little-cars Posted August 24, 2016 Share Posted August 24, 2016 Finally started adding on the products that we stock that aren't on the web site. Today I've added all the trumpeter tools that we stock. We don't get a chance to take many of them all to shows, so here they are; http://www.modellingtools.co.uk/trumpeter---mastertools-373-c.asp Many Thanks, Paul Link to comment Share on other sites More sharing options...
bootneck Posted August 24, 2016 Share Posted August 24, 2016 I like those chisels Paul, they look better than the little chisel blades (yellow packets) I used to get from you. I might have to send you an order next week (after pension day! ) cheers Mike Link to comment Share on other sites More sharing options...
little-cars Posted August 24, 2016 Author Share Posted August 24, 2016 Hi Mike, Both work well, the larger trumpeter ones have the advantage that you can sharpen them if needed. Paul 1 Link to comment Share on other sites More sharing options...
Avereda Posted August 24, 2016 Share Posted August 24, 2016 Bass pipes? 1 Link to comment Share on other sites More sharing options...
little-cars Posted August 24, 2016 Author Share Posted August 24, 2016 Bass pipes? Many thanks, that's one typo sorted out ! Link to comment Share on other sites More sharing options...
bootneck Posted September 1, 2016 Share Posted September 1, 2016 I like those chisels Paul, they look better than the little chisel blades (yellow packets) I used to get from you. I might have to send you an order next week. The chisels have arrived Paul; thanks for the quick serves. I've done couple of tests with them and I found them to be good plus they are also quite sturdy. I have found that the fine tips are good for scraping small areas off primed/pre-painted parts prior to gluing. The long handles are also very useful as they allow you to get down between tight areas to do chiselling or scraping. I'll try to place another order, for the rest of the set, in the near future. Mike 1 Link to comment Share on other sites More sharing options...
little-cars Posted September 5, 2016 Author Share Posted September 5, 2016 Hi Mike, Glad you like them. They are nicely made, well packed and should last many years. Thanks, Paul Link to comment Share on other sites More sharing options...
