Welcome to Britmodeller.com
Register now to gain access to all of our features. Once registered and logged in, you will be able to contribute to this site by submitting your own content or replying to existing content. You'll be able to customize your profile, receive reputation points as a reward for submitting content, while also communicating with other members via your own private inbox, plus much more! This message will be removed once you have signed in.
  • Announcements
    • Mike
      Switched Identities   18/06/17
      If you are still having problems logging in and remaining under your own username following the DDoS attack last week, you need to log off, clear your browser's cache, and restart your browser to ensure you clear all the old files from your temporary area.  Then you should be sorted.
Sprueloose
1/48 Trumpeter Westland Whirlwind
207 posts in this topic
Can I just second what Martian said...?!
Good to see the Crikey back underway Terry!
Keith
Thanks Martian and Keith for the kind words and support. I seem to be at a bit of a low point, struggling to get over a hump and move on!
So... back at the bench and after a couple of days of sanding and filling I managed to knock off one of the Fowler flap guides that protrude at the aft end of the flaps.. this makes about the third time that I have managed to remove one of them. They have been replaced at least twice with carved sprew... Sigh..
What I decided that I have learned from this experience, is one, I should seriously consider replacing all of these protruding bits with brass firmly anchored to the airframe. Like I have done with the pitot tube and antenna mast, and two... that my work space was way too cluttered and that added to my problems..
I admit to being rather a messy creator, (you should see the inside of my head!) but I am starting to see the benefits of have room to swing a cat! (without knocking off the sticky-out bits!)
So as a general first step in the campaign to ORGANIZE MY WORKSPACE, I decided to build a set of shelves for the paint and other jars of stuff.
Scrounging some peg board and slats of various woods I set to work.
Room is at a premium in my shop that does double duty as a woodshop (god help me when I start painting the crikey!), so I tried to fit the shelving into the existing space. A couple of coats of paint ,( the weather has improved), and here I am today... Doesn't that work space look lovely... Like Paul Budzik's! HA!
Of course now I have to clutter it up with all the stuff that was there before and is now on the table saw!
So that is what I have been doing .... model avoidance on a large though thoroughly rationalized scale!...
But I did build something! (felt good!)
I think that I needed to take a bit of a breather in the build and gain some perspective... It's not going to be perfect... but that's is not the point!!! I will see if I can keep my eye on the prize and soldier on!
Thanks for your patience and understanding!
Terry
I forgot to add that it felt so good to do some work today that I treated myself to:
I usually lean toward stouts and porters, but one of our local brewers has come out with a pilsner that is quite tasty. A little hoppy but you can get away from hops and live in the Northwest!..
Cheers you guys,
Hope your modeling is progressing nicely!
5 people like this
I like the idea for making the most of your workspace, however you have forgotten one of the unavoidable laws of modelling. This is that mess will expand exponentially in respect to the space available. I wonder how I know this?
Martian the Messy
1 person likes this
The first pic of your bench looks like both of mine Terry! Yes,I'm lucky enough to have two, one upstairs & one down - both equally messy and cluttered!
Keith
So after breaking off the flap guide once again.... I decided to replace them with brass...
Sculpted the guide in brass rod:
And then soldered a bit of brass sheet to the end hidden inside the wing:
Cleaned up the over-solder and did a bit more sculpting:
Glued in place with epoxy:
I'll let the epoxy cure over night and then clean it up a bit...
Thanks Martian for the sage advice.. too true.. like my basement.. the clutter does grow to fill the available space...
Keith, I am glad to know that there are others out there who work in a "messy" environment.. Reminds me of an old carton, where a scientist is showing someone around his lab and the gentleman comments on the mess. The scientist says "If you think this is bad you should see the inside of my head!"
Terry
3 people like this
It sounds exactly like me as a great many Britmodellers will attest.
It looks like those flap guides aren't going anywhere soon; good work.
Martian of the Messy Head
Lovely progress and workmanship, great solution with the flap track fairing.
Loving the shed layout as well.
