Monty Python Posted December 29, 2016 Share Posted December 29, 2016 Thinking of doing the Special Hobby Tempest Mk.V as a TT. Mk.V if only to get away from the usual grey/green finish. liking the look of the high speed silver over yellow/black under surface.. Question is what are the main differences between the 2 versions. The decals given by Xtradecal give a/c NV994/D, which I believe was originally used by Pierre Clostermann with 3 sq. I should imagine canons and gun sight would be removed but anything else? any info regarding target drogue towing fittings? TIA Link to comment Share on other sites More sharing options...
Wez Posted December 29, 2016 Share Posted December 29, 2016 47 minutes ago, Monty Python said: Thinking of doing the Special Hobby Tempest Mk.V as a TT. Mk.V if only to get away from the usual grey/green finish. liking the look of the high speed silver over yellow/black under surface.. Question is what are the main differences between the 2 versions. The decals given by Xtradecal give a/c NV994/D, which I believe was originally used by Pierre Clostermann with 3 sq. I should imagine canons and gun sight would be removed but anything else? any info regarding target drogue towing fittings? TIA Funny you should ask that check this thread out Link to comment Share on other sites More sharing options...
Monty Python Posted December 29, 2016 Author Share Posted December 29, 2016 3 hours ago, Wez said: Funny you should ask that check this thread out Thanks for that. Very helpful Link to comment Share on other sites More sharing options...
