rossm Posted March 26, 2016 Share Posted March 26, 2016 I'm not really into civil aircraft so please can anyone help interpret these photos http://www.aviationphotocompany.com/p946416424/h21C6B486#h21c6b486 and http://www.airteamimages.com/handley-page-herald_G-ATIG_brymon-airways_206185_large.html There are some subtle differences but I hope to fix on one of them From the top down: Fin - yellow - any comments on a possible match in Xtrumbiya or other manufs ranges? Upper fuse & wings - white Leading edges - presumably black de-icing boot Underwing registration - black? Nacelles - polished ally / pale grey or white Line - dark blue - model paint matches? Tailplanes - black? with or without white tips Line - white Line - yellow Radome - satin black Line - white Lower fuselage - pale blue/grey? - matches? Fuselage code - dark blue? Bottom of fuselage - mid-grey? - matches? Does the reg code appear under both wings? TIA Ross Link to comment Share on other sites More sharing options...
AMB Posted March 26, 2016 Share Posted March 26, 2016 I'm not really into civil aircraft so please can anyone help interpret these photos http://www.aviationphotocompany.com/p946416424/h21C6B486#h21c6b486 and http://www.airteamimages.com/handley-page-herald_G-ATIG_brymon-airways_206185_large.html There are some subtle differences but I hope to fix on one of them From the top down: Fin - yellow - any comments on a possible match in Xtrumbiya or other manufs ranges? Humbrol Golden Yellow, probably as close as you'll get. Upper fuse & wings - white - Correct Leading edges - presumably black de-icing boot - correct Underwing registration - black? - correct Nacelles - polished ally / pale grey or white - engines Light Aircraft Grey (Xtracolour) with polished nacelles Line - dark blue - model paint matches? Xtracolour Oxford Blue, or Humbrol Midnite Blue Tailplanes - black? with or without white tips - not sure, but I would say tailplanes are same dark blue as the cheatline, no white tips Line - white- correct Line - yellow - correct Radome - satin black -correct Line - white - correct Lower fuselage - pale blue/grey? - matches? Xtracolour Light Aircraft Grey Fuselage code - dark blue? black Bottom of fuselage - mid-grey? - matches? Not sure, but this possibly may be left natural metal, due to stones chipping any paint away here. Does the reg code appear under both wings? No, just beneath the port wing. TIA Ross 1 Link to comment Share on other sites More sharing options...
rossm Posted March 29, 2016 Author Share Posted March 29, 2016 Thanks for the comprehensive reply, Ross Link to comment Share on other sites More sharing options...
ANDYMO1962 Posted April 3, 2016 Share Posted April 3, 2016 Hi Ross- I'd add a couple of comments to Adrian's reply: I think HP painted the tailplane (gloss) black as it sits right behind the engine exhausts and gets covered in soot anyway- at least a close walk round G-APWA @ Woodley seems to suggest that. You can see the black is duller in the outboard section where it is behind the exhaust; The paler yellow of the two photos looks more like the Brymon yellow- that orangey colour is misleading The underside is all the same grey but since Heralds are not rounded underside but have an angled cross section to the belly they always look like there's a darker grey lower down - that plus the reflection of the aircraft's shadow - it's a trick of the light which you get with almost any grey-bellied Herald! 1 Link to comment Share on other sites More sharing options...
rossm Posted April 8, 2016 Author Share Posted April 8, 2016 Thanks for the extra comments, Ross Link to comment Share on other sites More sharing options...
AMB Posted June 1, 2016 Share Posted June 1, 2016 Hi Ross- I'd add a couple of comments to Adrian's reply: I think HP painted the tailplane (gloss) black as it sits right behind the engine exhausts and gets covered in soot anyway- at least a close walk round G-APWA @ Woodley seems to suggest that. You can see the black is duller in the outboard section where it is behind the exhaust; The paler yellow of the two photos looks more like the Brymon yellow- that orangey colour is misleading The underside is all the same grey but since Heralds are not rounded underside but have an angled cross section to the belly they always look like there's a darker grey lower down - that plus the reflection of the aircraft's shadow - it's a trick of the light which you get with almost any grey-bellied Herald! Andy, The black tailplane on G-APWA preserved at Woodley is part of the BEA livery of the day and not applied by HP. The colour of Herald tailplanes was the choice of the airline and I don't think painted to hide exhaust stains, although the airline may well have decided on that. Link to comment Share on other sites More sharing options...
alancmlaird Posted September 17, 2016 Share Posted September 17, 2016 Although the BEA Heralds had black-painted tailplanes, none of the rest of BEA's fleet had at that time, so Andy may well be correct about the sooty exhaust residue. I remember at the time it was a bit of a puzzle to us spotters at Abbotsinch Airport (Glasgow)! Link to comment Share on other sites More sharing options...
Eric Mc Posted September 18, 2016 Share Posted September 18, 2016 I'm pretty sure the British United and British Island Airways Heralds all featured black sections to their tailplanes. Link to comment Share on other sites More sharing options...
