Vickers 0.50 Quad Machine Gun Mounts
Shar2
1/350 Tetra Model Works
Sometimes, when building a model there are items that you’d love to add that extra bit of detail or change only a small part of the kit parts that you feel would be better in brass, without having to go to the expense of buying a full set for which you’d only use a few parts. Known for their super large sets for complete ship kits, Tetra Model Works have released this small set of Vickers quad .50 Machine guns. There are four complete mountings included and whilst looking very well produced, you will need some serious magnification on your optivisor as the parts are very, very small. Once built however, they will be mini masterpieces. There are sixteen etched brass parts and four turned brass barrels per mounting, giving you an idea of the detail included. Large ships usually had four mounts, although the Ark Royal had mounts, so you will need two sets, Cruisers and destroyers had two mountings.
Conclusion
Since the Royal Navy used these mounts on most ships until they were superseded by the 20mm Oerlikon this set will be very widely used. You will need to do your research to see whether the ship you are building still had them fitted during period you are building it, as they were generally withdrawn from general use around 1941/1942. Other than that they are really great little items and will give an extra dimension to you model.
        Review sample courtesy of
  • 4 months later...
