GMK Posted July 29, 2016 Author Share Posted July 29, 2016 Thanks, Ray. I'm now doing two M113 (my APC & a MRV) - but each have different track! A guy on Shapeways is doing the Diehl 513B for my car as a master for casting. The older T130E1 for the Scorpion turret will be done via modifying an old Verlinden track link & casting it. Link to comment Share on other sites More sharing options...
GMK Posted August 6, 2016 Author Share Posted August 6, 2016 A little more progress over the course of the week. The cargo hatch & filter box are close to completion. The trickiest work to date has been adding the gun depression rail ('Jesus bar') between the turret & cargo hatch to prevent own goals into the vehicle itself. The turret makes the full 360 degree/6,400 mil traverse, without interference. Interestingly, on the upgraded M113AS4, electronic interlocks superseded the need for a physical bar to prevent own goals, so one wasn't initially fitted. User complaints about the absence of a 'hand rail' led to the incorporation of a purpose designed one into the build state. Cheers. 4 Link to comment Share on other sites More sharing options...
GMK Posted August 7, 2016 Author Share Posted August 7, 2016 Mucking around with a Scorpion-turreted Medium Reconnaissance Vehicle in 1/16, as well. 2 Link to comment Share on other sites More sharing options...
GMK Posted August 8, 2016 Author Share Posted August 8, 2016 The car I'm building - 134329 - had a M113 hull, not a M113A1, so it had the bolted plate around the armoured fuel filler cap. Thankfully, so did the 1/1 scale example I measured. Anyone know where to find a 1/16 armoured fuel filler cap? 4 Link to comment Share on other sites More sharing options...
GMK Posted August 11, 2016 Author Share Posted August 11, 2016 A bit of progress on the hull roof. 5 Link to comment Share on other sites More sharing options...
GMK Posted August 13, 2016 Author Share Posted August 13, 2016 Colour experimentation for the disruptive pattern. The engine deck in kit is on the left - milled from a solid block of 2mm styrene. Not bad, considering. But the holes are cut vertically, not angled....so, my effort is on the left. Still a ways to go, but a definite improvement. Cheers 3 Link to comment Share on other sites More sharing options...
GMK Posted August 15, 2016 Author Share Posted August 15, 2016 More on the engine deck. Found some fly mesh for the grills - may be a little coarse, but was trying to find 0.6 x 1.5mm. This was the best I could do. Need to add the weld blobs that affix the mesh to the grills themselves. What can't be seen is the 1mm square chunk I removed from the glacis so that it sits a little less proudly in the rebate. 2 Link to comment Share on other sites More sharing options...
GMK Posted August 22, 2016 Author Share Posted August 22, 2016 Most of the work over the weekend was related to getting the hull in a better state. The glacis has been glued on, with work commencing on getting the transition between the lower hull & it correct. Also test fitted some tools from the Tamiya 1/16 M4 Sherman. In addition to tools, the Tamiya Sherman donated one of its fuel filler caps: Comments welcome, as always. 3 Link to comment Share on other sites More sharing options...
Wogga Posted August 22, 2016 Share Posted August 22, 2016 really great effort coming on nicely. 1 Link to comment Share on other sites More sharing options...
GMK Posted August 30, 2016 Author Share Posted August 30, 2016 Received some updated parts from Christian today. Managed to scale some aspects from the real vehicle: the kit has been updated accordingly. The biggest change has been the shift in the combat door on the ramp (you can see the different relative positions - old school one on top): And fit checked (the 3D printed mud guards are also visible): Squared off the corners of the roof of the hull. The surface underpinning the lifting points extend to the very edges. And - the idlers have arrived! 4 Link to comment Share on other sites More sharing options...
GMK Posted September 1, 2016 Author Share Posted September 1, 2016 Some more progress today. AMU brush guards on Australian M113A1 were a bit beefier than the standard, using flat stock section twisted, then bent into shape, before being welded in position. The results were somewhat agricultural - thankfully. As such, I rate my efforts as broadly representative. More tomorrow - may even finish the roof! 3 Link to comment Share on other sites More sharing options...
GMK Posted September 3, 2016 Author Share Posted September 3, 2016 Made a start on the driver's hatch. By the time I inherited 'my' car, a series of stolen APC rampage incidents (http://m.imgur.com/gallery/11iTk69) had led to a 'spider' lock being installed in place of the hatch-mounted driver's night viewer. I'll add the lock cover, hasp, & hold open next. Almost all of the hull roof fittings are now complete & fitted. The 'cut' edge of the driver's hatch can be seen here. Still need to finish the hinges. Away for the next week, so things will slow down. 2 Link to comment Share on other sites More sharing options...
GMK Posted September 12, 2016 Author Share Posted September 12, 2016 Got some paint on, to check what it looks like: And had the opportunity to collect some more references thanks to work: 4 Link to comment Share on other sites More sharing options...
GMK Posted September 18, 2016 Author Share Posted September 18, 2016 The CAD guy (thanks Matt) really took advantage of the great references I was able to collect to refine the CAD: I've done more work on the driver's hatch cover and refined the tone of the FS30129 tan. Adding 'flesh' toned paint has certainly improved the look: Only some minor fittings to go & the roof can be set aside to concentrate on the hull. 3 Link to comment Share on other sites More sharing options...
GMK Posted September 22, 2016 Author Share Posted September 22, 2016 As expected, adding the turret vision blocks that I'd cut earlier from a CD case to pre-cut holes in the turret sides set at a 60 degree angle wasn't fun, nor tidy. Now that they're basically fitted, the turret structure is sealed, ready for a mold to be taken. Still need to detail the sealant, weld runs, & vision block bolts, but it's definitely on the downhill. Primer, then in the mail to get a resin copy for a future build. Mantlet rework to follow. 2 Link to comment Share on other sites More sharing options...
GMK Posted November 13, 2016 Author Share Posted November 13, 2016 Well, after some time in the US, Japan, & Indonesia for work, minor progress has been made on 31. Thought I'd add a splash of colour to see what things look like. Neither the camouflage pattern nor the colours are 100%, but they are good for project morale. Comments welcome. 6 Link to comment Share on other sites More sharing options...
snapper_city Posted November 13, 2016 Share Posted November 13, 2016 Great work so far. The brown looks lighter in the photo. 1 Link to comment Share on other sites More sharing options...
magman2 Posted November 13, 2016 Share Posted November 13, 2016 Nice work, well done 1 Link to comment Share on other sites More sharing options...
Romeo Alpha Yankee Posted November 13, 2016 Share Posted November 13, 2016 Looking good Greg, I meant to ask about this when we caught up on the weekend, but the conversion got sidetracked a lot! 1 Link to comment Share on other sites More sharing options...
longshanks Posted November 13, 2016 Share Posted November 13, 2016 Some interesting work going on here Kev Link to comment Share on other sites More sharing options...
GMK Posted November 14, 2016 Author Share Posted November 14, 2016 3 hours ago, snapper_city said: Great work so far. The brown looks lighter in the photo. You're right - thankfully it's not as stark IRL. 1 Link to comment Share on other sites More sharing options...
Ripaman Posted November 14, 2016 Share Posted November 14, 2016 Love your scratch building Greg Regards Richard 1 Link to comment Share on other sites More sharing options...
GMK Posted November 14, 2016 Author Share Posted November 14, 2016 1 hour ago, Ripaman said: Love your scratch building Greg Regards Richard Thanks, Richard. It's been fun. I appreciate you commenting. Link to comment Share on other sites More sharing options...
GMK Posted November 14, 2016 Author Share Posted November 14, 2016 3 hours ago, TrojanThunder said: Looking good Greg, I meant to ask about this when we caught up on the weekend, but the conversion got sidetracked a lot! Cheers, Ray. Was good to catch up. I always enjoy checking your work out - it never disappoints. 3 hours ago, longshanks said: Some interesting work going on here Kev Cheers, Kev. I like to be a little different. Link to comment Share on other sites More sharing options...
GMK Posted November 14, 2016 Author Share Posted November 14, 2016 Some expressed concerns over the fidelity of the colours used, specifically the tan (FS30219 out of the tin). I used the early morning light that better captures what it looks like IRL: /URL] 3 Link to comment Share on other sites More sharing options...
