Homebee
1/48 - Bell P-63A/C & E Kingcobra by Dora Wings - TP-63E release January 2018 + box art P-63E
Arsenal Model Group (AMG) is to release new tool families of 1/48th and later 1/72nd (then maybe in 1/144th too) Bell P-63 Kingcobra kits.
1/48th first boxing is expected for this Summer.
To be followed.
Sources:
http://amg-models.net/2017/01/17/bell-p-63a-kingcobra/
http://amg-models.net/2017/01/17/bell-p-63c-kingcobra/
http://amg-models.net/2017/01/17/bell-p-63e-kingcobra/
3D renders
The Bell P-63 Kingcobra is an American fighter aircraft developed by Bell Aircraft in World War II from the Bell P-39 Airacobra in an attempt to correct that aircraft’s deficiencies. Although the P-63 was not accepted for combat use by the United States Army Air Forces, it was successfully adopted by the Soviet Air Force.[2]
The production model Bell Model 33; 1725 P-63As produced in various sub-marks.
P-63C Second production series differed from the P-63A by being powered by the uprated Allison V-1710-117 engine with a war emergency rating of 1,500 hp (1,120 kW) at sea level and 1,800 hp (1,340 kW) with water injection. The wingspan was reduced by 10 inches (250 mm). A total production run of 1,227 was completed
P-63E Essentially similar to the P-63D with the exception of a ventral fin extension and the use of a standard “cab”-style cockpit; only 13 built.
V.P.
Edited by Homebee
Very interesting, a new P-63 and not only that a P-63D, P-63E and a two seater! I'm guessing they are doing the standard single seat P-63E also as they only show the two seater version?
Edited by Tbolt
Marvellous - here I've been toiling away on the Toko 1/72 P-63A as a practice run for the P-39/P-63 group build next year, and along comes this! Well, maybe with a bit of luck, the AMG 1/72 version will appear before August 25, 2018! :speak_cool:
John
The E version in the 3D renders are wrong, they were not trainer AC but had a single 'bubble' canopy ...
Otherwise I hope the kits are accurate as I am very interested in modern kits of this beautiful and highly capable design.
But IIRC two E's were the two seaters pictured so I took that to mean we are getting the standard E and the two seater.
Edited by Tbolt
Grammer
charlie_c67 ,  plastik
We will try to make the maximum number of versions.
Ashampoo_Snap_2016_10_14_18h24m13s_018.j
Ashampoo_Snap_2016_10_14_18h22m26s_013.j
Ashampoo_Snap_2016_10_14_18h23m32s_016.j
2 hours ago, charlie_c67 said:
Plastic or resin? :dinosaur:
AMG's other kits are plastic, so I'm sure this will be.
Eugen, if you are going to release Tucker's race aircraft, which you look like you are thinking of with that last drawing, remember that the horizontal tailplanes were cut short as well.
Now, how about the L39 while you are at it? ;)
Edited by LanceB
+1 !!
Yeah and the L39 was painted navy blue, at least one of them
Here one can see the tubular structure of the later fuselage extension:
Edit:
Found a website that explains the developments of the fix of the center of gravity:
http://tailspintopics.blogspot.co.at/2011/04/sweeping-change-bell-l-39.html
Here are some photos that among other things show the second canopy on the trainer version didn't sit as high as displayed in AMD's 3D renderings:
https://wwiiafterwwii.wordpress.com/2016/11/24/p-63-kingcobra-post-wwii-service/
Still time to correct errors I hope
P-63C Second production series differed from the P-63A by being powered by the uprated Allison V-1710-117 engine with a war emergency rating of 1,500 hp (1,120 kW) at sea level and 1,800 hp (1,340 kW) with water injection. The wingspan was reduced by 10 inches (250 mm). A total production run of 1,227 was completed...
Where have you taken this info about 10" shorter wingspan from?
AFAIK the wings of P-63A and P-63C (Bell Model 33) are identical. The longer span wings were featured only by Bell Model 37/41/43 variants (P-63D/E/F).
Michael
Michael
If you Google it, it's copied from Wikipedia. Hopefully they only did that for speed and it's not based on what they are modelling as like you say the wingspan was the same.
Edited by Tbolt
3D model was built a long time - 6 months. Had to learn a lot of information.
The wingspan of model A and C are the same. They are very different near the fuselage.
Therefore, the upper halves of the wing, the model will be the same, bottom different.
In scale P-63C In the process of making molds.
Two forms are ready. Approximately the model will be released in September-October.
Help me please.
Maybe someone knows what the inscription on the left wing is from below..?
My version - "NX41964"
What other options are there?
Thank you!
Best regards,
Eugen
regulus.jpgP-63-twoseater.jpgBell_P63_N41964c1950s082p63vipsml_zpsbdd
10 hours ago, dora said:
Help me please.
Thank you!
Best regards,
Eugen
I would go with the serial number, which was a common post war practice, such as on this P-51. Unless someone can come up with a better picture.
last.jpg?w=809
This P-63F has it under the left wing  (left side picture in the SS In Action book) and the ID number under the right wing, but since 964 doesn't have an ID Number the right wing was probably blank.
Edited by Tbolt
