petr@SpecialHobby Posted December 13, 2016 Share Posted December 13, 2016 Special Hobby is pleased to announce their new and top-quality take on the iconic French cold war jet fighter, the Super Mystere B.2 plane, in both the original French version and the improved Israeli with ex-A4 Skyhawk engine and longer rear section installed in order to avoid or at least minimize the damage by enemy´s anti-aircraft missiles. You are welcomed to visit our blog to see more rendered pictures of the 3D design. http://www.specialhobby.info/2016/11/we-are-preparing-smb-2-super-mystere-172.html 2 Link to comment Share on other sites More sharing options...
petr@SpecialHobby Posted December 13, 2016 Author Share Posted December 13, 2016 Yet couple more computer rendered images: Link to comment Share on other sites More sharing options...
petr@SpecialHobby Posted December 13, 2016 Author Share Posted December 13, 2016 Link to comment Share on other sites More sharing options...
Mike Posted December 13, 2016 Share Posted December 13, 2016 Looks great - is the top rear section of the intake trunking removed just for visibility to show the engine face off? I'd like to think that will keep Homebee quiet for a while, but now he'll just hassle you for the release date! Link to comment Share on other sites More sharing options...
petr@SpecialHobby Posted December 13, 2016 Author Share Posted December 13, 2016 (edited) Thanks Mike. The trunking section in question will not be comprised in the kit as it would not be visible from any angle through the nose air intake part anyway. Edited December 13, 2016 by petr@SpecialHobby 1 Link to comment Share on other sites More sharing options...
Mike Posted December 13, 2016 Share Posted December 13, 2016 Understood, thanks for the info Link to comment Share on other sites More sharing options...
Jon Kunac-Tabinor Posted December 13, 2016 Share Posted December 13, 2016 Just for one, small, bright, shining moment, I though this was 1/48th scale..... Alas not. But - it looks fantastic. Jonners, dreaming of quarter scale Petit Sabres Link to comment Share on other sites More sharing options...
petr@SpecialHobby Posted December 13, 2016 Author Share Posted December 13, 2016 Will be, and more detailed, see another topic (although sans rendered images, to be added later). Link to comment Share on other sites More sharing options...
RidgeRunner Posted December 16, 2016 Share Posted December 16, 2016 Very nice, and announced just as I am about to cement the two fuselage halves of my latest build, a SMB2 Sa'ar, I'm just finishing my Emhar Fury but no sign of a new moulding from anyone :(.... Martin Link to comment Share on other sites More sharing options...
RidgeRunner Posted December 16, 2016 Share Posted December 16, 2016 (edited) Petre, will it it come with a full set of underwing stores, including those for the Sa'ar? And a MB seat for a Honduran machine? martin Edited December 16, 2016 by RidgeRunner Link to comment Share on other sites More sharing options...
Antoine Posted December 16, 2016 Share Posted December 16, 2016 (edited) On 13/12/2016 at 11:36 AM, petr@SpecialHobby said: Special Hobby is pleased to announce their new and top-quality take on the iconic French cold war jet fighter, the Super Mystere B.2 plane, in both the original French version and the improved Israeli with ex-A4 Skyhawk engine and longer rear section installed in order to avoid or at least minimize the damage by enemy´s anti-aircraft missiles. Well, this is not 100% true. The PW J-52 was indeed the same engine used for the Skyhawk, but why ex-skyhawk? The main reason behind the upgrade was the end of the French Era for the IDF, and therefore the end of technical support. J-52 did fit the bill to replace the ATAR, and I don't believe the rule was to use ex-skyhawk engines, as new one were available. The longer fuselage was just needed to fit the J-52 (with 300kg less than the ATAR) to keep the CG in the same place, and the fact that the longer exhaust gave the aircraft a better chance against a SAM was only an added bonus discovered much later, and then only with IR missiles. Out of 25 SMB2 available at the beginning of the war october war of 1973, only(!) six were lost, but some survived an IR missile hit thanks to the longer exhaust. This is why the Skyhawk underwent a crash program to get the modification done, as they were suffering very high losses. If this had been known before, then the mod would have been made much early. Edited December 16, 2016 by Antoine Link to comment Share on other sites More sharing options...
petr@SpecialHobby Posted December 16, 2016 Author Share Posted December 16, 2016 Martin, Yep, we definitely plan to equip the model with all the stuff you have mentioned. We are happy to be able to collaborate on this project both with colleagues from Israel where the Sa´ar machine is preserved in their museum and also with some guys from France. Got already much help from them for which we are very thankful. Link to comment Share on other sites More sharing options...
cvrle Posted December 16, 2016 Share Posted December 16, 2016 Wonderful news! Now, could you be persuaded to put in codes for ones flown by Tanguy and Laverdure? (very well known french comic book with two pilots as heroes) Cheers! Link to comment Share on other sites More sharing options...
Antoine Posted December 16, 2016 Share Posted December 16, 2016 10 hours ago, Antoine said: Well, this is not 100% true. The PW J-52 was indeed the same engine used for the Skyhawk, but why ex-skyhawk? The main reason behind the upgrade was the end of the French Era for the IDF, and therefore the end of technical support. J-52 did fit the bill to replace the ATAR, and I don't believe the rule was to use ex-skyhawk engines, as new one were available. The longer fuselage was just needed to fit the J-52 (with 300kg less than the ATAR) to keep the CG in the same place, and the fact that the longer exhaust gave the aircraft a better chance against a SAM was only an added bonus discovered much later, and then only with IR missiles. Out of 25 SMB2 available at the beginning of the war october war of 1973, only(!) six were lost, but some survived an IR missile hit thanks to the longer exhaust. This is why the Skyhawk underwent a crash program to get the modification done, as they were suffering very high losses. If this had been known before, then the mod would have been made much early. Forgot to say: I'm Happy!!!! Link to comment Share on other sites More sharing options...
TEMPESTMK5 Posted May 3, 2017 Share Posted May 3, 2017 Good morning Petr Any news on this model ? Patrice Link to comment Share on other sites More sharing options...
petr@SpecialHobby Posted May 11, 2017 Author Share Posted May 11, 2017 Don’t worry Patrice, we will keep you updated here, stay tuned. 1 Link to comment Share on other sites More sharing options...
petr@SpecialHobby Posted April 26, 2018 Author Share Posted April 26, 2018 First look at the test shot sprues: http://www.specialhobby.info/2018/03/172-super-mystere-progress-report-first.html internal details revealed: http://www.specialhobby.info/2018/03/172-super-mystere-first-testshot-trial.html Link to comment Share on other sites More sharing options...
petr@SpecialHobby Posted April 26, 2018 Author Share Posted April 26, 2018 And finally, a completed model built using the first test shots: http://www.specialhobby.info/2018/04/sh72345-super-mystere-smb2-saar-built.html Link to comment Share on other sites More sharing options...
petr@SpecialHobby Posted April 26, 2018 Author Share Posted April 26, 2018 French reboxing for Azur Frrom shown: http://www.specialhobby.info/2018/04/azur-frrom-fr0035-super-mystere-boxart.html 1 Link to comment Share on other sites More sharing options...
