Two steps forward, one step back. The MLG and tail wheel are on:
80F232F0-D903-47DC-97E6-9A0F92CF4D69_zps
C190DF08-A9C6-4017-BD95-2EA8641CADB3_zps
7034B2DF-DF91-4DEE-9BB9-A5E0CE723B5D_zps
The fuselage camouflage wasn't sitting right with me so I resprayed and masked the RLM 78 and 79. I alluded to using tape to mask the markings. These pieces are more of a "rough guide" just to give me a reference when I re-shoot the RLM 80:
5E607F8D-2A9F-45A8-A10C-0E2F4EAC0407_zps
9F452070-FA9D-4CA1-91A3-62C081170C0E_zps
The prop is completed as are the MLG wheels. The slats have been repositioned to their final resting places:
93DFED41-8075-45F1-8740-C5FB21559A9C_zps
1992B470-EAFC-4C39-9ACB-95422834EEF8_zps
4BA451C2-631E-4354-A09E-67BCB7232BAA_zps
F09DFE05-2F61-400C-AD59-1A975F01BFF1_zps
I have also also repaired the tail antenna mast which was damaged somewhere along the way:
54F0CBB5-EBA6-4143-879F-C241F1130F3C_zps
86F0964C-88F4-4DAA-91BA-2CDFC1BAA3C4_zps
Once I am happy with the RLM 80, everything including sub assemblies will get a gloss coat for decals and washes. This outburst of OCD probably means I will miss the end date for the GB, as I honestly don't see much benchtime in the next 48 hours, being Christmas and all. Probably the only real hope I have is if the mods declare an extension.  🙏 We shall see!
Regards,
Happy 2017 one and all,
I think I have FINALLY got the RLM 80 splotches to the point I am happy with it! Moving on has been bits and pieces in preparation for the gloss coat. I have detailed the MG17 gun bay and a test fit of the MG 17 showed the port one was fine but the starboard one would not seat properly, being about 1 mm too far forward. The rear end of the MG fouls the instrument covering and I will need to carve a "groove" or fold in the material to allow the MG to sit properly:
809892B6-CF48-4046-9070-5E34990AF7FB_zps
333C6A6F-3212-4F4C-B391-05FBEFB8C5AC_zps
3B32FC37-A14C-4997-A640-ADE5B51B7DD0_zps
The splotches of what I take to be RLM 63 light grey on either side of the fuselage have also been added:
14C697BB-BB48-43E1-AAF1-A58BF4FDA3F3_zps
5C750EE5-0B95-4BC8-8A2B-2E45C4DB9BEE_zps
My attention then turned to the underside, with the PE radiator and oil cooler flaps added their respective positions:
06583701-5225-4E15-890B-F4EE5676B91A_zps
The rudder control wires and guide horns, horizontal stabilisers and supports were added in that order and fixed in position after ensuring they were true:
0350CB7C-635A-4DD5-A916-61DDF161480C_zps
7594B626-7492-4A78-9071-B5C7FD06FFC2_zps
EF9BB86F-DA55-41E2-8AFC-E44A787B562B_zps
Lastly, the MGFF barrels were inserted in their openings and set to their correct protruding length using the handy scale plan that comes in the Master Barrel set. The antenna mast was then set into position atop the rear cockpit:
C5E154DB-CE65-4E32-886A-8C8C29F98766_zps
59FF5123-76B1-42B6-9F7E-53E1F09D7534_zps
Now I think I am ready for gloss coating!
Regards,
Thanks lads,
A pity I was late to the finish but still progressing. 99% of the stencils applied. I still have to paint the red trim tabs and add their stencils. As the aircraft were repainted for the MTO, I have not added the red no walk lines on the wings, as they do not appear in photos of MTO 109's that I have seen, but the "nicht betreten" stencils may or may not have been repainted:
FD441D8C-659C-42FE-AD5D-AA7520B3E97B_zps
793AFEC8-721C-4153-8F29-2C3AE790A108_zps
F01230A8-6D4E-4CE4-A678-63A4B937F504_zps
19E0367B-70E9-4DBE-9870-68A4FF8333D3_zps
6661F43B-98A9-45BD-99CD-E002114815A6_zps
The removed panels have had the "Zu" marking added. These will be open and some CMK PE latches employed to portray the latches. The material inside the latch points will be removed so the red lines will still be on either side:
1103187F-E967-4078-BEF1-D1A655659C57_zps
Fuel tank and propellor markings:
CF71977F-4852-42D9-B9A6-18C7AD787412_zps
27063AE2-EC89-4544-AB5B-1F24D9BA2C4B_zps
77AD820C-0BCD-4C0F-9258-43208F6CA491_zps
I have started looking more closely at the engine. The spark plug cables have a solid piece where they should be open. I have drilled the greater part of the gap (I will have to replace a couple of wires). I may just bite the bullet, remove them all and use lead wire:
15556597-6BD3-456B-9E0E-DF0948304C68_zps
E31D26F6-6714-452F-BDFF-1632CC0475BB_zps
All the decals performed perfectly, laying down with minimal fuss and bother (not of my own making).
Thanks for looking and Regards,
3 hours ago, Calum said:
Looking good Kent. Really attractive scheme
Thanks matey,
I have replaced the broken off spark plug cables and guess what? I am tempted to replace them all. Curse this AMS!
Photos later.
Regards,
Still progressing. The starboard MG 17 was too long when fitted into its cradle, well to be more correct the forward IP cover was too far forward. A little surgery on the resin in an attempt to make it look like a fold in the leather:
AD12A5E8-FA71-415E-A5EC-B45CA101DCAC_zps
D5D421F4-6277-4FE7-B7F6-B17F171B73E4_zps
And finally the last stencils added to the trim tabs:
0A732EEA-0D4D-447C-93C8-BFC25DB5F1F2_zps
I shall touch up the IP cover and then proceed with weathering the airframe.
Regards,
So, the IP cover has been touched up with MM Leather enamel and the starboard fuselage MG 17 is sorted and fixed into position. The gun bay wiring was repainted RLM 63 Lichtgrau, after my references showed the yellow to be incorrect. The forward securing mechanism half way along the barrel is made from a sliver of BMF and PE. It took me the best part of an hour to wrangle the two sets into creation for each MG. This brings me to the port MG. Whilst attempting to fix it into position it fell into the interior of the fuselage, through the hole near the base of the ammunition canisters. I heard it rattle, then the small amount of CA that was on it stuck to something inside and it remains unobtainable. Luckily this was to be a maintenance vignette!
21871408-6D65-46DE-A68D-FCF805365F51_zps
AD07AD1A-54D1-49C9-B6C4-62423BBA57EE_zps
55738029-94BC-4BD6-8834-83D9B0F9A08F_zps
7081E1C9-9CC6-4EC7-9A40-7B861B67D635_zps
Regards,
Welcome back to those still following on!
 Celebrating the kids being back at school with some bench time! The upper areas have had a coat of Flory light dirt (being in the desert). Not too bad a result and some areas (such as oil leaks) will get a darker treatment:
78B20196-1342-4915-A526-75F30B063BCB_zps
2897C8F9-143E-4DE2-B628-903955DEA776_zps
A74B8A6F-7FB3-4BAB-A143-33847BE1CFD2_zps
3A7478A2-E68E-4629-845C-13275BFA0D52_zps
The underside will get its light dirt and some missing PE pieces. The engine is coming along, main colours and some more bits added to it. The replaced spark plug leads do look better but I am also pleased with the non replaced items, carefully painted, they should look okay once the engine is installed. The holes have been drilled to accept more plumbing at a later date:
730B1725-2954-40CF-8233-76E64CCCB050_zps
8FA6EDED-96C1-4619-A3B1-8D82577AB2AF_zps
AEF82E6F-529F-4C51-AF2A-3D8D70626068_zps
98440245-DF9A-40E8-8988-50E30552D12C_zps
Regards,
I've been watching this one, I've decals to do the same aircraft in 1/72, they were an option on the old Airfix 109E at one point but an earlier scheme, I like this one so much more & like what you're doing with it. :)
Steve.
Hello Mods,
As this one is now so far behind schedule, with still a fair way to go, it might pay to move it to a WIP thread if you think it more suitable?
As I said, some slow progress. The aircraft has now had its Flory light dirt wash applied and removed. AK Interactive Ultra Matte Varnish for a protective top coat. I may have used a little too much thinner and defeated the dullness, so another light coat of less thinned is probably on the cards. The MLG oleos have had their BMF coverings, PE retraction struts and the wheels added. The BMF will be toned down a bit with some dust:
62317D1B-87CB-41C2-BDD7-F9AF3023EDC4_zps
6865BA7A-EF28-4967-BE1B-BD8CE17981D4_zps
0183FD5C-2074-47A9-B0F2-BDB0FB9D340A_zps
D76A37D1-CFAC-4E76-84FA-524044D1ED10_zps
B0138807-6EF3-4C2A-BB91-CDC5FBE19242_zps
ACA58707-0402-40B3-83F0-6F6243396F77_zps
AFC81A56-C44F-4837-B17C-7CCAD9E32F98_zps
87A71A71-D08D-44E5-8960-B32F543FCA1A_zps
The MLG angles look right from all directions so I am happy with the setup. Brake lines and MLG covers to go followed by some more lower area dirt.
Regards,
