Welcome to Britmodeller.com
Register now to gain access to all of our features. Once registered and logged in, you will be able to contribute to this site by submitting your own content or replying to existing content. You'll be able to customize your profile, receive reputation points as a reward for submitting content, while also communicating with other members via your own private inbox, plus much more! This message will be removed once you have signed in.
  • Announcements
    • Mike
      Switched Identities   18/06/17
      If you are still having problems logging in and remaining under your own username following the DDoS attack last week, you need to log off, clear your browser's cache, and restart your browser to ensure you clear all the old files from your temporary area.  Then you should be sorted.
bootneck
are there 'good' and bad CA superglues?
34 posts in this topic
Yep, you mentioned it earlier, I see no need for it for myself.
Edited by Digger1895
When you get to attempt some intricate parts with different materials it is a boon.
Rigging with approx 50 ends to fix with the minimum of C/A then you wish you had it.
Another fellow model maker appealed for help with rigging about to give up. Mentioned
the pen. Came back later having had 100% success using the pan.
Also works by using liquid accelerator but the pen is much more convenient with its felt tip.
I mentioned it again, for those who may be interested, as the first  I did not have the on
line address for those who may be interested. QED
Laurie
Whilst not superglue, I have tried the new Lazerbond seen advertised on TV recently.  It is quite sticky and will grab and hold small PE parts and sets only when you expose it to the built in UV light.  It will fill gaps,drys clear and is sandable.  Use a cocktail stick or similar to better control application of small ammounts.  All in all I recomend it, it's saved my bacon a couple of times with parts I was having trouble sticking with the more traditional suuperglue.
1 person likes this
Thanks Derek, but Amazon dont ship to SA. I found it locally at ZAR 70.00 a tube, but ZAR 121 for delivery.
Ouch, I do hate it when the P&P is more than the item!  Without wanting to teach granny to suck the proverbial egg, have you tried searching for something more generic like UV activated glue or plastic?
Edited by Derek A
Added text
ive had good results with vitalbond CA, it comes in various viscosities and so far has stuck pretty much anything I've tried it on, from the millennium falcon partwork mainly resin bits and bobs, plasticard and a white metal cooking range for the other halfs dolls house
