  • Announcements
    • Mike
      Ongoing DDoS Attack causing Forum Slowness   26/04/17
      In case you have missed the announcement, the reason that the forum has been slow at times since the minor version update the other day is due to a Denial of Service attack, brute force attack on our email, and judging by the lag with our FTP response, that too.  If you're feeling like you're experiencing a glitch in the Matrix, you're not wrong.  This is the same MO as the attack in September 2016 that occurred when we transitioned to the new version 4 of the software.  We're currently working with US and UK cyber-crime departments, who specialise in this sort of thing, and we're hopeful that we'll be able to track them down this time by using the accumulated evidence already held.    We are pretty certain that it's a continuation of the same attack last year, only at a reduced intensity to deter people from using the site "because it's terribly slow", rather than taking it down completely, and we're also sure of the motivations of those responsible.  Spite.   Please bear with us in the interim, and wish us luck in dealing with these.... "people".
RumonYa
Metallic Details sets in stock
6 posts in this topic
Products of Metallic Details is in stock:
1/144
Detailing set for Airbus A319
Set contains photoetch parts for detailing the engines, fold chassis, sensors, winglets, wipers of the aircraft. Recommended for Revell kit.
Detailing set for Tu-144
Set contains photoetch parts for detailing the exterior of the aircraft. Recommended for ICM kit.
Detailing set for Boeing 787-8 Dreamliner
Set contains photoetch parts for detailing the exterior of the aircraft. Recommended for Zvezda kit.
1/48
Detailing set for I-185
Photo etched parts. Recommended for kit: Ark Models
Detailing set for Su-2
Photo etched parts. Recommended for kit: Zvezda
Detailing set for Po-2/U2
Photo etched parts. Recommended for kit: ICM
Air intake grilles for Su-27
Photo etched parts. Recommended for kit: Academy
Detailing set for B-29
Resin & photo etched parts. 4 x Engine, 8 x Compressor exhaust, 2 x Landing gear bays. Recommended for kit: Revell/Monogram
Detailing set for He-219
Photo etched parts. Recommended for kit: Tamiya
Detailing set for Yak-9
Photo etched parts. Recommended for kit: Modelsvit
Detailing set for Folland Gnat T.1
Photo etched parts. Recommended for kit: Airfix
Ejection Seat K-36 D/DM
Resin & photo etched parts. The set has 2 seats with the possibility to assemble the chairs in variants K-36D and K-36DM. These seats are installed on the aircraft such as the Su-27, MiG-29, Tu-160 etc.
Detailing set for Po-2 mod. LNB/VS
Resin & photo etched parts. The set contains 2 dashboards for the pilot and navigator for the aircraft Po-2 modifications LNB (light night bomber)and VS (Soviet Air Force plane connection). In addition, the kit contains parts for assembly and device for forming 2 spoked wheels with tires (original size 700x120 mm).
Detailing set for Pe-2
Photo etched parts. Recommended for Zvezda kit. Set contains parts for detailing the interior and exterior of the aircraft.
Czech hedgehog
Kit contains photoetched and resin parts to build 1 Czech hedgehog. The base with the bolts/nuts has a fixture to bend. The thickness of the metal - 0.3 mm. The diameter of the bolt head, nut - 0,86 mm. The bolt is threaded on its end.
Detailing set for B-29, flaps
Photo etched parts. Recommended for Revell/Monogram kit. Set contains parts for detailing exterior of the aircraft. 2 sheets - 270*126 mm, 1 sheet - 270*70 mm
Nose cone for Su-27
The nose cone for model aircraft Su-27 by Academy. Designed for correcting the shape of the nose cone.
Nose cone for MiG-23
The nose cone for model aircraft MiG-23 by Trumpeter. Designed for correcting the shape of the nose cone.
1/72
FuG-200
Photo etched parts.
Detailing set for Su-27
Detailing set for T-50 PAK-FA
Resin & photo etched parts. 4 x Engine, 8x Compressor exhaust,2 x Landing gear bays. Recommended for kit: Academy
Czech hedgehog
1/48 & 1/72
Machine gun sights
Photo etched parts
1/35
Soviet tanks set 1
Photo etched parts. The universal set for Soviet tanks of the II World War (IS-1, IS-2, SU-100, ISU-152, T-34).
Czech hedgehog
German grenades M39 and M24
Photo etched and resin parts. Kit contains 5 resin Eihandgranate M39, 5 resin Stielhandgranaten 24, 2 boxes to transport both types of grenades
Soviet grenades F1 and RGD-5
Photo etched and resin parts. Kit contains 5 resin grenades F1, 5 resin grenades RGD-5, 4 resin capacity with UZRGM fuses, 2 boxes to transport both types of grenades (14*9 mm)
Soon
1/48 B-24 Liberator. Engines
Resin parts.4 x Engine Pratt & Whitney R-1830 Twin Wasp, 4 x Supercharger. Number of parts - 148. Recommended for Revell/Monogram kit.
Coming soon production of Metallic Details:
7_20.jpgDetailing set for Zvezda kit "Boeing 777-300 ER" in scale 1/144.
Set contains parts for detailing the exterior of the aircraft.
2_37.jpgSR-71 Blackbird. Grides and jet nozzles in scale 1/48 for Testors/Italeri kit.
Designed to improve the appearance of the model.
1_41.jpgSR-71 Blackbird. Inlet cone in scale 1/48 for Testors/Italeri kit.
The set contains 8 parts to assemble 2 inlet cones.
1_45.jpgPratt & Whitney R-985 Wasp Junior in scale 1/48.
The set contains parts to build 1 engine.
Designed for the aircraft model C-45 Expeditor ICM-kit.
1_44.jpgWright R-1820 Cyclone in scale 1/48.
Designed for the aircraft model B-17 Flying Fortress Monogram kit.
1_43.jpgPratt & Whitney R-1830 in scale 1/48.
Designed for the aircraft model B-24 Liberator Monogram kit.
1_39.jpgEjection seat K-36DM late in scale 1/48.
The set contains parts to build 1 seat.
Use for aircraft Su-24, Su-25, Su-27, MiG-29.
1_38.jpgEjection seat K-36DM early in scale 1/48.
1_40.jpgLAU-128/ADU-552 Launcher set for F-15 in scale 1/48.
ADU F-15. Set contains 8 details.
2_32.jpgButterfly screw 3 in scale 1/35.
The set contains 12 screws.
Coming soon:
2_56.jpgSR-71 Blackbird. Grides in scale 1/72.
14_3.jpgDetailing set for aircraft model MiG-29 (Zvezda) in scale 1/72.
Set contains photoetched details, painting masks for the cockpit canopy, color film for the dashboard.
11_3.jpgDetailing set for aircraft model Airbus A300 Beluga (Revell) in scale 1/144.
2_53.jpgDetailing set for aircraft model Ju-88. Interior (ICM) in scale 1/48.
Set contains parts for detailing the interior of the aircraft.
3_52.jpgDetailing set for aircraft model Ju-88. Exterior (ICM) in scale 1/48.
3_51.jpgDetailing sets for aircraft model C-45 Expeditor (ICM) in scale 1/48 of 2 variants:
- Detailing set for aircraft model C-45 Big edition (ICM, 1/48): resin (2 engines Pratt & Whitney R-985 Wasp Junior) and photoetched details, film for dashboard;
- Detailing set for aircraft model C-45 Expeditor (ICM, 1/48): photoetched details and film for dashboard.
Sets contain parts for detailing the exterior of the aircraft.
10_5.jpgDetailing set for aircraft model I-153 (ICM) in scale 1/48.
1_54.jpgDetailing set for aircraft Tu-154 for Zvezda kit in scale 1/144.
4_33.jpgBoat davits for Russian ships (Bayan, Pallada, Makarov) in scale 1/700.
Set contains 32 davits 4 sizes.
Edited by RumonYa
Coming soon:
1_85.jpgF-15 E. Jet nozzles in scale 1/48 for Revell kit.
1_86.jpgLAU-128/ADU-552 Launcher set for F-15 in scale 1/72.
The set contains 8 details.
1_93.jpgCorrection set for T-70, T-80, Su-76 in scale 1/35.
The set contains 14 road wheels and 2 types of driver's hatch.
5_39.jpgGerman staff tent type 1 in scale 1/72.
The set contains 1 tent. No Assembly required.
2_77.jpgCanister 20 l in scales 1/48, 1/72 and 1/144.
Sets contain 3 or 5 canisters depending on the scale.
5_37.jpgDrum 200 l in scales 1/35, 1/48, 1/72 and 1/144.
Sets contain from 3 to 5 drums depending on the scale.
2_72.jpg- Butterfly screw 4 in scale 1/35;
- Butterfly screw 5 in scale 1/35;
- Wing screw 2 in scale 1/35.
Sets contain 12 screws.
2_68.jpgRussian concrete fences PO-2, PO-2m, PO-3, PO-3m, P6V, P6Vm in scales 1/72 and 1/144.
Sets contain 8 plates and 9 footing.
1_63.jpgBollard type 1 in scale 1/700.
Set contains 10 bollards.
Coming soon:
1_94.jpg Detailing set for aircraft model Concorde (Revell) in scale 1/144.
The set contains photoetching and resin parts (4 air intakes and engine components).
10_12.jpgDetailing set for aircraft model L-1011 Tristar (Eastern Express) in scale 1/144.
2_91.jpgDetailing set for aircraft model ATR 42-500 (Italeri) in scale 1/144.
The set contains photoetching parts and painting masks.
1_99.jpgDetailing set for British heavy tank model Conqueror Mark 2 in scale 1/35.
Set contains parts for detailing the exterior of the tank.
4_56.jpgDetailing set for aircraft model VC-140b JetStar (Roden) in scale 1/144.
1_97.jpgDetailing set for aircraft model C-17A Globemaster (Revell) in scale 1/144.
