Sign in to follow this
Followers 0
Paul A H
Eduard
Fw 190F8 Profipack Edition - 1:72 Eduard
7 posts in this topic
1:72 Eduard
The Focke-Wulf Fw 190 was designed by Kurt Tank in the late 1930s. His aim was to create a fighter that was not only fast and agile, but also reliable. It had a wide track undercarriage to improve ground handling and also utilised electric rather than hydraulic controls to reduce the risk of system loss in combat. The Fw 190 also marked a departure from aircraft like the Bf109 and Spitfire as it combined a 14 cylinder radial engine with a development of the NACA cowling system. This choice was crucial as it meant that the Fw190 would not create additional demand for DB 601 liquid cooled engines. It also allowed a low drag profile for such a powerful engine. Despite early teething problems, the Fw 190 first entered operational service over France in August 1941. It proved to be quite a shock for the RAF whose 1440hp Spitfire Mk.V, the best fighter available at the time, was outclassed in terms of firepower and all round performance, particularly at lower and medium altitudes. The Fw 190 F8 was a fighter-bomber variant developed from the A8 fighter, but with a revised supercharger for improved low-altitude performance and bomb racks under the wings and fuselage.
Eduard have long been capable of churning out excellent kits, but in 2011, with the release of their Hellcat series, that they really set a new standard for plastic kits in the smaller scales. Since then, they have added several superlative kits to their lineup, including the BF110 series, MiG-15 and MiG-15UTI series and their latest release, the Spitfire Mk.IX. They are still adding to their range of Fw 190s though, the newest of which is the F-8. This version of the kit is part of the Profipack range, which means it benefits from the inclusion of masks, photo etched details and a no fewer than five decal options. The kit itself is made up of over 200 plastic parts spread across of three sprues of blue-grey plastic (although a significant number of these are not used for the F8) and a single clear sprue with the now-familiar circular layout. Being a Profipack, photo etched parts and masks are also included. The instruction book is a glossy, stapled booklet with full-colour painting diagrams. All together, the impression is of a quality package.
As you would expect from Eduard, the quality of the plastic parts is second to none. The mouldings are clean and crisp and there are no traces of flash or sink marks. The surface detail on the outside of the airframe comprises recessed panel lines and delicately engraved rivet and fastener detail. It looks absolutely superb. Eduard haven't skimped on the detail elsewhere either; sub-assemblies such as the cockpit are right up there with high end resin items when it comes to the quality and quantity of detail. The cockpit is made up of over thirty parts (including photo etched details), which is a truly phenomenal for a kit of this size. The photo etched parts cover obvious items such as the rudder pedals, seat harnesses and instrument panel and side consoles, although for the latter two items there are plastic alternatives. They really help to raise the level of detail a notch. Once assembled, the whole thing can be sandwiched inside the fuselage halves along with the firewall and the basic-but-good-enough-in-this-scale engine.
Setting the semi-completed fuselage to one side for a moment, construction turns to the wing. The lower wing is moulded as a single span, to which the main spar (which also forms the rear wall of the main landing gear bays) must be added. The other parts which form the structures and details of the landing gear bays must also be added at this point, prior to everything being fixed in place by the addition of the upper wing surfaces. If you wish to use the supplied bomb racks, remember to drill out the appropriate holes at this point. The ailerons are moulded separately to the rest of the wing, which opens up some possibilities for the diorama builder, as well as enhancing the level of realism. Turning back to the fuselage, the rudder is also moulded as a separate part while the tail planes are solid lumps. In common with other kits of the type, the upper fuselage forward of the cockpit is moulded separately (in this case as two parts with a third for the cannon barrels).
Once the basic airframe is together, it’s time to fit the undercarriage and other finishing details. Each of the main gear legs is made up of two parts, although you have the option of removing the plastic torque links and replacing them with photo etched versions. The wheels themselves are made up of nicely moulded tyres and separate hubs. This should make painting them much easier. As this is the F8 version, you get a whole extra sprue containing a wide choice of ordnance including a drop tank, three different types of bomb and two different types of rockets and launch rails. Alternative photo etched parts are provided for the ballistic tails of the bombs. A number of small parts are included to cover the final details, including the aileron balance weights and various aerials and antennae. The canopy deserves a special mention as there are four rear sections included; blown and unblown, with different parts for closed and open options. Two propellers are included as well, although only one is needed for the included options.
Decal options are provided for a generous five aircraft:
  • Fw 190F8 5./SG 77, Cottbus, Germany, early 1945. This aircraft is finished in RLM 74/75 over RLM 76;
  • Fw 190F8 SG 2, Hungary, late 1944/early 1945. This aircraft is finished in a similar scheme, but with a temporary winter whitewash and a red cowling ring;
  • Fw 190F8 1./SG 4, Piacenza Air Base, Italy, 1944. This aircraft is finished in RLM 79/80 over RLM 76;
  • Fw 190F8 W.Nr. 584592, SG 2 or SG 10, Nuremburg, Germany, May 1945. Finished in RLM 81/83 over RLM 76; and
  • Fw 190F8 SG 10, Ceske Budejovice, Czechoslovakia, May 1945. Finished in RLM 83 over RLM 76.
Each option is illustrated with a four-view profile as well as detailed illustrations of the propellers or drop tanks where appropriate. The decals, which are printed by Eduard, look crisp, thin and glossy and the colours used are nice and bold.
Conclusion
While it may be a fairly uninspired choice of subject, there's no denying that Eduard have delivered the definitive kit of the Fw190, as well as providing a prime example of the kit maker's art. The level of detail they have packed in is as superb as the engineering is excellent, and the kit appears to be accurate in every major way. Overall this is a winning package and can be highly recommended.
Review sample courtesy of
6 people like this
Nice review Paul, I have some but have never looked in the box (that's an indication of how low my Mojo has got rather than lack of interest in the kit though).
Duncan B
Many thanks.
May I suggest insertion of a straight link toward the instruction sheet pdf for all Ed's kits reviews?
Like this?
2 people like this
On 12/18/2016 at 08:47, Antoine said:
Many thanks.
Like this?
The Buy It Now link goes directly to Eduard's website, and from there it is only one more click to the pdf instructions,
Julien
I seriously hope Eduard make this kit with the schemes in 1:48. I will buy it in a heartbeat.
All the options above are already with the 1/48 Profipack box, with only a different aircraft from SG4, red 10 instead of white 1.
1 person likes this
Eduards Fw 190 is a real gem, especially with these interesting markings. But did i miss something ?
The kit in the box is more an A-8 with more ordnance and decals for the F-8, thanks to the molded on ejection chutes for the outboard wing gun stations, found on the A-6 to the A-9, so some sanding is needed.
Followers 0
