Shar2 Posted June 25, 2016 Share Posted June 25, 2016 Lockheed F-104G Detail SetsEduard/Brassin 1:32 The release of the big 1:32 Starfighter was met with some disappointment from some quarters for various reasons. If you have got one or are thinking of getting one, then you might want to get the most out of the kit with the addition of these two sets from Eduard.(32869 - Electronic Equipment) – This set contains two small sheets, one pre-painted, whilst the other is unpainted. Naturally there is quite a bit of the kit detail in the area that will need to be removed first, and these areas are clearly marked on the instructions. The pre-painted sheet contains the equipment faces, placards and circuit breaker panels. The unpainted sheet contains the central spine of the bay, an empty bay to be fitted in the open space in the left hand bay, along with the strip that goes around the bay, complete with screw holes to affix the removable panels. The panels themselves also receive new parts, such as bulkheads, fixing strips, internal access panels, and strengthening plates. (632047 - Ejection Seat) – Contained within the now standard Brassin blister pack the resin parts are very well protected with quite a thick layer of foam, whilst the etched sheet is separate by a card backing. There are four resin parts that include the seat, the seat rail and two styles of PSP pack. The seat is beautifully detailed, but some care will need to be exercised when removing from the moulding block as areas such as the leg restraint points might get damaged. The rails, whilst more fragile are only held to the moulding block by quite thin webs, so shouldn’t cause too many problems with removal. The etched parts are used for the finer fittings, such as seat firing handle, PSP release handle, seat rail cross beams, and thankfully a full set of seatbelts. There is also a small decal sheet which provides the various placards for around the seat. Once assembled, it’s just a case of gluing the rails and seat into the kits cockpit. ConclusionHere we have another pair of useful items from Eduard/Brassin. Although I think the seat set will probably be more popular the electronic bay set will certainly give someone looking at the completed model something different to view. Review sample courtesy of Link to comment Share on other sites More sharing options...
