DogTailRed2 Posted May 15, 2016 Share Posted May 15, 2016 I want to wipe down my model, to remover finger prints, prior to priming with Alclad II black primer. Will Isopropyl Alcohol affect Alclad Primer or Paints and should I use it in this manner? Many thanks. Link to comment Share on other sites More sharing options...
dogsbody Posted May 15, 2016 Share Posted May 15, 2016 When you posted " IPA", my first thought was India Pale Ale and I was thinking that it probably wouldn't do your Alclad much good. Chris 3 Link to comment Share on other sites More sharing options...
Stew Dapple Posted May 15, 2016 Share Posted May 15, 2016 Hi mate, IPA shouldn't affect the Alclad (Alclad is laquer/cellulose based not alcohol-based). IPA is great for de-greasing, I use it in place of the soapy-water-sprue-wash before starting a kit. Cheers, Stew Link to comment Share on other sites More sharing options...
viscount806x Posted May 15, 2016 Share Posted May 15, 2016 Probably not but why not try it on a painted sample patch first to give 100% confidence. If it works OK, award yourself one of Chris Dogsbody's India Pale Ales by way of a small celebration.... 1 Link to comment Share on other sites More sharing options...
Tomjw Posted May 18, 2016 Share Posted May 18, 2016 It'll be fine. I do the same. Just make sure the IPA has completely dried before applying the primer. Hth, Tom. Link to comment Share on other sites More sharing options...
DogTailRed2 Posted May 21, 2016 Author Share Posted May 21, 2016 Thanks. tried it and it's fine. :-) Link to comment Share on other sites More sharing options...
