(ex)Sgtrafman Posted August 7, 2016 Share Posted August 7, 2016 Evening everyone A question for all you typhoon phanatics. I'm building SW399 HH*K, am I right in thinking she had a four bladed prop and tempest tail? Also was she a 'bombphoon' or did she carry rockets? Many thanks in advance Iain Link to comment Share on other sites More sharing options...
ben_m Posted August 7, 2016 Share Posted August 7, 2016 Yes Iain you are right, SW399 was built with large tailplanes and the 4 blade prop. It would also have had the belly-mounted dust filter (provided in the Airfix 1/72 and 1/24 kits). If you are modelling it with red spinner with yellow spinner back-plate, as in the Xtradecals set with this serial, this was based on a photo taken in July 1945, and the aircraft also had the inner landing gear doors decorated (top 1/3 yellow, middle 1/3 red, bottom 1/3 yellow), and also the 'cuckoo-doors' of the filter for the intake in the centre of the radiator were red with a yellow outline. Source: 2nd Tactical Airforce Vol. 4 p.671, by Shores and Thomas. 175 Sqn was a rockets-only squadron from Mar/Apr 1944 until the end of the war.In the July 1945 photo it shows SW399 with the aluminium Mk. 3 rocket rails (if you're building the 1/72 Airfix- or Brengun, or Academy- the type supplied are Mk.I; aftermarket rails are available). 1 Link to comment Share on other sites More sharing options...
(ex)Sgtrafman Posted August 8, 2016 Author Share Posted August 8, 2016 Yes Iain you are right, SW399 was built with large tailplanes and the 4 blade prop. It would also have had the belly-mounted dust filter (provided in the Airfix 1/72 and 1/24 kits). If you are modelling it with red spinner with yellow spinner back-plate, as in the Xtradecals set with this serial, this was based on a photo taken in July 1945, and the aircraft also had the inner landing gear doors decorated (top 1/3 yellow, middle 1/3 red, bottom 1/3 yellow), and also the 'cuckoo-doors' of the filter for the intake in the centre of the radiator were red with a yellow outline. Source: 2nd Tactical Airforce Vol. 4 p.671, by Shores and Thomas. 175 Sqn was a rockets-only squadron from Mar/Apr 1944 until the end of the war.In the July 1945 photo it shows SW399 with the aluminium Mk. 3 rocket rails (if you're building the 1/72 Airfix- or Brengun, or Academy- the type supplied are Mk.I; aftermarket rails are available). Hi Ben Brilliant thanks mate. Regards Iain Link to comment Share on other sites More sharing options...
(ex)Sgtrafman Posted August 8, 2016 Author Share Posted August 8, 2016 Hi everyone Another quick question. I want to display my model as though it's under going some maintenance with panels removed. Would the fuel tank in front of the ip be resealable and if so would it have been in a red colour? Again thanks in advance Iain Link to comment Share on other sites More sharing options...
