Joss Posted February 5, 2017 Share Posted February 5, 2017 Hi everyone. Just a quick question regarding the hellcat. I'm currently build the Eduard weekend edition and going for the marking #21 from vfn-90. I pulled this picture; Here And was wondering if anybody's got any idea what the discolouration on the wing was? Any help would be greatfully accepted. Regards Joss Link to comment Share on other sites More sharing options...
JackG Posted February 6, 2017 Share Posted February 6, 2017 Looks to be inline with the guns, so perhaps residue from that, along with some scuffing from maintenance crews. It might more than just colour difference. If the aircraft in question has some kind of gloss finish, than the flat sheen of the discolouration will be that much more apparent compared to the surrounding cleaner areas. regards, Jack. Link to comment Share on other sites More sharing options...
Joss Posted February 6, 2017 Author Share Posted February 6, 2017 Cheers jack that's what I was thinking, they are meant to be finished in gloss blue but the fact it's only dirty that on one wing and nowhere else seems odd to me?! It seems the stabilisers have a gloss finish so it could be fading mixed with gun residue. Many thanks Regards Joss Link to comment Share on other sites More sharing options...
Arniec Posted February 6, 2017 Share Posted February 6, 2017 I had also the same idea as Jack. The ones near the fuselage are from the walk ways to the cockpit and oil tank that is in front of the cockpit?! Cheers, 1 Link to comment Share on other sites More sharing options...
JackG Posted February 6, 2017 Share Posted February 6, 2017 (edited) Bit more top view showing similar discolouration: regards, Jack Edited February 6, 2017 by JackG 1 Link to comment Share on other sites More sharing options...
DaveCromie Posted February 12, 2017 Share Posted February 12, 2017 Looking at the rather nice picture posted by JackG i would suggest that the discolouration shown is due to running the engine at a lean setting. The lead in the exhaust mixture causes a lighter than expected staining. I do, as usual, stand to be corrected! DC 1 Link to comment Share on other sites More sharing options...
Work In Progress Posted February 13, 2017 Share Posted February 13, 2017 Yes, that's what is happening at the wing root. The engine is being operated correctly for range and/or endurance, which is always a good idea in carrier ops! 3 Link to comment Share on other sites More sharing options...
Joss Posted February 13, 2017 Author Share Posted February 13, 2017 Thanks everyone, i shall try to replicate the effect and see how it goes! I'll try to use a light creamy colour. Joss Link to comment Share on other sites More sharing options...
Work In Progress Posted February 13, 2017 Share Posted February 13, 2017 Go with a sooty black outside the pattern laid down by the creamy brown-grey. The aircraft uses full rich mixture for take-off and that's when it's at full power and low speed, so blows out the widest pattern of exhaust residue. Then over a period of hours of cruising flight at lean mixture the paler deposits build up in a narrower pattern. In the pic you can actually see the sootier band, about where the sailor's foot is. 1 Link to comment Share on other sites More sharing options...
Troy Smith Posted February 14, 2017 Share Posted February 14, 2017 (edited) I suspect the wing is showing signs of scuffed and worn paint, as this is the access area to the gun bays , this is a FAA plane, but not the worn and scuffed paint, but not worn to bare metal, also the exhaust stainng Hellcat by Etienne du Plessis, on Flickr this a 1946 shot of a well worn F4U-4, note the paint scuffing and wear to the access area of the forward wing root, as well as the matting down of gloss sea blue paint, more so than than you hellcat subject, but an idea of the way GSB fades and weathers and wears. I'm not sure what Grumman used as a base primer, hopefully Dana bell will see this and say, or someone else will know. Vought use zinc chromate by this point i think, and that;s whats under the worn GSB for exhaust staining, this shows the creamy- brown-grey colur,well, the result of a lean mixture and lead oxide being deposited HTH Edited February 14, 2017 by Troy Smith tidying up 3 Link to comment Share on other sites More sharing options...
Joss Posted February 19, 2017 Author Share Posted February 19, 2017 Cheers guys sorry I did not reply sooner did not see this go off... Very helpful information troy, my only query which may sound daft is would the nightfighters faded down to Matt as they where only flown at night or did they get flown in the day as well? Cheers WIP I shall give that a go once I've got the last of the stencils on (so many of them!) Regards Joss Link to comment Share on other sites More sharing options...
