HS-125 in 1/48
bar side
Hi
Now as far as I know there are no kits for a 1/48 HS-125, so if I want one I guess I would have to scratch build one.  I did print & scale up some outline plans and found a length of pipe about the right size for the main fuselage section
So the basic shape may be do-able.  The trouble is the more detailed areas - engines, undercarriage etc.  Are there any existing kits or parts that might be suitable?  Not a lot about in 1/48 that I can see - learjet or maybe some after market wheels?
Any ideas gratefully recieved
Hasegawa did a range of Biz jets in 1/48th that might proivide parts - the Falcon 10 (Also issued by Revell) might even have the right enines for later 125s depending on what markings you want. (The RAF 125-400 and 600s were re-engined with Garretts)
Thinking about it, the Learjet (also issued by Revell) also had Garretts. Revell aslo did the Citation
Edited by Dave Fleming
22 minutes ago, Gary West said:
Cant be of help but Id love to make a Dominie in 1/48 scale - good luck with your project
Hmm, don't know if it will ever make it as far as a project - more a 'pipe' dream!
Something tells me it would be easier to use pipe, card and wood to make up a pattern & vac form it.  Might reduce the amount of building up
3 minutes ago, Dave Fleming said:
Hasegawa did a range of Biz jets in 1/48th that might proivide parts - the Falcon 10 (Also issued by Revell) might even have the right enines for later 125s depending on what markings you want. (The RAF 125-400 and 600ss were re-engined with Garrets)
Thanks Dave - could be interesting, will have a look at the Falcon 10
Falcon 10 double wheel main gear looks better along with the engines.  Will see though.  I tried setting it up for looks & size using the plastic waste tube for the body center and the plan pasted on to card for the nose tail & wheels. Would look good in 1/48
The hawk is just there for scale
It does look good in 1/48th.
I have a 'desk top' resin model of a 125-800 in Royal Saudi Air Force markings.
Maybe too many differences to be rebuilt as a Royal Air Force aircraft?
But it does show that there are 125's out there.
Sounds nice Pete - those desktop models seem to go for quite a lot on ebay for any aircraft.  I am very tempted to have a go at scratch building something but I am really not sure how I will get on with the undercarriage.  Budget is about zero too.
1 minute ago, Pete in Lincs said:
So do it 'desktop' style.
A square of wood, a piece of dowel
and you have a flying 125.
Problem solved.
You might be on to something there!  Hopefully the box of left over bits with throw something up.
1 hour ago, Pete in Lincs said:
Very nice.  Really just fancied having one sat on the apron around the other jets.  Very few RAF 70s / 80s aircraft in 1/48 outside of the front line jets.  No 125, no jetstream, no chipmunk (well easy one anyway), no andover - so if I want one I think I am going to have to build one.
