Mike Posted November 13, 2016 Share Posted November 13, 2016 Harrier GR.7/9 (648384for Hasegawa) 1:48 Eduard Brassin The Hasegawa Harriers are well-respected kits, but as moulding technology moves on, there are areas that start to look a little below-par, and coupled with the paucity of weapons in the box, a lot of modellers like to make some upgrades to the basic kit when building. Eduard have a number of sets available for this kit, and they have now released this set that contains a number of them, concentrating their efforts on the most obvious areas. The set arrives in the familiar Brassin rectangular profile box, with the resin parts safely cocooned on dark grey foam inserts, and the instructions assisting Exhaust Nozzles - Four resin nozzles, which are direct replacements for the two part kit nozzles, so not only do you avoid having to fill the seams, but you also get a much better level of detail into the bargain. Sniper ATP - Harrier used this target designation pod extensively, and this set contains all the necessary parts with the adapter rail that is required for attachment to the Harrier. The main body is cut from its pouring plug and the join is covered by a PE part, with an optional "black box" on the aft end, while the movable seeker head and PE lens is fitted into the recess in the front. Then the glazing parts in clear resin are prepared by adding a bevel to their edges as shown in the accompanying diagram, before gluing to the lip around the edges of the window. The adapter rail, sway-braces and pylon are fixed to the top of the pod body, with some small PE parts providing extra detail, and decals supplied for the stencils. If you wanted to pose the pod in its deployed mode, simply turn the seeker head windows to the downward position using your references. TERMA Pod – this defence pod isn't exclusively used by the Harrier, so it has uses with other aircraft, but it is carried by it, so it has been included here, and consists of two resin parts and a small fret of pre-painted PE. The pod is liberated from its casting blocks, then glued together to form the pod body. The PE parts are then affixed to the exterior, which is best done after main painting is completed due to them being pre-printed. Ejection Seat – a complete resin seat with cushions, plus PE belts and other details, plus a small number of stencils. Wheels - The landing gear of the Harrier is described as bicycle-style, with a single nose wheel and large twin tail wheel, both of which resin parts , as are the little stabiliser wheels half-way along the wing with detailed resin yokes and tyres added. Conclusion A great set that is pretty much a one-stop box for anyone needing to upgrade their Hasegawa Harrier. After installation and sympathetic painting, the difference will be plain to see. Very highly recommended. Review sample courtesy of 1 Link to comment Share on other sites More sharing options...
LaurieS Posted December 13, 2016 Share Posted December 13, 2016 Great info Mike. Just starting the Mk7. Afghanistan RAF livery. Laurie Link to comment Share on other sites More sharing options...
