DDELK Posted May 11, 2016 Share Posted May 11, 2016 Is it best to use the alclad gloss black as a base ? Or can I use any other gloss black paint Link to comment Share on other sites More sharing options...
Space Ranger Posted May 11, 2016 Share Posted May 11, 2016 Gloss black is necessary only if you are spraying Chrome. All other Alclad shades look good over primer. Or you might try other gloss colors as a base to vary the effect. Link to comment Share on other sites More sharing options...
infofrog Posted May 12, 2016 Share Posted May 12, 2016 I maybe wrong here . I think Alclad covers better and faster over black base .. Thats the only advantage, but not necessary. As Space Ranger says , its necessary for chrome look That maybe my not seeing so go eye these days Rick Link to comment Share on other sites More sharing options...
DDELK Posted May 12, 2016 Author Share Posted May 12, 2016 I don't need the chrome look. I'm painting a F-86D Sabre. It's going to have the NMF. I like the look of the polished aluminum Link to comment Share on other sites More sharing options...
infofrog Posted May 12, 2016 Share Posted May 12, 2016 I don't need the chrome look. I'm painting a F-86D Sabre. It's going to have the NMF. I like the look of the polished aluminum This is what I would do I would spray the plane with a black base .. I use Tamiya black with 10 percent Tamiya clear and X20A thinner . Let Dry and polish the black smooth . Then spray Alclad . Rick 5 Link to comment Share on other sites More sharing options...
DDELK Posted May 12, 2016 Author Share Posted May 12, 2016 I think that's the way I will go then. Your P-51 is exactly the color I'm looking for. How did you polish the black if you don't mind my asking. Thanks Dave 1 Link to comment Share on other sites More sharing options...
pacificmustang Posted May 12, 2016 Share Posted May 12, 2016 Dave. all the "hi shine" colours, of which polished aluminum is one, need to be sprayed over a gloss black base. This can be either Alclad's own or another gloss black base Hope this helps Bruce Link to comment Share on other sites More sharing options...
Alan P Posted May 12, 2016 Share Posted May 12, 2016 (edited) Definitely gloss black base.Doesn't have to be Alclad's own brand, could just be any black paint with an acrylic or lacquer gloss coat. Needs to be very smooth though. Edited May 20, 2016 by Alan P Link to comment Share on other sites More sharing options...
Séan Pádraig Posted May 12, 2016 Share Posted May 12, 2016 I always test on plastic spoons... helped me when I was trying fluorescent orange... Link to comment Share on other sites More sharing options...
infofrog Posted May 12, 2016 Share Posted May 12, 2016 I think that's the way I will go then. Your P-51 is exactly the color I'm looking for. How did you polish the black if you don't mind my asking. Thanks Dave 2000 wet sand paper Link to comment Share on other sites More sharing options...
DDELK Posted May 12, 2016 Author Share Posted May 12, 2016 You guys have all been very helpful. Thanks for the info, I will post a picture in the next couple days Thanks Dave Link to comment Share on other sites More sharing options...
Muzz Posted May 12, 2016 Share Posted May 12, 2016 I was disappointed with Alclads black gloss primer, didn't dry properly and stayed pretty tacky. I've went back to using Tamiya's gloss black. Link to comment Share on other sites More sharing options...
Pin Posted May 12, 2016 Share Posted May 12, 2016 I was disappointed with Alclads black gloss primer, didn't dry properly and stayed pretty tacky. I've went back to using Tamiya's gloss black. I had similar experience but I gave it another try and guess what - I started to loving it! 1 Link to comment Share on other sites More sharing options...
DDELK Posted May 12, 2016 Author Share Posted May 12, 2016 Did the alclad gloss black lay down smooth or did you have to polish it smooth? Link to comment Share on other sites More sharing options...
DDELK Posted May 12, 2016 Author Share Posted May 12, 2016 These are the markings/paint that I'm going with. It's the S.C Air Guard aircraft.. Link to comment Share on other sites More sharing options...
Pin Posted May 12, 2016 Share Posted May 12, 2016 It lays down mirror smooth. One may need to polish minor imperfections Link to comment Share on other sites More sharing options...
ICMF Posted May 12, 2016 Share Posted May 12, 2016 HIGH SHINE ALCLAD FINISHES ALC-105 POLISHED ALUMINIUM ALC-107 CHROME FOR PLASTIC ALC-109 POLISHED BRASS ALC-114 CHROME FOR LEXAN ALC-115 STAINLESS STEEL ALC-118 GOLD TITANIUM ALC-119 AIRFRAME ALUMINIUM ALC-122 MIRRORED GOLD FOR LEXAN Apply one of these primers before using High Shine ALCLAD: ALCLAD GLOSS BLACK BASE ALC-304/305 ALCLAD CLEAR BASE ALC-303 (Other hobby enamel paints are suitable-it is advisable to conduct a test on scrap plastic) PREPARATION AND SPRAYING The surfaces to be painted must be thoroughly clean and free from dust,grease,oil and finger marks. Apply the correct primer for the type of Alclad being used. ALCLAD should be sprayed at 12-15psi. Spray from a distance of 2-3 inches from the surface being painted using a narrow to medium width spray fan. Use the airbrush like a paint brush-aim to cover the model in a methodical manner. Buffing is not necessary-tonal variation can be made by polishing selected panels with Micromesh. REGULAR ALCLAD can be masked over and painted. Decal solutions ... are not recommended for HIGH SHINE ALCLAD Link to comment Share on other sites More sharing options...
S5 modeller Posted May 21, 2016 Share Posted May 21, 2016 (edited) Hi chaps. I'm going to be using gloss black base soon, and came across this thread in a search. If I'm reading it right, is it best to put a clear lacquer over the black base? I'm going to be using alclad polished aluminium, if that helps. Matt Edited May 21, 2016 by S5 modeller 1 Link to comment Share on other sites More sharing options...
Artie Posted May 21, 2016 Share Posted May 21, 2016 I've used Tamiya Gloss Black, decanted from spray can.......works fine and gives you a hard, handling friendly finish... 1 Link to comment Share on other sites More sharing options...
ICMF Posted May 21, 2016 Share Posted May 21, 2016 Hi chaps. I'm going to be using gloss black base soon, and came across this thread in a search. If I'm reading it right, is it best to put a clear lacquer over the black base? I'm going to be using alclad polished aluminium, if that helps. Matt HIGH SHINE ALCLAD FINISHES ALC-105 POLISHED ALUMINIUM Apply one of these primers before using High Shine ALCLAD: ALCLAD GLOSS BLACK BASE ALC-304/305 ALCLAD CLEAR BASE ALC-303 (Other hobby enamel paints are suitable-it is advisable to conduct a test on scrap plastic) PREPARATION AND SPRAYING The surfaces to be painted must be thoroughly clean and free from dust,grease,oil and finger marks. Apply the correct primer for the type of Alclad being used. Link to comment Share on other sites More sharing options...
DDELK Posted May 21, 2016 Author Share Posted May 21, 2016 This was the results I ended up with, as I was the one to start this thread. I was pretty pleased with the results, as it was only my second attempt at using alclad. I've still got a long way to go before s get it mastered down but in the meantime I can't complain to much.. 1 Link to comment Share on other sites More sharing options...
infofrog Posted May 22, 2016 Share Posted May 22, 2016 This was the results I ended up with, as I was the one to start this thread. I was pretty pleased with the results, as it was only my second attempt at using alclad. I've still got a long way to go before s get it mastered down but in the meantime I can't complain to much. This was the results I ended up with, as I was the one to start this thread. I was pretty pleased with the results, as it was only my second attempt at using alclad. I've still got a long way to go before s get it mastered down but in the meantime I can't complain to much.. looks great Rick Looks great Link to comment Share on other sites More sharing options...
DogTailRed2 Posted May 25, 2016 Share Posted May 25, 2016 Is it okay to use Alclad Black primer and then Alclad Clear for Polished Aluminium, or should I use Humbrol Gloss Black over the primer? I ask because I have painted Alclad Black Primer and then realised it's a matt base. Link to comment Share on other sites More sharing options...
dfqweofekwpeweiop4 Posted May 25, 2016 Share Posted May 25, 2016 This is what I would do I would spray the plane with a black base .. I use Tamiya black with 10 percent Tamiya clear and X20A thinner . Let Dry and polish the black smooth . Then spray Alclad . Rick Nice Mustang but it's name appears to be missing some letters! Regards the topic - I've had no bother with Alcald Gloss Black Base and use it prior to using Alclad Aluminium, that works fine for me but I find the shiny Alclads don't work too well for me. thanks Mike 1 Link to comment Share on other sites More sharing options...
turnerdad Posted May 25, 2016 Share Posted May 25, 2016 Are you planning on applying main markings as decals or transfers? Reason I ask is if masking (or more likely, When masking), I would recommend "de-tacking" the tape first. Link to comment Share on other sites More sharing options...
