Sign in to follow this
Followers 0
Hobbycolours
New Products from HOBBY Colours
1 post in this topic
Our new products release in May 2016:
  1. Decal Setting Solution (30ml)
Setting Solutions to improve the adhesion of decals to the surface of a model.
Instructions:
It is designed to be applied to the model's surface by brush before applying the decal. Improves the adhesion of decals to the surface of a model and helps them to conform to curves, panel lines and other surface features. The Setting Solution can easy remove old decals as long there is no layer with varnish on top of the decal.
- Shake well before use
- Net Weight: 30ml
- Shipping Weight: 45ml
Safety Instructions:
- Keep them out of reach of children.
- Avoid skin contact, eye contact and inhalation.
- Use it in well ventilated areas only.
Manufactured by: HOBBY Colours Made%20in%20Greece.jpg
2. Acrylic Retarder (30ml)
Use to slow the drying time of acrylic paints. An agent that increases ‘open‘ (working) time of acrylic paint.
Instructions:
The Acrylic Retarder is used to counter the fast drying properties of acrylic paints, making possible the use of airbrush. Increases blending time, making blending of colors and detail brushwork easier. Do not mix more than 25% per volume into acrylic paint otherwise paint may not fully dry.
- Net Weight: 30ml
Followers 0
