DDELK Posted November 17, 2016 Share Posted November 17, 2016 Was thinking about tackling this kit but wanted to get some opinions.. I heard that the intakes don't have the greatest fit and just wanted to see if anyone else has done this build and get their opinions.. thanks dave Link to comment Share on other sites More sharing options...
madcat911 Posted November 18, 2016 Share Posted November 18, 2016 I completed a build of this kit recently. Link to RFI thread below. Made some comments about the kit further down in the thread. Hope this is of help! Mark Link to comment Share on other sites More sharing options...
Bobski Posted November 18, 2016 Share Posted November 18, 2016 It takes quite a bit of patience to build as the fit isn't great and the plastic is a bit gash too, but the effort pays off in the end. The intakes in particular are difficult to get right and will need a healthy dose of filler to sort out the various gaps. I've also had problems with the lower wings on every Typhoon that I've built. Other things to watch out for are the instrument panel (it doesn't fit properly to the moulded glare-shield when installing the cockpit so you end up with a step) and the airbrake. If you want to close the airbrake then your best bet is to completely remove the recessed 'floor' on the upper fuselage that forms the airbrake bay. Link to comment Share on other sites More sharing options...
lordstrpe Posted November 18, 2016 Share Posted November 18, 2016 Is the new kit out with the bright tiger livery just a reboxing of the last one revell released? Link to comment Share on other sites More sharing options...
Stephen Posted November 18, 2016 Share Posted November 18, 2016 26 minutes ago, lordstrpe said: Is the new kit out with the bright tiger livery just a reboxing of the last one revell released? Yes, There is only the tiger livery as the decal option. Link to comment Share on other sites More sharing options...
Fido996 Posted November 18, 2016 Share Posted November 18, 2016 I'm currently getting to grips with this kit, it's a bit of a mixed bag. I have planned to scratch build an intake cover so I didn't have to deal with the intakes. The instrument panel and glare panel do need some work, but it's nothing too drastic. The rest of the kit goes together fairly well, I've had no real problems with it. I'm at the painting stage now. The entire surface was polished, primed and then polished again to an almost mirror finish. The final touch ups were done earlier and a couple of coats of my varnish mix were sprayed on. This is now drying off and hardening before the decals and weathering are applied. It's the Seek/ Destroy 41sqn bird. Well, hopefully anyway! 1 Link to comment Share on other sites More sharing options...
