Shar2 Posted June 18, 2016 Share Posted June 18, 2016 Masts and 14 Barrels1:350/700 Master Models Master Models continue to build their range of accessories and barrels in both 1:350 and 1:700. Having released two sets of yardarms in both scales, they have now released two sets of tapered masts to go with them.[sM-350-89] The first of the mast sets is contained in the standard Master packaging, only the internal bag is compartmentalised, allowing each of the four masts to be slid into their own pouch. Each mast is 100mm or 4 inches in old money and are meant to used as the main section on larger ships masts.. [sM-350-90] Set two in 1:350 also contains four mast sections, each 100mm long, but these are more tapered and a meant for use as the top sections on larger masts or the main section for smaller ships masts. The tips of these are quite sharp so be aware when using them and you might want to keep any models with them fitted in a case, as they could easily damage an eye for the unwary. [sM-700-47] For those modellers who like their ships in 1:700 scale, Master Models have masts sets for you too. Set one once again has four mast, as per the 1:350 sets, but each are 60mm long. Whilst they are meant to be used as the main section of larger ships in the smaller scale, they could also be used in :350 ships for the very top of taller masts. [sM-350-48] This second set also has four masts, again each 60mm long and again for use as the top sections of large ships masts, but could also be used on smaller ships. They could also be used as gaffs and other mast parts on larger scale ships. Now these are the sharpest of the four mast parts and boy are they sharp. I actually drew blood trying to get one out of the packaging, so the warning above is even more relevant with these. [sM-700-50] This and the next set return to what Master do best, and that is to make turned metal barrels for model warships. This set contains twelve 14 barrels for use with the Tennessee and New Mexico class battleships. These barrels are for use when there are no blast bags fitted to the model. [sM-700-51] This second set of 14 barrels is as per the set above, only for use when blast bags are fitted to the turrets. ConclusionI just love what Master do. Everything is so precise and realistic looking, which is exactly what we, as modellers, are looking for. The mast sections will be a real boon to those who dislike the slightly bent look that injection moulded masts can get when the rigging is attached, with these sections and the yardarms mentioned earlier, you will have a nice sturdy mast. Just be careful when handling and once built. The barrels are just what we have come to expect from Master Models and make for very convincing replacements to the injection moulded parts, which can look quite clunky in comparison. Very highly recommendedReview sample courtesy of Piotr at Link to comment Share on other sites More sharing options...
