Booty003 Posted June 6, 2016 Share Posted June 6, 2016 I have been commissioned to build this for a chap and made a start the other night. This is my first build of a low run kit so am experiencing the pleasure that come with such a run...... Seat is decent enough and there will be PE to go on here once painted. An awful design of the vertical stab, the gap will need filling and carefully sanding back to look anywhere near reasonable. One upper lift engine built (minus compressor blades underneath) and every part of this needed trimming in order to fit. Lower lift fans, again every keyed part needed trimming..... Lower lift fan guides need completely removing from the lower wing area in order to fit...... Lots of removed plastic from just assembling the fan parts. Main wheel housings, yep, more trimming...... Assembled. I suspect that this will push me the more I do but time will tell..... Wish me luck....... Phil 4 Link to comment Share on other sites More sharing options...
Flankerman Posted June 6, 2016 Share Posted June 6, 2016 Phil, welcome to the wonderful world of Modelsvit and Amodel kit building. It's very character forming - so persevere with it and you'll end up with an unusual model that will attract comments wherever it is displayed. Or..... wait until Tamiya or Hasegawa produce kits of these subjects ........ Ken 1 Link to comment Share on other sites More sharing options...
Radleigh Posted June 6, 2016 Share Posted June 6, 2016 I love these odd ball subjects these two companies are giving us. Looking forward to seeing this done, first time I've seen this kit. Link to comment Share on other sites More sharing options...
PhantomBigStu Posted June 6, 2016 Share Posted June 6, 2016 good luck booty, heard modelsvit aren't the most fun of builds Link to comment Share on other sites More sharing options...
Flankerman Posted June 6, 2016 Share Posted June 6, 2016 (edited) I suppose it depends on what you regard as 'fun' I've managed to survive building a few..... Tu-91 Boot :- http://www.flankers-site.co.uk/model_tu-91.html Tu-22KD Blinder :- http://www.flankers-site.co.uk/model_tu-22.html Bartini VVA-14 :- http://www.flankers-site.co.uk/model_vva-14_modelsvit.html MiG E-150 :- http://www.flankers-site.co.uk/model_e-150.html An-124 :- http://www.flankers-site.co.uk/modl_an-124.html ..... and I'm still here to tell the tale. They just require a bit of old-fashioned modelling - and no-one else is going to kit them - so they are really the best kits of their subjects currently available. Ken Edited June 6, 2016 by Flankerman 1 Link to comment Share on other sites More sharing options...
Booty003 Posted June 6, 2016 Author Share Posted June 6, 2016 Ken - your Tu-22 is an absolute work of art. The actual aircraft is almost something from science fiction. I was thinking of buying that actual kit but am more than happy to leave it on the shelf now.....!!! I will just look at yours when I feel then need...!! Link to comment Share on other sites More sharing options...
Flankerman Posted June 6, 2016 Share Posted June 6, 2016 I was hoping to inspire you - not put you off !!! If I can do it..... anyone can. Ken Link to comment Share on other sites More sharing options...
Booty003 Posted June 7, 2016 Author Share Posted June 7, 2016 LoL...!! Primed up several parts last night and will be splashing some colour around later on this evening. Will have a few more piccies tomorrow. Link to comment Share on other sites More sharing options...
Booty003 Posted June 8, 2016 Author Share Posted June 8, 2016 A little bit more progress last night. Seat about 80% finished, need to add some more PE and buckle detail to the straps etc: Lift fans taking shape: Some nice PE for the flame holder. I have left this unpainted as it gives some nice contrast looking down into the exhaust pipe: Cheers all, Phil 2 Link to comment Share on other sites More sharing options...
Booty003 Posted June 10, 2016 Author Share Posted June 10, 2016 Some more progress from last night. I'm calling the seat finished: Lift fans and main U/C bays: Upper lift fan housings in place: An example of yet more poor fitment of this kit, rear fuselage okay at the top: Bottom will need some work just to get the thing to fit flush..... Cheers all, Phil 3 Link to comment Share on other sites More sharing options...
Booty003 Posted January 30, 2017 Author Share Posted January 30, 2017 Oh wow, when was this last update....????  This kit is pushing me to the limit with the amount of work required. It would of been quicker to get a solid block of plastic and whittle it away to make a Mirage....!!  Anyhoo, on we go.....  Wings joined to fuselage - this didn't fit at all well and needed parts trimming and then gluing in stages to get a relatively decent join.    Even then there was a big step and gap that has needed filler and now superglue.....   Same is true for the rear of the fuse.   Oh and the intakes.....   I am just about at the primer, check and re-scribing stage.  Phil 5 Link to comment Share on other sites More sharing options...
AdrianMF Posted January 30, 2017 Share Posted January 30, 2017 May be taking a while but it's looking good. I've just finished one that has been sitting in a corner on and off since 2012, so don't give up on it! Â Regards, Adrian 1 Link to comment Share on other sites More sharing options...
Martian Posted January 30, 2017 Share Posted January 30, 2017 I think its looking great, well worth the effort you have put into it so far! Â Martian 1 Link to comment Share on other sites More sharing options...
Booty003 Posted February 7, 2017 Author Share Posted February 7, 2017 Having a big push to get this finished and off the bench now. Â Lift fan upper door housings prior to clean up and install: Â Â Â Â All 4 installed: Â Â Â A plastic frame sits on top of the extended door things (!!!) and this PE needs delicately bending into the correct shape and then fitting on!!: Â Â Â Phil 3 Link to comment Share on other sites More sharing options...
Radleigh Posted February 7, 2017 Share Posted February 7, 2017 Good old Modelsvit. Great work and great subject. Link to comment Share on other sites More sharing options...
Martian Posted February 7, 2017 Share Posted February 7, 2017 I have to say that this build is beginning to look rather tasty! Â Martian Link to comment Share on other sites More sharing options...
Booty003 Posted February 20, 2017 Author Share Posted February 20, 2017 Extensive fillers, superglue and sanding....!!! Â Initial coat of primer applied to see how its all looking and I must say that I am quite pleased so far, especially around the forward intakes. Â I have applied some Mr Dissolved Putty into the areas needing additional work and once fully dry and hardened will be sanded back. Â Â Â Â I can actually see a light at the end of the tunnel now... Â Cheers all, Â Phil 1 Link to comment Share on other sites More sharing options...
Martian Posted February 20, 2017 Share Posted February 20, 2017 That coat of primer has made all the difference! Â Martian Link to comment Share on other sites More sharing options...
Booty003 Posted March 29, 2017 Author Share Posted March 29, 2017 (edited) After a very long break, the wonderful smells of model making are once again in the air. Put some colour on the fuselage last night to highlight any flaws, panel lines that need re-scribing etc. and there are a few....!!! I will spend tonight tidying those up ready for the proper paint job. The aircraft is a patchwork of different colours and shades - going to be a PITA.....  Phil Edited March 29, 2017 by Booty003 Link to comment Share on other sites More sharing options...
Booty003 Posted April 6, 2017 Author Share Posted April 6, 2017 Back into the swing of things now!!  The first coat of primer identified the areas that needed additional work. I have now re-scribed some missing panels - they just need a little tidy up and then I will be hitting it with some paint!!      There was a massive gap and step here - very happy with how it has turned out:   I WILL beat this kit.....!!  Phil Link to comment Share on other sites More sharing options...
Booty003 Posted April 19, 2017 Author Share Posted April 19, 2017 I had a great Easter Monday to give some proper time to this kit, got loads done and here she is as of this morning. Â Not only is the actual build overly complicated; the actual paint application has been a challenge too.....!! Â Â Â Â Â 5 Link to comment Share on other sites More sharing options...
AngstROM Posted April 19, 2017 Share Posted April 19, 2017 Fascinating; I had no idea this kit existed until a couple of days ago when I found something about it by accident on 'the Internets'. And here is one well under way -excellent progress indeed, but the experience has sort of informed my purchase decision.  I do like that seat, though...and the rest of it is looking really good...GAAAHHH! 1 Link to comment Share on other sites More sharing options...
Booty003 Posted April 24, 2017 Author Share Posted April 24, 2017 I keep chipping away at this when I find some spare time - a bit more added from the weekend. Â Â Â I did want the main U/C doors closed but they wouldn't fit due to the design of the kit - the support brace for the main gear is in the way...... Â Â Â Â Â The seat may also need some attention to fit in the pit properly..... Â Â Cheers all, Â Phil 2 Link to comment Share on other sites More sharing options...
Booty003 Posted April 27, 2017 Author Share Posted April 27, 2017 With pretty much all of the main painting jobs completed it was time to move onto the area of the main lift engines. Â Â The kit provided a basic plastic covering and also some photo etch that would need carefully bending into shape...!! Â Â Â The PE needs mounting to a plastic frame first: Â Â it also needs a slight curve putting into it: Â Â Â Each of the louvres needed carefully bending into place: Â Â Mounted to the plastic frame using superglue: Â Â The finished effect is fantastic: Â Â There is no comparison between the plastic and PE parts: Â Â Â Â Â Finally ready for some decals: Â Â Â Â Â Cheers all, Â Phil Link to comment Share on other sites More sharing options...
Robert Posted April 27, 2017 Share Posted April 27, 2017 Excellent work there Phil those PE vanes and the paint work looks great. 1 Link to comment Share on other sites More sharing options...
