Epimedium Posted November 19, 2016 Share Posted November 19, 2016 Just started this one, picked it up at Telford for £12! I hope to post up the progress although it may be slow, never actually rigged a 1/72 biplane so why not start at the deep end 😬 Started with the two engines, found them fiddly due to the fact tamiya cement wouldn't react in its usual manner, so I may switch to revell or humbrol. The kits seems relatively simple (famous last words) and I hope to keep the wings separate for painting as the dazzle options are quite complex, I'm also hoping to rig the main wings before attaching them. Everything does look a bit flashy and bulky, especially the canopy but it should all be fine once it comes together as a completed model. thanks Jason 4 Link to comment Share on other sites More sharing options...
Brandy Posted November 20, 2016 Share Posted November 20, 2016 (edited) Wow, talk about in at the deep end! I have this one (and the Curtis version) in my stash but I'm not at home right now so can't check the assembly....I wouldn't recommend rigging the wings before fitting them unless you have a good jig and they are very sturdy - the fuselage adds a lot of strength! I did it that way on my Short 184 build but only because I built it wings folded and had no other option....it was a nightmare, and I only build WWI....... Ian Edited November 20, 2016 by limeypilot Link to comment Share on other sites More sharing options...
Ed Russell Posted November 20, 2016 Share Posted November 20, 2016 Hi Epimedium - Fully constructing and rigging the wings will certainly work as this WIP picture shows.... I'm sure yours will look similar. I used the dazzle pattern as shown on the box top and, like you, thought it was easier to paint both halves separately. I wouldn't call it an easy build but it was satisfying to complete it. I shall follow your build with interest. 2 Link to comment Share on other sites More sharing options...
Derek A Posted November 20, 2016 Share Posted November 20, 2016 That's a lot of rigging! Looking really good so far. 1 Link to comment Share on other sites More sharing options...
Planebuilder62 Posted November 20, 2016 Share Posted November 20, 2016 Dear Jason Good luck building yours. When I built mine it took me a couple of tries to get the top wing on due to the engine mounting struts being slightly misaligned. I don't know how much rigging experience you have but rigging my Felixstowe taught me patience. By the way do you have the Aims squirmy decal set? Regards Toby 1 Link to comment Share on other sites More sharing options...
Epimedium Posted November 20, 2016 Author Share Posted November 20, 2016 1 hour ago, Sofusthecat said: By the way do you have the Aims squirmy decal set? Regards Toby I did look at that and was going to go that route but when I looked it seemed the pattern was quite irregular so I figured I could do the same with masking and I like the look of the blue version. the wings look like they are sturdy as they are a separate piece but I'm not liking the look of how they join to the fuselage, seems a little vague, although I haven't study that part of construction yet. also concerning rigging I have Uschi fine and superfine (the latter being for this one) I've only used ez line before so is this similar in habit. I'm also not planning to use buckles as in the scale I can't see that they'd be visible. Any help and info is greatly appreciated. Link to comment Share on other sites More sharing options...
Ed Russell Posted November 20, 2016 Share Posted November 20, 2016 With these sort of patterns you don't really need a mask set. It's pretty easy to do it like this............. 4 Link to comment Share on other sites More sharing options...
TheBaron Posted November 20, 2016 Share Posted November 20, 2016 I've been eyeing one of these up for a while but thankfully now I get to watch you trial it before I make a decision. Very best of luck Epimedium! (Let me know if you need any rigging diagrams or interior shots as I think I've both tucked away on file). Great to see this Tony Link to comment Share on other sites More sharing options...
Squibby Posted November 20, 2016 Share Posted November 20, 2016 Really cool looking paint scheme you're going for there. Looking forward to seeing it unfold. Link to comment Share on other sites More sharing options...
Epimedium Posted November 20, 2016 Author Share Posted November 20, 2016 13 minutes ago, TheBaron said: I've been eyeing one of these up for a while but thankfully now I get to watch you trial it before I make a decision. Very best of luck Epimedium! (Let me know if you need any rigging diagrams or interior shots as I think I've both tucked away on file). Great to see this Tony Hi tony any info would be greatly appreciated as I'm going by what I can find on google! 19 minutes ago, Ed Russell said: With these sort of patterns you don't really need a mask set. It's pretty easy to do it like this............. This is what I thought as they're not perfect curves etc so it'll be easier to cut with artistic license. Have you got a link to your completed one it would be good to see it. thanks Link to comment Share on other sites More sharing options...
Epimedium Posted November 20, 2016 Author Share Posted November 20, 2016 A little progress, I finished one engine and then decided to press on with the wings and fuselage as the fitting is a little vague so I'd prefer a dry fit instead of hoping it'll all line up, which I can see it clearly wouldn't. There are no locating pins for any of the joints so I'm giving it plenty of drying time. 2 Link to comment Share on other sites More sharing options...
Brandy Posted November 20, 2016 Share Posted November 20, 2016 Those engines look great! This link to WnW should prove useful for details such as rigging diagrams... http://www.wingnutwings.com/ww/product?productid=3116 Ian Link to comment Share on other sites More sharing options...
TheBaron Posted November 20, 2016 Share Posted November 20, 2016 11 hours ago, Epimedium said: Hi tony any info would be greatly appreciated as I'm going by what I can find on google! PM sent. Link to comment Share on other sites More sharing options...
TallBlondJohn Posted November 20, 2016 Share Posted November 20, 2016 Wow, good luck with this one. I have it (and the swirly decals) in the stash for a rainy day when I have lost all reason. I have heard worrying tales of woe about the engine mounting struts, apparently the instructions are completely misleading. Recommend you google other builds. Link to comment Share on other sites More sharing options...
