SeanM Posted July 12, 2016 Author Share Posted July 12, 2016 I have to agree Brodie. I've done Panda's M-ATV and that was not easy but at least it went together. However in this instance I don't believe I've made any real error in the construction and the fit is just awful! I'm not even sure I can recover it beyond this point..... Link to comment Share on other sites More sharing options...
FrancisGL Posted July 12, 2016 Share Posted July 12, 2016 It is good to know that, anyone who buys one knows what to expect, good work... , cheers 1 Link to comment Share on other sites More sharing options...
Reilly Posted July 21, 2016 Share Posted July 21, 2016 That's quite a gap that needs filling. That's a lot worse then the Meng effort, even before work with files and sanding boards, but then they weren't too good at translating the length of the real thing to the model. Link to comment Share on other sites More sharing options...
simmerit Posted July 21, 2016 Share Posted July 21, 2016 I've got one of these as well as the Meng, and I bought it because I was gutted about Meng getting the dimensions wrong. Its good watchign you get to grips with this, but its put me off tackling mine in the short term. Stick with it and I'm sure you will get there Link to comment Share on other sites More sharing options...
SeanM Posted July 28, 2016 Author Share Posted July 28, 2016 Not the neatest job, but it will at least let me finish it. Lots of repairs needed after the struggle of getting the two halves together. It was worth stepping back for a week. So for anyone else attempting a Panda Cougar start with the inside and get the body halves attached before doing the suspension, fenders, bins, lift rings, steps....basically anything on the outside. And constantly dry-fit....sand, cut, file, dry-fit again, repeat.... 3 Link to comment Share on other sites More sharing options...
brodiebear Posted July 28, 2016 Share Posted July 28, 2016 great perseverance, but its building like a cottage kit from back in the 90's and not the supposed high tech kit from a mainstream manufacturer its supposed to be:-) 1 Link to comment Share on other sites More sharing options...
FrancisGL Posted July 28, 2016 Share Posted July 28, 2016 A good job of patience and effort, as you mention before, dberia be better for what they "say it is" kit , cheers mate 1 Link to comment Share on other sites More sharing options...
Alpha Delta 210 Posted July 28, 2016 Share Posted July 28, 2016 Sorry that this is proving a bit of a battle, but if looks like your perseverance is paying off! Looking forward to seeing the next instalment. 1 Link to comment Share on other sites More sharing options...
Kallisti Posted July 28, 2016 Share Posted July 28, 2016 Slap some dirt on it in the painting stage and nobody will notice 2 Link to comment Share on other sites More sharing options...
SeanM Posted July 29, 2016 Author Share Posted July 29, 2016 Thanks Gents. If it had been a cheap kit it would have gone in the bin. But too much time and money gone in to it to surrender now 😄 This is going to fight me every step of the way.... The front windscreen in incompletely cast. One side is missing ant these stand out from the hull. How it should be: The other side: And after repairs ready for painting: The controls for rotating the turret were not very well thought out. OK if leaving hatch closed but will need filling with open hatch. Pity I didn't spot it before assembly So the struggle continues.....stay tuned for further updates 1 Link to comment Share on other sites More sharing options...
phildagreek Posted July 29, 2016 Share Posted July 29, 2016 It's always more satisfying when it fights back! 1 Link to comment Share on other sites More sharing options...
SeanM Posted July 29, 2016 Author Share Posted July 29, 2016 Currently feeling real "satisfied" Phil 🤔 2 Link to comment Share on other sites More sharing options...
FrancisGL Posted July 30, 2016 Share Posted July 30, 2016 Good "fight" ... despite everything going well dodging obstacles ... , cheers Sean 1 Link to comment Share on other sites More sharing options...
SeanM Posted August 3, 2016 Author Share Posted August 3, 2016 Well it's time to start painting the outside using my shiny new airbrush And the first attempt didn't go so well. Guess I should have practiced more first. Also tried with Mig primer on the turret and that was even worse. Link to comment Share on other sites More sharing options...
Alpha Delta 210 Posted August 4, 2016 Share Posted August 4, 2016 What a beast! Good luck with your second attempt. 1 Link to comment Share on other sites More sharing options...
FrancisGL Posted August 4, 2016 Share Posted August 4, 2016 It is a decisive step in the assembly of any kit, you have to be very careful with mixing more with the primer, which is usually very dense. , cheers mate Link to comment Share on other sites More sharing options...
SeanM Posted August 4, 2016 Author Share Posted August 4, 2016 I found the Mig primer just flowed and pulled into little globules Francis. I'll do some on an unused piece and take a photo tonight Link to comment Share on other sites More sharing options...
Andy Moore Posted August 4, 2016 Share Posted August 4, 2016 The Mig AMMO primers can take a bit of getting used to. They need to be misted on, and you need to let each layer flash off for a minute or so before applying another misted layer. They can't be sprayed as a wet coat. When you do get them to work though, they make a pretty good primer. Andy 1 Link to comment Share on other sites More sharing options...
SeanM Posted August 5, 2016 Author Share Posted August 5, 2016 This is what I used to prime the cleaned up gun-tub after the Mig primer was a disaster Came out quite well too 3 Link to comment Share on other sites More sharing options...
SeanM Posted August 5, 2016 Author Share Posted August 5, 2016 And now back to the hairy sticks to start detailing 😀 Took a bit of sanding and re-spraying bits but happy with the result 6 Link to comment Share on other sites More sharing options...
FrancisGL Posted August 6, 2016 Share Posted August 6, 2016 Look better... , cheers Sean 1 Link to comment Share on other sites More sharing options...
Alpha Delta 210 Posted August 6, 2016 Share Posted August 6, 2016 Great recovery. It's really looking good now. 1 Link to comment Share on other sites More sharing options...
SeanM Posted August 6, 2016 Author Share Posted August 6, 2016 Thanks Gents! Finally on the home stretch! Link to comment Share on other sites More sharing options...
phildagreek Posted August 6, 2016 Share Posted August 6, 2016 Looking good! 1 Link to comment Share on other sites More sharing options...
SeanM Posted August 10, 2016 Author Share Posted August 10, 2016 Thanks Phil Slowly adding bits and pieces and also started the weathering 3 Link to comment Share on other sites More sharing options...
