1/48 Hawker Typhoon 1b, 175 Sqn, Schleswig, Germany 1945. After 4 years its finished!
Hi everyone
Last weekend I had some time off from work so I decided to clean out and remodel my workshop....
....and in doing so I found a plane I started 3 years ago the Hasegawa 1/48 Hawker Typhoon 1b which as the title says will be built as MP197 using the rather lovely decals from Aviaeology AOD48003 Typhoon Special.
At the time I had the Barracuda cast cockpit upgrade.....
...which in my opinion looks lovely, its just a shame most of it will never be seen again! Oh and for those observant amongst you you would have noticed the head armour is missing, I broke it off many moons ago but I still have it and I'll reattached it nearer the end of the build.
General model pictures.....
....my 1/24 version is still on going but it is my long build so I need smaller stuff to keep me sane!
  • Like 9
3 minutes ago, Spookytooth said:
A nice and tidy bench there sir.
A place for everything and everything in it`s place.
The Tiffie looks great, looking forward to seeing more.
Simon.
Hey Simon
Ha ha, believe me I'm not tidy by nature so it wont stay tidy for long! Yeah the Hasagawa Tiffie is a nice bit of moulding and it really does look the part.
I don't know why I put it to one side all those years ago? Still I'll get her finished now!
Iain
Where there slightly different boxings of the Has 1/48 Typhoon?  I have one working its way to the top of the stash (after the Sea Gladiator and the Sandringham conversion)  but I think it has the early tailplane and three bladed prop..
Do you need to fill the landing light for this airframe?
Hi everyone
Well it seems like I've been away from modelling since, well forever. I've recently changed jobs so I no longer work nights and weekends so its time to get back to the bench and finish a few models that I've started, the first being my Typhoon something I started in 2014.
I've spent today painting the basic camouflage and it hasn't gone too badly, I still have the tail to finish tomorrow and then I can start on the roundels, fin flashes and Sqn codes...
After the Typhoon is finished I'm going to complete my Revel 1/72 Halifax followed by my Fly 1/48 Jet Provost.
Cheers all and a Happy New year to you!
Iain
34 minutes ago, Christer A said:
Nice and crisp finish there Iain!
Hey Christer
cheers mate. My air brush technique is a little rusty but it's gone ok. I'm looking forward to finishing it though.
cheers mate
iain
Morning all
I've finished the basic paint job and TBH I think it looks ok...
...later on today I'll start spraying on the roundels etc then hopefully she will start to look the part.
Umm looking at the photo I think I need to check the seam lines on the cannons! And I thought I had them covered!
Iain
Hi everyone
Since 14:00 this afternoon I've been applying the roundels to my Typhoon (its now 17:15 and the main ones are finished). I've used the Montex mask set K48273 for the task.
Firstly I drew guide lines on all the masks I was going to use, in this case the upper wing and fuselage.
I then applied the outer mask to the wings and fuselage...
Followed by all the inner masks except the very centre ones, Red was going to be my first colour...
I reattached the inner (red) masks and removed the next masks (blue)...
I reattached the (blue) masks..
Removed the outer (yellow) masks...
Sprayed the yellow...
Removed all the masks...
Now the results isn't perfect by any means, your seeing them as I removed them, so some touch ups will be required, but they do look so much better than decals. Tomorrow I'll do the under wing roundels and and fin flashes.
As an aside for Christmas my wife bought me a dremel drill press (which I've yet to use)....
And a Badger paint stirrer...
Which is a pretty nifty piece of kit.
Iain
As far as I know there have been four Typhoon boxings from Hasegawa:-
Car door canopy;
Bubble canopy, four blade prop, early tailplanes;
Bubble canopy, three blade prop, early tailplanes;
Bubble canopy, four blade prop, Tempest tailplanes (sharkmouth boxing).
I await correction on the last one.
Car door canopy;
The last one is correct - it contains resin Tempest tailplanes. But alas not the lightweight Mk3 RP rails which you need for the 245 sharky.  The "normal" Mk1 RP rails are in there though
The Tamiya Mossie has Mk 3 rails.
Jonners
Hi everyone
Tonight I've concentrated on finishing painting the roundels and codes. TBH I'm not totally happy with the results, but they are fixable it will just take more time. Again you're seeing the model with in minutes of the masks being removed..
I'm gonna let everything dry for a full 24 hours before I start the tidy up.
Iain
  • Like 10
43 minutes ago, JosephLalor said:
That's looking very fine
Hey Joseph
thanks mate. Hopefully by this time tomorrow all the touch ups will be done and I can give it a gloss coat ready for the stencil data, serial number and a/c name.
cheers
iain
Looking good there Iain, coming on a treat! Great work on the roundels. I tried to mask the roundels on my recent Zero with limited success. I weathered the heck out of her so i got away with it!
16 hours ago, crustydude said:
Lovely work as usual mate☺ can I ask which colours you used for the roundels as im going to try painting my own!cheers mate👍
The colours are all Tamiya and the mix ratios are:
Dull Roundel Red : 75% Flat Red (XF-7), 25% Red Brown (XF-64)
Roundel Blue : 75% Flat Blue (XF-8), 25% Flat Black (XF-1)
Roundel Yellow : 95% Flat Yellow (XF-3), 5% Flat Red (XF-7)
HTH
Iain
16 hours ago, cashman said:
nicely done! those masks do look better than decals.....
Cheers mate
Yeah the masks are very good (when they behave themselves), I just need to do a little tidying up and they should be fine.
Hi Val
Thanks mate. I will need to carry out a little weathering myself - covers a multitude of sins!
Take it easy fella
Iain
