gamblor916 Posted February 6, 2017 Share Posted February 6, 2017 (edited) This was probably my most favourite Bandai kit to date. No glue anywhere and all the seams are small or hidden. I lit this with a couple of Leds and button batteries so it's all contained. The switch is hidden behind the right gun and the batteries are accessible via the underside panel. Edited July 22, 2017 by gamblor916 Photobucket 30 Link to comment Share on other sites More sharing options...
Mike Posted February 6, 2017 Share Posted February 6, 2017 That's a cracker! Lovely neat wiring too 1 Link to comment Share on other sites More sharing options...
Habu12 Posted February 8, 2017 Share Posted February 8, 2017 Nice nice. I also lit mine, almost identically...not that it's that variable of a route. Except my power source is underneath the base. 1 Link to comment Share on other sites More sharing options...
gamblor916 Posted February 8, 2017 Author Share Posted February 8, 2017 I cut away a lot of plastic without damaging the attachment points but it's still a tight fit. 1 Link to comment Share on other sites More sharing options...
Will Vale Posted February 8, 2017 Share Posted February 8, 2017 Really lovely, the lit engines are perfect. What kind of switch did you use? It looks like a sliver of PCB with switch on the edge rather than sticking up? Will 1 Link to comment Share on other sites More sharing options...
gamblor916 Posted February 9, 2017 Author Share Posted February 9, 2017 (edited) Thanks. This is a stock photo I found. It's a tiny 3 pin slide switch. I bought a bunch a few years ago off ebay. Edited February 9, 2017 by gamblor916 2 Link to comment Share on other sites More sharing options...
Will Vale Posted February 9, 2017 Share Posted February 9, 2017 Thanks! Will have to find some of those as they're very discrete. W 1 Link to comment Share on other sites More sharing options...
BrotherMole Posted February 10, 2017 Share Posted February 10, 2017 I really like it and I particularly like these kits in 'non-standard' or 'not in the movie' colours - in an odd way it makes them feel a bit more 'real' to me, perhaps because I haven't seen them like this before. Irrespective cracking model - thanks for sharing. 1 Link to comment Share on other sites More sharing options...
Hunter Rose Posted February 10, 2017 Share Posted February 10, 2017 I love the a wing and its very cool in green, great job with the lighting too! I'll also be grabbing some of those dinky switches too, perfect for my current project thanks for sharing 1 Link to comment Share on other sites More sharing options...
HOUSTON Posted February 10, 2017 Share Posted February 10, 2017 Gamblor916... STUPENDOUS build. LIKED it.. have you taken any night shots with the lights on... I imagine it looks SUPERB in the night. Good job. 1 Link to comment Share on other sites More sharing options...
gamblor916 Posted February 11, 2017 Author Share Posted February 11, 2017 I've been asked how I've cramed all the lighting bits in there so rather than explaining with just words I've pulled it apart and taken a few shots. Bandai have done such a great job with this kit that it's an easy exercise to disassemble and reassemble at will. Here's the battery access in case I need to replace the batteries. This is the general wire layout. Just a simple parallel circuit. Battery holder is just a few bits of styrene glued into a box. Led fits inside a hole drilled on part B8. I hope you can see the areas I needed to cut away so the wires can thread through. Switch is hidden next to right gun mounting point. I use tweezers to turn it on and off. Put it back together and everything stills works. 7 Link to comment Share on other sites More sharing options...
HOUSTON Posted February 11, 2017 Share Posted February 11, 2017 Thank you for showing the disassembled and assembled photos of your models. when you are able to refigure it back to its original status ,it shows your skills are impressive. SUPER build and CLEAN photos. 1 Link to comment Share on other sites More sharing options...
Orangesherbert Posted February 16, 2017 Share Posted February 16, 2017 Thats a beaut ! chippy tastic. Lovely work 1 Link to comment Share on other sites More sharing options...
Zarichta Posted February 16, 2017 Share Posted February 16, 2017 Uau!! Great! Cheers! 1 Link to comment Share on other sites More sharing options...
evansdad Posted February 16, 2017 Share Posted February 16, 2017 Very nice. I plan to do mine in green as well. The A-wings that attacked the Death Star 2 and Executor in Return of the Jedi were actually members of Green Squadron, but ILM had trouble compositing them, so the color changed to red. But you probably already knew that. 2 Link to comment Share on other sites More sharing options...
noelbarnes Posted February 17, 2017 Share Posted February 17, 2017 Excellent. Love all your wiring and the way you have hidden the switch. Top notch. 1 Link to comment Share on other sites More sharing options...
