TEMPESTMK5
Spit Vb P O Jacques Andrieux Sqn 130 Sept 1942
Good evening
I am taking part to this Gb with a Spit Vb Tamiya I will try to represent the aircraft flown by the Pilot Officer Jacques Andrieux https://en.wikipedia.org/wiki/Jacques_Andrieux
I will replace the Ip by a Yahu models one https://www.scalemates.com/kits/944642-yahu-models-yma7249-spitfire-mk-v, and use Eduard Pe seat belts and the Berna decals sheet 984347004.jpg
Today I painted the cockpit with in Green Interieor Humbrol 78 .
Patrice
Welcome along Patrice. Good to see a French pilot being represented with this one :)
Welcome aboard!
Thank you Gingerbob
Patrice
Good to see another model being built here ! Looking forward to the first pictures
Thank you Giorgio
Patrice
Thank you Col
Patrice
Good evening
I changed my mind and decided to use a Quickboost seat and today I painted it
I also prepared the Ip ( I really like these Yahu Ips ..)
I placed the seat , Ip and control column
Yesterday I had painted the fuselage interior
Patrice
Edited by TEMPESTMK5
Good progress there and have to agree with your choices of after-market parts; the Yahu panel is stunning and the Quickboost seat essential to replace the strange shelf that Tamiya would have a Spitfire pilot perch upon.
Good evening
This Week end I placed the wings on the fuselage
Patrice
Suddenly you have a Spitfire :thumbsup:
I can only echo Col's comments, the cockpit is very good and the seat in particular really looks the part. Quickboost parts really are a great way of adding detail at little cost.
Good morning
Thank you for your comments ..
I would like to know if I should delete the 2 parallel lines on the top of the wings between the cannon fairings and the pear shaped bump ?
Patrice
Good morning
Patrice
When did Andrieux fly this aircraft ? The two stiffeners were introduced as a modification in early 1942, any aircraft serving before that date would not have any stiffener. Aircrafts in service after this date may or not have these retrofitted
Hi Giorgio
Thank you I will check when Andrieux flew this aircraft ..
Patrice
Hi Patrice. Hadn't realised you were making this Tamiya kit as well. It's rather good isn't it?.........and you're making very good progress - much quicker than me! :thumbsup:
Good morning
Thank you ..
I think the Tamiya kits are the best , easy to build , accurate the only point is their price when you want to buy them in Europe but you can find some interesting opportunities on Ebay ..
Patrice
Hi Patrice,
Spitfire Vb BL736 was sent first to no.33 Maintenance Unit in February 1942 and issued to 130 Squadron on 25 March 1942. Based on that I think you will be okay with the stiffeners.
More info here...
Stew
Hi Patrice,
More info here...
Stew
Good morning Stew
Thanks a lot for your infos :thumbsup: :thumbsup:
Patrice
Good evening
I decided to let the stiffeners in place .
This Week end I made a preshadding and started painting the underside in grey ..
Patrice
Good evening
Today I started painting with Humbrol Grey 106
Patrice
Good morning Stew
Thank you
Patrice
Good morning
I had no time to work on this build yesterday I will try to go on painting this Week end ..
Patrice
Good to see more progress - you are certainly way ahead of me now. I ended up removing the stiffeners from mine - it took a bit of careful trimming and I only twice caught detail on the surface that was supposed to remain in place!! A little bit of filler and a bit of sanding down sorted it all out though. Looking forward to seeing more of the paint going on yours. I may try and do some pre-shading on mine this weekend.
Kind regards,
Stix
Kind regards,
Stix
Good afternoon Stix
Thank you ,removing the stifeners took you the time I spent on painting I think you will not take long before you catch me up .
The weather forecasts are not good for the weekend I think I will be able to do some more painting ..
Regards
Patrice
