Shar2 Posted July 17, 2016 Share Posted July 17, 2016 Mk82 Air BSU 49/BVideoaviation 1:32 Continuing the growth in their 1:32 range of bombs, Videoaviation have released this set of Mk82 500lb bombs, this time fitted with the BSU 49/B high drag tail unit. Produced in the standard cream resin the eight bombs come with a variety of nose caps, dependent on whether a nose or tail fuse is fitted. As with previous sets the bombs are made up from two sections, the bomb unit and the tail unit, which, once removed from the moulding plug and cleaned up are simply glued together. The bomb lugs are also separate items, and quite fragile, so great care will be needed to remove them from the moulding blocks. Whilst the bombs as released are for use with USAF aircraft, the modeller can, should they desire, simulate the thermal protection used on USN bombs and use them with any modern naval aircraft. The decals supplied provide the stencils found on these bombs, along with eight remove before flight flags. ConclusionAs is usual with Videoaviation the details and moulding quality is superb and the decals are well printed. They will make a great addition to any model. Very highly recommended. Review sample courtesy of Link to comment Share on other sites More sharing options...
