 Flat Brown. Coated with Gunze Super Clear III to protect everything and spent around 5 hours for the decal application. It's 90% done, the rest is the one on Ventral Fins which I really forgot to spray Dark Blue. 3 Link to comment Share on other sites More sharing options...
Duncan B Posted February 23, 2017 Share Posted February 23, 2017 Lovely job you've done. Duncan B Link to comment Share on other sites More sharing options...
SallysDad Posted April 3, 2017 Share Posted April 3, 2017 Beautiful build. Link to comment Share on other sites More sharing options...
