Shar2 Posted February 5, 2017 Share Posted February 5, 2017 AS-90 155mm SPG Detail set 1:35 Tetra Model Works The Trumpeter 1:35 AS-90 155mm Self Propelled Gun has been out for nearly 15 years now, so it’s good to see that it’s still getting attention by the aftermarket companies. This set is for the general detail; the other set released alongside it will be reviewed separately HERE, and contains two sheets of relief etched brass. What sets this detail set above some others is the beautifully laid out and easy to read instructions, which show exactly where the completed parts are meant to be fitted, unlike some other companies. Whilst the majority of parts on the sheets are for the smaller items, such as brackets, headlight guards, latches, clamps and hinges, there are some important additions. The thing that most modellers moaned about with the kit si the lack of stowage basket on the rear turret roof, well this in included in this set, along with new stowage boxes, ID box and grille for the rear of the turret, new lids for the turrets side bins. Then there are the engine intake grilles, air conditioner grille, smoke discharge plate and brackets, new ammunition stowage for the GPMG boxes, which also receives a new ammo box and ammunition, and the faces of all the viewing ports. There doesn’t appear to be much of the kit detail to be removed for the PE, mainly due to the fact the parts weren’t included in the kit so fitting is pretty easy. That said, some of the folding is a little fiddly as it is in most PE sets, and some parts need to be indented by use a ball point pen in one side, particularly the louvers on the grilles over the air conditioner box. Conclusion Given that the AS-90 kit has been out some time now, it’s great to revisit it with the release of this very nice set from Tetra Model Works. With very few complex bends or folds it should be useable by all but the newest modellers and would be a good introduction to the art of using etched brass. The details contained in the set do help to improve the somewhat clunky look that of the styrene parts, plus adding some that was completely missing, and will help make a good looking model into a great one. Review sample courtesy of Link to comment Share on other sites More sharing options...
Panzer Vor!!! Posted February 5, 2017 Share Posted February 5, 2017 Hi I will have to have a nosy at this , esp as you says its simple !!!!! Link to comment Share on other sites More sharing options...
