Romeo Alpha Yankee Posted June 7, 2016 Share Posted June 7, 2016 Been tinkering on these for a little while now. The TAP-3B is a resurrected shelf of doom RP-3D I was not happy with. So off came the gear, out came the nose weight and onto a pole it went. I will be using some Aussie Decals for this one. Still at the early paint stage, need to break up the all over grey with some faded panels and weathering. The P-3B is a new build with Hamilton Hobbies (local Aussie producer) P-3B conversion and weapons bay sets. I will be using the DEKLs P-3B decals on this one. Also more painting to go, this one will be a lot cleaner than the TAP-3B 4 Link to comment Share on other sites More sharing options...
Romeo Alpha Yankee Posted June 19, 2016 Author Share Posted June 19, 2016 Well I am done with the paint on the P-3B, Once the gloss coat sets it will be time for some decals - It will be A9-300 Then to secure the props and entry ladder and add the final clear bits 3 Link to comment Share on other sites More sharing options...
The 3rd Placer Posted June 19, 2016 Share Posted June 19, 2016 Clean work Ray, looking forward to the finished product....I do like the boarding ladder! What type is that twin in the background on your bench? Ryan 1 Link to comment Share on other sites More sharing options...
Romeo Alpha Yankee Posted June 20, 2016 Author Share Posted June 20, 2016 Thanks Ryan, The twin in the background is Beech 200 (resin kit). Link to comment Share on other sites More sharing options...
Romeo Alpha Yankee Posted July 4, 2016 Author Share Posted July 4, 2016 Finally got motivated to start decalling after a lot of paint rework. I am using the DekLs sheet ( local Aussie producer). He uses a reverse printing technique on continuous film. Colours looks good once applied. I started by laying down the whites I used 2 white disks for the fuselage roundel position as it went over the grey and white (the sheet gives you extras). Then I added the roundels and flashes. I managed to damage some of the decals when cutting them out and trimming them. Not sure how I could have prevented this. Will have to ask Mr DekL next time I chat with him. Overall, the decals look pretty good at this stage. Will continue tonight 3 Link to comment Share on other sites More sharing options...
snapper_city Posted July 4, 2016 Share Posted July 4, 2016 Looking good so far. 1 Link to comment Share on other sites More sharing options...
The 3rd Placer Posted July 5, 2016 Share Posted July 5, 2016 Nice update Ray, crisp masking around the Windows, looking good. Ryan 1 Link to comment Share on other sites More sharing options...
Coors54 Posted July 5, 2016 Share Posted July 5, 2016 Hi Ray, loving the P-3's but one question, are they the right props you have on in the earlier picture? I thought P-3's had the square cut Aeroproducts(?) props not the round tip Ham Standards. Probably wrong as it's a long time since I had dealings with Allison 501's. Can't wait to see the finished article. Dave 1 Link to comment Share on other sites More sharing options...
Pete in Lincs Posted July 5, 2016 Share Posted July 5, 2016 Looking nice. 1 Link to comment Share on other sites More sharing options...
Romeo Alpha Yankee Posted July 5, 2016 Author Share Posted July 5, 2016 Hi Ray, loving the P-3's but one question, are they the right props you have on in the earlier picture? I thought P-3's had the square cut Aeroproducts(?) props not the round tip Ham Standards. Probably wrong as it's a long time since I had dealings with Allison 501's. Can't wait to see the finished article. Dave Thanks Dave, Definitely round tips on the P-3s. Lockheed Electras had square tips Link to the aircraft I am trying to model Link to comment Share on other sites More sharing options...
GMK Posted July 6, 2016 Share Posted July 6, 2016 Clean, crisp work as always, Ray. You choose some pretty tricky schemes as well. 1 Link to comment Share on other sites More sharing options...
Coors54 Posted July 6, 2016 Share Posted July 6, 2016 Yeah, you're right Ray, my time was on Electras and we only had one 'frame with round tips, an ex KLM machine, G-FIZU on the UK register. The props were a customer option and KLM were one of the only ones to go that way, wonder why the military a/c all have rounded tips? Better low altitude performance? I seem to remember that ZU was reputed to have a better take off performance....... 1 Link to comment Share on other sites More sharing options...
Romeo Alpha Yankee Posted July 6, 2016 Author Share Posted July 6, 2016 Dave, ask and you will find out... Found this on another forum. Its all about prop tip speed and efficiency The problem with fast, fairly high flying turbo-props with large propeller radii is that the propeller tips will be the first part of the aircraft to reach the speed of sound, with resultant significant loss of thrust for the power delivered to the propeller. Compare the L188 Electra which was developed into the P-3. The L188 was optimised to fly fast (about TAS 330 Knots) and reasonably high (F/L 250). The L188 had square propeller tips, with a slightly broader blade than the P-3, i.e. the same propeller area to absorb the power. Some loss of aerodynamic efficiency was acceptable to avert the much greater loss of efficiency in having the propeller tips reach Mach 1.0 at fast and high cruise.The P-3 on the other hand was optimised to spend most of it's mission time at low level, where sonic propeller tips are not a problem, and the higher aspect ratio rounded tip propellers provided the optimum efficiency. It still left the P-3 with a 'respectable' high speed / high altitude transit capability, but not in the same league as it's 'parent' L188. (This loss of high speed capability may have been compensated for in the increased power (by about 500 HP per engine) on the Allison variant fitted to the P-3). Clean, crisp work as always, Ray. You choose some pretty tricky schemes as well. Thanks Greg,, I like my different schemes, can't have a boring all grey display case Yeah, you're right Ray, my time was on Electras and we only had one 'frame with round tips, an ex KLM machine, G-FIZU on the UK register. The props were a customer option and KLM were one of the only ones to go that way, wonder why the military a/c all have rounded tips? Better low altitude performance?I seem to remember that ZU was reputed to have a better take off performance....... The Electra is a nice aircraft, I have a conversion in 1/72, but wish I had more. There are so many nice schemes out there including the Atlantic Airlines ones. 1 Link to comment Share on other sites More sharing options...
Romeo Alpha Yankee Posted July 23, 2016 Author Share Posted July 23, 2016 Decalling almost finished, just have the wing walkways to do, install some clear parts and HF wire antennas and it should be done (who knows when that will be!) 7 Link to comment Share on other sites More sharing options...
Alpha Delta 210 Posted July 23, 2016 Share Posted July 23, 2016 Absolutely beautiful! I've always had a soft spot for the Orion. 1 Link to comment Share on other sites More sharing options...
Romeo Alpha Yankee Posted August 9, 2016 Author Share Posted August 9, 2016 Calling this done (after a final gloss coat) with one of it's RAAF Stablemates 1 Link to comment Share on other sites More sharing options...
The 3rd Placer Posted August 9, 2016 Share Posted August 9, 2016 Good looking birds. 1 Link to comment Share on other sites More sharing options...
