The Spadgent Posted December 4, 2016 Share Posted December 4, 2016 Stunning. Those hinges are ace. I might borrow some of your ideas here for my Bf109. john 1 Link to comment Share on other sites More sharing options...
Tomoshenko Posted December 17, 2016 Author Share Posted December 17, 2016 As per usual I am running out of time. However, I am not giving up without a fight! A couple of small details to get done. First was to replace the kit pitot with some lengths of tubing. Second was to finish off the air cooler or whatever. Painted black and dry brushed with silver. Annoyingly when I glued this into the nose section one of the vertical bits of wire broke off, but I’m leaving that now. You can barely see it. Then at long last I had to bite the bullet and mask that darned canopy. It felt like masking Crystal Palace with a role of tape, took almost forever; but eventually I got it done in the end. I’d sanded off the kit frames because they were wrong and scale up were about as thick as concrete pillars – see above. This made it more time consuming as I had to reference pictures, drawing etc. on tinternet. Not perfect but anyroad it’s done. Finally I got the nose and tail plane glued on. At long last it is ready for primer. The nose gives it a lot of presence, as the distinctive gull-winged menacing look which characterises the Stuka eventually graces the bench: I gave the canopy a spray of light green (same as the interior) then black. I’ve primed the other bits and bobs, so I can get some primer on this tomorrow. 3 Link to comment Share on other sites More sharing options...
Tomoshenko Posted December 21, 2016 Author Share Posted December 21, 2016 The dash to the finish continues. Got a coat of Alclad grey primer on and some Alclad white on the nose and rudder. Then got some HU24 on like thus. Once the yellow dried I got it masked off and then some Hobby Color RLM65 on the underside. Next up post masking was the RLM71. Splinter scheme masked and then it was the turn of the RLM70. Again Hobby Color, and I must say they went on very nicely and gave a produced a fine finish that I’m quite pleased with. Haven’t used Hobby Color paints much before, but I’m quite impressed with them so will be using them again. This is pre-Klear. Quite pleased with how the splinter scheme came out. Must admit I feel it adds an extra dimension of menace to the Stuka, which after all is menacing enough! Here it is with a couple of coats of Klear. Nice and shiny awaiting the transfers. I’ll let this cure overnight, then on with the transfers. Meanwhile why this dries I’ll be painting the sub-assemblies. 3 Link to comment Share on other sites More sharing options...
Tomoshenko Posted December 23, 2016 Author Share Posted December 23, 2016 Right then. Here it is the transfers on. Went on no probs, quite impressed, no silvering, laid down well, didn’t curl up or disintegrate. On problems was the serial lettering on the undercarriage casings which is a compound curve. Also the swastika which is an Xtradecal was a bit fiddly because it consists of a white outline and a black centre in two parts. Panel line wash in progress. Just got a coat of Alclad semi-matte on. Next I be doing some final weathering, glue the sub-assemblies on, so baring a giant asteroid strike or alien abductions I should get it done in time. 3 Link to comment Share on other sites More sharing options...
rob85 Posted December 23, 2016 Share Posted December 23, 2016 Looking really nice Tom! Looking forward to seeing it completed. Rob 1 Link to comment Share on other sites More sharing options...
modelling minion Posted December 23, 2016 Share Posted December 23, 2016 Looks great! Some fantastic work here, especially masking that camo scheme. Craig. 1 Link to comment Share on other sites More sharing options...
Tomoshenko Posted December 24, 2016 Author Share Posted December 24, 2016 Thank you very much gents. Final run in. Adding a bit of weathering and shading with soft pastels. After this was blended in it got a final coat of Alclad Klear Kote Matte. Here is all the sub-assemblies waiting for assembly. Here it is unmasked and the cockpit opened up again. Pleased with how the canopy turned out given how it started life. Not perfect but I’m quite chuffed with it. Virtually took almost as long to demask as it did mask though with all those flippin’ panes. And finally at long blinkin’ last the Stuka is completed in all its menace. Right then. I’ll get a couple more piccies up a bit later, and get some sorted on the gallery. Only leaves me to say thank you to the mods and hoasts, and thanks to all who have participated, commented and viewed. Happy Christmas. 4 Link to comment Share on other sites More sharing options...
Tomoshenko Posted December 24, 2016 Author Share Posted December 24, 2016 A couple more piccies. It's now up in the gallery: Gallery Thanks for looking. 2 Link to comment Share on other sites More sharing options...
PhantomBigStu Posted December 24, 2016 Share Posted December 24, 2016 A Stunning Stuka, superb work 1 Link to comment Share on other sites More sharing options...
modelling minion Posted December 24, 2016 Share Posted December 24, 2016 A superb result, she looks fantastic. Very well done. Craig. 1 Link to comment Share on other sites More sharing options...
rob85 Posted December 25, 2016 Share Posted December 25, 2016 A stunning result Tom, merry Christmas Rob 1 Link to comment Share on other sites More sharing options...
