HMS X-Craft
beefy66
While waiting for the base to dry on my USS Independence build I thought I would start a quick build OOB by doing this Merit X-Craft submarine
So started reading a few reviews and other builds and got the Eduard PE sheet for this MM(Quick I thought but knowing me this will take a bit longer
had already built up most of the hull when I realised that the drain holes and other things needed to be drilled out so here goes  :blink:
taking my time which is unusual for me used a 0.5 drill and scalpel to clean and cut out then a flat blade thin file will start on the holes that you can see around the hull now
Beefy
Quote
6 hours ago, whitestar12chris said:
Have fun Beefy, just a word of caution the early X-craft had a two tone scheme, not all over black.
All the best Chris
Hi Chris thanks for the heads up been doing a bit of research on the net and also found some that are just an all over dark grey so something to think about  :unsure:
If I go for the Black it will not show a lot of the details but a Grey would allow me to use some better washes to bring out the details I hope  ;)
Anyway it is back to the hole drilling for now  :blink:
Beefy
Small update started adding the PE after drilling out all the holes around the hull
Also filled in the holes that will not be needed for the port side rudder linkage
Beefy
Well all to myself today for a change and got some good time in at the bench more PE added and the starboard rubber linkage fitted I have left the lower part of the rubber off so that the screw can be fitted after painting.
Beefy
  • 3 weeks later...
Well now that I have got one other build out of the way it is back to this more PE added and now onto the locking devices for the side charges
And trying out the new roller tool for the Snorkel top
Trying to get this done before the party's and family visits start off work now for 2 weeks so should be getting more bench time  :yahoo:
Beefy
Quote
On 12/22/2016 at 2:04 PM, robgizlu said:
Beefy- that is looking really special, the problem with time off is that bench time never seems to actually materialise.
Keep it coming
Rob
Thanks Rob my time at the bench this holidays is all planned into the timetable not making the same mistake as other years need my own time to help chill out so to speak  B)
All the construction done added some braided fishing line to the side charge locking device think that what they are anyway
Then started painting the propeller have to confess I made a right balls up of the kit one so will be using a one from the MTB that I did not use on that  :unsure:
Then with my punch set made the joining pipe from the hull to the snorkel
Then attached a block of wood to the hull for handling when painting
and hear are the paints that I will use flat black and Panzer grey over a coat of Halfords primer
Just for Kayell cos he mentioned that I had stopped putting the paints behind my models during the WIP
Beefy
I thought this was going to be an easy simple build !
Looks like you have it well under control
Congratulations on new metallic paint sponsor.... lol
Merry Christmas to yo and your clan
Keith
Quote
3 hours ago, Gremlin56 said:
Looking very good Keith, tiny thing for a 3 man crew though isn't it............
Even smaller than you think Julian these things had a 4 man crew even at 15 meters long only 1.75 meters wide that would have been a real cramped little tube
So no sprouts on the dinner menu for those boys  :sick:
Will be putting the first coat of black primer on today and making a start on the figure I have for this from Wee Freinds
Beefy
Quote
23 hours ago, longshanks said:
Looking a bit like a Zebra.........
but I'm sure the washes will pull it all together
Kev
Yes the light shining through the window does bring out the lighter colors
Added the propeller and periscope also added the last part of the rubber
main part of the figure painted but not sure what head to add I have one with a tin helmet and one with a beret  :book:  and suggestions
Beefy
Quote
8 minutes ago, longshanks said:
Beret for my money.
Standing on top of a tin of beans I don't imagine the helmet is going to inspire any more confidence.....
Kev
Beret it is then did not think the tin hat looked quite right  :book:
Beefy
