Welcome to Britmodeller.com
Register now to gain access to all of our features. Once registered and logged in, you will be able to contribute to this site by submitting your own content or replying to existing content. You'll be able to customize your profile, receive reputation points as a reward for submitting content, while also communicating with other members via your own private inbox, plus much more! This message will be removed once you have signed in.
  • Announcements
    • Mike
      PhotoBucket are no longer permitting 3rd party hosting   01/07/17
      As most of you are now painfully aware, Photobucket (PB) are stopping/have stopped allowing their members to link their accumulated years of photos into forums and the like, which they call 3rd party linking.  You can give them a non-refundable $399 a year to allow links, but I doubt that many will be rushing to take them up on that offer.  If you've previously paid them for the Pro account, it looks like you've got until your renewal to find another place to host your files, but you too will be subject to this ban unless you fork over a lot of cash.   PB seem to be making a concerted move to another type of customer, having been the butt of much displeasure over the years of a constantly worsening user interface, sloth and advertising pop-ups, with the result that they clearly don't give a hoot about the free members anymore.  If you don't have web space included in your internet package, you need to start looking for another photo host, but choose carefully, as some may follow suit and ditch their "free" members at some point.  The lesson there is keep local backups on your hard drive of everything you upload, so you can walk away if the same thing happens.   There's a thread on the subject here, so please use that to curse them, look for solutions or generall grouse about their mental capacity.   Not a nice situation for the forum users that hosted all their photos there, and there will now be a host of useless threads that relied heavily on photos from PB, but as there's not much we can do other than petition for a more equitable solution, I suggest we make the best of what we have and move on.  One thing is for certain.  It won't win them any friends, but they may not care at this point.    Mike.
TristanR
U-991 1/72 Type VIIc U-Boat - Revell
140 posts in this topic
Luckily an end of war u-boat, covered in salt and rust can just about get away with the rough paint job I have!
It's not rough in the slightest it looks great! It was just that earlier in the thread you said:
I mix it with about 30% thinner, the x-20 stuff. I tried water but it's a lot mushier during chipping for me. It has to go on at a high pressure with a lot of paint flow, which means you have to be quick to add a thin coat.
I think the leveling thinner would have made that job easier. Also, I find that regardless of what thinner you're using Tamiya needs about 60/40 thinner/paint as a minimum on most colours. Doing so would have allowed you that little bit more control (you would have been able to lower the pressure substantially for one thing) and made applying the winter white a little easier :)
1 person likes this
I think I will try that, I don't think I've ever thinned the paint that much, so it's good to know I can. I do find XF2 flat white a lot harder to spray than most other tamiya colours. I will definitely try it with levelling thinner. Still so much to learn!
Thanks!
It is rough though, doesn't really come through on the pictures but compared to the sky grey underneath it's a lot chalkier finish.
1 person likes this
If you've not already coated it with varnish or the like (and it's really bothering you) you could always try wet sanding it a bit with 8-12,000 grit micromesh. The problem with that of course is that with the hairspray you might well end up stripping it all off....so it might not be best to do that on second thought.
But as you say, this is a well used boat, so it's probably appropriate.
Just come across this build and must say how impressive the U Boat is looking! Love the detail and weathering.
This september marks one year since I started this!
Anyway, some progress,
I got the 3D printed intake pipe on, Ialmost lines up, It's a little of centre with the schnorkel mast, and a little too forward, but I think I will modify the schnorkel to fit
F158750F-44C4-46BA-8381-7852B1F3E3E3_zps
C2BEC382-4E69-40B5-A40E-635ED869FE72_zps
There is more soldering to be done, there are 2 more guard rails. The top one is on another laser cut buck I made, it's a very difficult shape to do, as the railing is at a angle and flares out in the middle.
In the deck I cut the postions for all the vertical posts that make up this railing, I copied those positions and included them in this buck, you can see the holes underneath.  This way I can insert the brass into these holes and when it's all soldered together, it should just drop into the corresponding holes on the deck.
219A588D-EECB-4B72-946A-03F10150B767_zps
These rails sit just forward of the tower, and have a wires rails connected to the other railing, hense the little tabs that were spares on the eduard set.
DAE03CA2-7436-4CBA-88E3-BECDE7BEF681_zps
Here's one installed, it wasn't a great fit but lose enough after a fight.
A5EFA983-DA19-4095-A83A-5D4AA55F8511_zps
Underneath you can see how it's held bu the laser cut holes.
D7928661-478F-45DB-9C56-41969D04AC4B_zps
The heat transfer problem I've bee having with these wood bucks went away when I switched to this blowtorch soldering iron
025F6277-32F6-450F-924D-E16792A715D6_zps
here they are in place, that's a lot of railing. Got to do the other side now.
960B91EF-450F-4ACC-8B0F-F73C0DF1571F_zps
422836F2-8B2C-4D3A-B77C-CA61AEAB15A8_zps
I've been further painting the deck, the photos are not showing it but the deck is a lot browner, and I started putting eduard little hinges on the hatches.
110ED87A-65A8-4026-A497-13406A32ED19_zps
D1253996-D39E-492B-B0A8-17CCA0A36B95_zps
Did some weathering on the guns, and added whiter salt stains to the tops of the saddle tanks,
5BB8D0B2-6F7C-4C68-8BCE-E92C8FD6D991_zps
F1F4D526-F7A8-4DB4-886F-DA2C44ABB84B_zps
Thanks for looking!
16 people like this
Great skills on display here, I keep forgetting this is 1/72 :goodjob:
Kev
1 person likes this
I done another video, bit crappy still, as only 12% seems to be in focus, hopefully you get the idea though...
5 people like this
:goodjob:
1 person likes this
Tristan - this is turning out to be one of the most beautifully weathered models I've seen.  Once again really helpful video.  Astonishing work.  One thing I really like is the texture of roughened peeling paint - Superb!!:worthy:
Rob
Holy cow, look at that deck and tower. This by far, hands down, the best sub model I have ever seen. You are very skillful model my friend. I sure will hope that you never get burn out with your wip as I'm loving it and learning a lot. Thanks for sharing your work ;)
Mike
Wow, more great finishing - this is looking like it is made from the actual materials that the real thing was made from, and has been to sea for extended periods like the real thing.
Stunning ... the decking, amongst everything else, in particular is impressive !
BillyD
Amazing job you've done on this boat. I'm very impressed with all the extras you've built and the weathering is superb. Very inspirational. i'm taking notes.
Thankyou all for the comments, I'm happy to report that I am back on this.  Got really busy recently, but thing have settled down enough that i was able to begin thinking about finishing this.  I have to build a structure around the schnorkel:
1C1CB991-BC5D-4E38-B4BF-61FAE7831710_zps
I build a side baffle wall for the recess, also behind it is the mounting for the deleted deck gun.
1D0621EF-6392-4FF6-84F1-F5288D425D4A_zps
35D32DA6-C566-47D7-993E-729A697B33D1_zps
Here's the baffle work under the deck, with forward torpedo loading hatch.
ADC753A4-24F6-4D59-92E5-7352340F79FB_zps
Some 3D printed hatch lids for the ammo containers came in, also the rear lamp.
7AAC495F-CBEB-452A-8DC1-356036D9177E_zps
Messing with rigging.  My 3D printed isolators have bent a bit,
i might try to straighten them ib warm water.  I think I will use EZ-line for the rigging, to keep the wholw thing in tension.  I a pain though.
F556C42C-888E-4161-8AC6-1B3DA74F81A7_zps
Cheers!
10 people like this
Hello,
It's amazing, it's a museum piece, I'm admiring.
Great congratulations.
1 person likes this
So glad you are back on this; simply stunning.
1 person likes this
Thank you for the comments guys, glad you are still with me!
It's good to be back on it, there is our local model show in april so I'm making it my deadline.  It doesn't look like I have done all that much, but I've slowly been washing the saddle tanks with watery light grey paint.  I want the tops pretty light, and it's very effective to build it up in many layers, there is about 5 or 6 thin washes, with heavier wash around the welds and hatches I scribed in.
BKFZBmA.jpg?1
Some of the chipping is out of scale, so I figured I'd try some fine vertical streaks. I tried some colured pencil, some caran dasche watercolor pencils, But it wasn't quite a match for the lifecolor rust I have been using so far.  So I swtiched back to lifecolor and found a longish brush with a good point (sometimes you have to go through a few brushes for this).  with a bit of practice you can flick thin, vertical streaks pretty well,  having a longer brush adds a bit of spring which soaks up some of the wobble from your hand.
QdhQ5IL.jpg?1
You can see the slightly oranger pencil work around the doubled slot to the centre-right of the picture.  There is a horizontal strip feature just under the slots, and underneath it, at the bottom of the white is a slightly greenish umber, that is also colored pencil.  The streaks a drew on were wrongish, so with water, I washed them out leaving this greenish stain, whch although a mistake I quite like it.
With the salt washing, I'm always striving to hide brushstrokes, even if it means washing it all away.  Because the surface is so matt, a small amount remains.  Tide marks are a giveaway, so I usually try to wash away all of those.  Right in the middle there is the sloping lap joint I added. It collects all sorts of wash debris, and over time the build up looks better and better, it's even crept up to the rivets a bit, maybe even resembling barnacle build up.
JgNTJ3g.jpg?1
6 people like this
Quite exceptional, sublime weathering, you can virtually smell the sea just looking at this!
A very convincing rust finish  :book:
beefy
Thanks for the comments guys, nearly there.
last big job is the under-deck plumbing.  I haven't decided what hatches will be open or not, so I will build a bit of support around possible open hatches.  The wood deck is so thick I can't really use them as open hatches, but I can leave some missing perhaps.
This side of the snorkel hatch is pretty much boxed in now.
17A4C474-9AEC-4727-B29B-6EB434E7A9CF_zps
But the other side is probably more visible, so I will add some support ribs in 1mm strips
EC6E45BA-1A01-48BF-81C4-C54EA62A24E3_zps
4A66965E-E158-4225-84E0-E2143B80B11C_zps
This is the hatch around the torpedo loading hatch.  I think this is supposed to be boxed in
9A2788FB-29E3-4E6A-9B30-8E38ED0C87F4_zps
So I build some sidewalls, its a bit of a mess but does the job.
44068B47-2A78-45C9-BC07-01AA4A0FFF80_zps
The capstan retracts under the deck.  I made a 90 degree box frame and brass rod running forward to the anchor windlass in the bow (if that's what it's called).  My 3D printed capstan sits on another brass rod, and fits into a brass lined tube glued to the top of the box frame.
50382AAD-455A-4E82-940F-F9C351AC87B5_zps
When the deck is on the capstan slots in here, the brass has a nice friction so I can slide it in and out.
C6E7E035-2E31-4305-BD91-2B7E63360170_zps
Yessss.
2BD24C43-CFA5-44B7-9A4D-B20DB14CA853_zps
7D598DD9-F198-4C25-A55E-2EC80754D8F4_zps
Cheers!
2 people like this
OK time to paint these underdeck areas.
B4F8B2B1-E05A-42A3-8784-36DC1E134B8E_zps
An undercoat of hull red and flat black,
A6BF6A5F-555C-4783-8F9F-FDB429CC4720_zps
 Then hairspray, for chipped sky grey.
FBCCF852-92CD-439C-B1A5-786C41BAC4FD_zps
009B5E47-4E60-4523-B1EF-CB0E2C2AC13A_zps
On with some rust washes.
6EB120AE-C74E-4E69-9BFF-0F574E07CC3D_zps
C641C09C-AC17-4F41-9F85-8B571BD28967_zps
I took the boat to my local IPMS meeting, and saw it in a well lit room at a distance, for the first time.  I was struck how toneless the hull looked. Up close it's got a lot going on but from a distance it needs contrast.  To fix it I will apply some black oil streaking.  Just little dots, blended with a dry brush.
4B67C9AC-A68B-4BB6-BAC7-230082614AA1_zps
949E74D3-1FC5-4858-9596-03EDE7334096_zps
2834854B-E65D-4222-9B4C-F4DCCF1E67C7_zps
Before
4A5E793D-35C6-46C2-B126-9818C9E7C193_zps
After
FB53E869-0A11-435F-8432-EB74CEDCA928_zps
I think I need to be carful not to overdo this, and maybe not be quite so uniform in streak distribution.
here's a shot of the tower attached without any decking.
65FE2385-055C-4C87-9FA9-96BB0A9640D0_zps
Cheers!
6 people like this
