Buzby061 Posted January 18, 2017 Share Posted January 18, 2017 This is the Airfix Mk 1 Spit finished as a Mk II. The kit includes the cowling bump needed, decals are from Kagero's Polish Spitfires book. I used some Eduard PE in the cockpit & tried using Maskol to represent chipping. I'm reasonable pleased with the result but the engineering of the undercarriage is bizarre, it doesn't look quite right to me. If I do another I'll assemble the u/c legs before attaching to the wings. Any comments, observations or criticisms welcome. Pete Thanks for looking. 18 Link to comment Share on other sites More sharing options...
FatFlyHalf Posted January 18, 2017 Share Posted January 18, 2017 The u/c does look a bit 'toe out' in the pictures, but otherwise I think its a wonderful representation. Out of idle curiosity, what made the u/c construction so bizarre? FFH 1 Link to comment Share on other sites More sharing options...
PlaStix Posted January 18, 2017 Share Posted January 18, 2017 (edited) Great looking Spitfire Pete. Yeah the u/c construction on this kit is awful. The way I dealt with them can be found in the posts below. I basically glued on the upper part early, drilled down through the legs, then cut the parts apart again but in a straight line and used wire to allow for final alignment. Hope it is of some use for future builds. Kind regards, Stix Edited January 18, 2017 by PlaStix 2 Link to comment Share on other sites More sharing options...
polo1112 Posted January 18, 2017 Share Posted January 18, 2017 Great work!!! Bravo. 1 Link to comment Share on other sites More sharing options...
Buzby061 Posted January 18, 2017 Author Share Posted January 18, 2017 56 minutes ago, FatFlyHalf said: The u/c does look a bit 'toe out' in the pictures, but otherwise I think its a wonderful representation. Out of idle curiosity, what made the u/c construction so bizarre? FFH Every other Spit I've built has the u/c leg as a complete unit with a square lug which locates into the wheel well. This gives the correct alignment. Airfix have split it in two with an L shaped join, the short bit near the top. The embuggerance is there's no positive join, hence the 109esque toe out of my Spit. Other than that it goes together very nicely. Pete Link to comment Share on other sites More sharing options...
RMCS Posted January 18, 2017 Share Posted January 18, 2017 Cracking build. 1 Link to comment Share on other sites More sharing options...
Newbie(kinda) Posted January 18, 2017 Share Posted January 18, 2017 7 hours ago, Buzby061 said: Every other Spit I've built has the u/c leg as a complete unit with a square lug which locates into the wheel well. This gives the correct alignment. Airfix have split it in two with an L shaped join, the short bit near the top. The embuggerance is there's no positive join, hence the 109esque toe out of my Spit. Other than that it goes together very nicely. Pete Lovely looking Spit. Haven't used Maskol in years but whatever you did, you did it REALLY well! I've been putting this kit off for over a year now because of the undercarriage...gluing, drilling, cutting and pinning scares the life out of me. And I just know it'll end up in the bin. So kudos to you! 1 Link to comment Share on other sites More sharing options...
Bangor Lad Posted January 18, 2017 Share Posted January 18, 2017 Lovely Spit! Great chips too 1 Link to comment Share on other sites More sharing options...
Meatbox8 Posted January 18, 2017 Share Posted January 18, 2017 What ever the problems you had with the undercarriage you have still turned out a stunning Spitfire. 1 Link to comment Share on other sites More sharing options...
Buzby061 Posted January 19, 2017 Author Share Posted January 19, 2017 Thanks for the kind words. Stix, good tip. I want to do a Mk V in a Malta scheme so I'll save that one up. Newbie, I don't use Maskol much either. Not keen on using something that smells of cat wee. Pete Link to comment Share on other sites More sharing options...
Bell209 Posted January 22, 2017 Share Posted January 22, 2017 I used Maskol heaps until I realised it was the cause of my canopy fogging issues - Future doesn't like it! Yours came up nicely. 1 Link to comment Share on other sites More sharing options...
Buzby061 Posted January 22, 2017 Author Share Posted January 22, 2017 10 hours ago, Bell209 said: I used Maskol heaps until I realised it was the cause of my canopy fogging issues - Future doesn't like it! Yours came up nicely. I never knew that, it certainly is an education being on Britmodeller. Thanks for the info. Pete Link to comment Share on other sites More sharing options...
