STEEL Remove Before Flight Tags - 1:32 Eduard
1:32 Eduard
Modern combat aircraft seem festooned with RBF tags. This sheet contains 14 RBF tags of five different types, these have a  loop of fine wire adding to attach them to the protective covers that adorn intake FOD barriers, seeker head protectors etc. Some are red with white printing, others with black printing, so check your references to see which type the operator of your model use. This set had printing on both sides, so you won't need to do any tricky paint matching, and there is some text on the back-side for some designs too. Being of the new Steel design like the seatbelts the modeller will be able to bend and shape them without worrying about the paint flaking off, so they should look ore realistic.
Conclusion
These will add a nice final touch to any model. Recommended.
Review sample courtesy of
