jupy41
Speeder bike - Pursuit in the forest of endor
24 posts in this topic
Hi everyone
I will try to share with you, the assembly of the speeder bike with scout trooper.
I'm sorry, but my English is poor ... so I'll try to explain clearly ;)
I had already made the kit from AMT a few years ago, but the bandaï seems to me better proportioned, on the right scale.
I pass quickly on the contents of the kit with a picture that summarizes all the parts of the box:
KR_20speederbike0.jpg?v=f75rik5scle6mo0
The molding is very nice and the assembly could be done without glue, like the gundams ;)
It is on the scout trooper that there will be the hardest work.
The only advantage (for me) of this mounting option is that you can mount and disassemble the miniature as you want ... easy for testing and mounting.
The head will be disassembled to hide the mask before painting:
Speederbike_20V2_0_80.jpg?v=22j43w5scmk7
Then I assembled the bust.
The joints will make it possible to give a dynamic position to the figurine and which will be specific to each assembly
Speederbike_20V2_0_90.jpg?v=e8prws5scmk8
The legs are then assembled on the bust,
The knee protectors allow to hide the joints of the knees, but the ankles look like "toy".
Speederbike_20V2_0_110.jpg?v=1k17rg5scmk
The arms are assembled, one hand on the handlebars and the other is in blaster shot position
Speederbike_20V2_0_120.jpg?v=1ulzm4kylzi
On the side of the speeder, I assembled the stabilizers, very well detailed, with a small line of joint that must disappear
Speederbike_20V2_0_130.jpg?v=1uo0p85tm3v
The speeder is fully assembled to give a definitive look to the figurine
Speederbike_20V2_0_140.jpg?v=1ulo5o5tm3v
I will replace the plastic cover with a more realistic cover.
For this I remove the fixing studs
Speederbike_20V2_0_150.jpg?v=1to9l8kylzi
On the figurine side, the articulations are blocked with glue, then filled with milliput.
They will be smoothed later with "Mister surfacer"
Speederbike_20V2_0_180.jpg?v=1qovws5tm3w
The thrust flaps are modified to be in a semi-open position, and different from each side.
Speederbike_20V2_0_190.jpg?v=1q55l8kylzn
See you soon, guys ^_^
13 people like this
Looking great so far, i look forward to the rest of the build B)
Good start. Will follow with interest,  always enjoy speeder bike builds!
Very nice start. Good photography and good explanations.
I am very interested to see how the joint filling turns out. Recently, I've been thinking how to make these figures look more realistic by eliminating the gaps around the articulated joints.
Gap covering.
Tissue paper and white glue?
I built this kit a few years ago.  It has ok details,  I'll watch your improvements.  Have Fun.
Hi, thanks to all ;)
The plastic cable of the gas handles is replaced by a 1 mm spring wire cable from T2M
Speederbike_20V2_0_200.jpg?v=1qlu305tm3w
Larger springs will also fit the engine.
I place inside the spring, a piece of tin wire to be able to form them as I want
Speederbike_20V2_0_210.jpg?v=1qebgs5tmke
The first is in place ... it seems a little too big, so I will replace it with a slightly smaller diameter
Speederbike_20V2_0_220.jpg?v=1urpu45tmke
All the hoses are shaped
Speederbike_20V2_0_260.jpg?v=1uu3kc23vv0
A small non-molded detail on the crate was corrected by adding two small washers, made with push & die tool.
Speederbike_20V2_0_270.jpg?v=1ehv2k23vv4
The engine and stabilizers  receive a matt black basecoat.
Speederbike_20V2_0_280.jpg?v=7xlsb07l74e
Speederbike_20V2_0_290.jpg?v=7rtpxo7l7b4
Then, I passed a thin layer of dark gray Vallejo 862, as well as on the stabilizers
Speederbike_20V2_0_310.jpg?v=1fzrm47l7cr
The body is painted in matt black
Speederbike_20V2_0_320.jpg?v=7xj2bw7l7h2
The saddlebags and the bottom of the bust are painted in matt white, then stained with MIG pigments
Speederbike_20V2_0_340.jpg?v=ge9c3w7m68s
Gap covering.
Yes, absolutely
See you soon, with the return of the force :ninja::)
5 people like this
Coming along nicely.
The body of the scout trooper is painted black satin
Speederbike_20V2_0_350.jpg?v=gsfi4s245qi
And here is the figure assembled before realizing the patina
Speederbike_20V2_0_360.jpg?v=gus4247m699
Motor and stabilizers are brushed with medium gray
Speederbike_20V2_0_390.jpg?v=1e6suk23unb
Speederbike_20V2_0_400.jpg?v=elgwi45up4r
Second phase of painting for body parts: Alclad Aluminum
Speederbike_20V2_0_410.jpg?v=giee8c5up4r
Then comes the phase of the scuffs. A layer of chipping fluid is passed over the alclad, then a layer of red brown XF64 Tamiya.
When it's dry, I brush it with a wet brush at some scuffed places.
I continue the patina with MIG pigments.
Speederbike_20V2_0_460.jpg?v=elgux85up4r
For the engine block, which suffered some damage, I opted for a sponge brushing with silver titanium X32.
All mechanical parts are painted using the same method
Speederbike_20V2_0_430.jpg?v=ekt37wl2ih8
Speederbike_20V2_0_440.jpg?v=gvje6k5up4s
Speederbike_20V2_0_450.jpg?v=1s1c3w5up4s
.....To be continued :)
8 people like this
Hi everybody
Here is the continuation ^_^
A casing connects the engine with the stabilizers:
Speederbike_20V2_0_480.jpg?v=gig8zwl2ih8
Speederbike_20V2_0_490.jpg?v=1ostcc5up4s
For the trooper, I put brown and black washes on the armor, and finally, I make some traces with pigments MIG:
Speederbike_20V2_0_370.jpg?v=1j2nbgl2ihx
The black clothes are brushed with graphite powder to give a "leather aspect".
Speederbike_20V2_0_380.jpg?v=1gvkwc5up4z
For the texture of the cover, I use tissue paper with wood glue
Speederbike_20V2_0_500.jpg?v=1epg2423weq
I cover the piece with tissue paper, giving the folds that we want to appear to the reality.
Speederbike_20V2_0_510.jpg?v=1lviq423wes
When it’s dry, I obtain a tissue appearance, with some voluntary folds ...
I can paint a base in Dark yellow XF60
Speederbike_20V2_0_520.jpg?v=1ky07g7l8ow
Then I prepare a wash with burnt sienna (oil paint + thinner F)
The wash is deposited in all the hollows with a fine brush in order to create zones of shadows
Speederbike_20V2_0_530.jpg?v=1ge9vw7l8pk
Speederbike_20V2_0_540.jpg?v=1lwo7g7l8pk
Next comes the brushing on the areas of light (mixt of sienna and white titanium) with a dry brush
Some pigments will finish the patina later
Speederbike_20V2_0_550.jpg?v=1pscy4l3021
Speederbike_20V2_0_560.jpg?v=1pncss23wem
9 people like this
Very impressive work jupy
It will a real pleasure to read the next steps !
Have a nice day
This is great. Loving your work.
Hi guys, after a good week of holidays in the Alps, I come back on the speeder bike.
All elements are assembled ... without glue, thanks to the Bandaï design ;)
Speederbike_20V2_0_570.jpg?v=1u324sl3028
We can see the 4 straps fixing the cover, made thanks to the capsule of the an excellent Bordeaux wine ;)
The handlebars were brushed with gun metal pigment to bring out the metal side. Spring steel replace the plastic part
Speederbike_20V2_0_580.jpg?v=h1nrt8l302a
The matt black seat is brushed with a clear pigment to give a used look. I drilled a hole that will fix the scout trooper
Speederbike_20V2_0_590.jpg?v=1lqhscl302c
A profile view, showing the damage sustained during this pursuit in the forest of Endor
Speederbike_20V2_0_600.jpg?v=gxb9u4l302g
The triangular logos on the front wings are painted with red color
Speederbike_20V2_0_610.jpg?v=1l0eq423wen
View on the dashboard, patinated with black wash and pigments.
Speederbike_20V2_0_620.jpg?v=gxeg0cl302m
See you soon ;)
7 people like this
The straps of cover are made with pieces of plastic-card and photoetched rivets
Speederbike_20V2_0_630.jpg?v=1q540cl31wy
matt black paint and brushing in gun metal, and here is the cover in place and strapped.
Speederbike_20V2_0_640.jpg?v=21mah8l31x3
A little earth on the soles of the boots ... with the paint "soil effect" Tamiya
Speederbike_20V2_0_650.jpg?v=1y3nv023wlb
The scout trooper is now installed on his mount, blaster in hand, ready to shoot.
Speederbike_20V2_0_660.jpg?v=1hfwjw23wlb
I secured the grip between the feet and the pedals with micro-screws
Speederbike_20V2_0_670.jpg?v=hfizkcl31x9
After few trials for the blaster shoot, I opted for the following solution:
White Styrene wire 0.7 mm , painted with translucent red, then scraped with a blade on the flank, to give a bright impression.
Speederbike_20V2_0_680.jpg?v=1edqj0l31xd
See you soon, guys ;)
7 people like this
Love the straps, nice little detail. He's looking great!
Good afternoon, everybody :)
I put the speeder aside to start the ground .... I use a thick photo frame costing 5 € .
I attached the speeder holder with the glue 21 and sealing powder.
Speederbike_20V2_0_700.jpg?v=1vho5o24hhs
I used a piece of vine representing an old strain, and foam board for the base of the ground.
Speederbike_20V2_0_710.jpg?v=1uw70s24hhx
A brush with acetone makes it possible to have an irregularity on the ground
Speederbike_20V2_0_720.jpg?v=1vweq424hi8
I finally changed the layout of the strain in the décor, by simply turning it over.
I find that its integrates better like that.
Speederbike_20V2_0_730.jpg?v=h923yk24hic
For the floor, in order:
Base painted in matt brown, then textured paint for tamiya floor, followed by brown and black MIG washes  .... let dry before adding pigments and foliage.
Speederbike_20V2_0_740.jpg?v=1hd28c24hif
For the nameplate of the diorama, I used a piece of rusty metal
Speederbike_20V2_0_750.jpg?v=1r35ho24nsc
The ground is brushed with a hue composed of sienna, naples yellow and titanium white.
Speederbike_20V2_0_770.jpg?v=1r9jt87nz8a
I put the nameplate in front of the tree trunk
Speederbike_20V2_0_780.jpg?v=1qa6j024nsf
And here is the scout on his speeder bike.
The vegetable touch is given with chopped parsley and tea leaves (Pineapple and Vanilla, for odor).
Speederbike_20V2_0_790.jpg?v=1r3rm47nz93
And here are some pictures outside
Speederbike_20V2_0_801.jpg?v=1l7pfwl722p
Speederbike_20V2_0_810.jpg?v=1tso0cl722q
Speederbike_20V2_0_820.jpg?v=1v6jyk24b0a
Speederbike_20V2_0_830.jpg?v=1wp5e4l722u
Speederbike_20V2_0_840.jpg?v=1wuuto24b0a
7 people like this
Exceptional work! The diorama is very well done. :worthy:
mega work on the model and the base, you can almost smell the burning Ewoks  :)
