Those gaps aren't a problem to you rich, they're like that all the time on some kits, in fact  that would pass as quality for some manufacturers :P, nice work rich.
Glynn
As Hewy says, those seems shouldn’t be an issue - I’ve seen bigger in Italeri truck kits! And a bit of putty should sort out shapes at the bottoms of the A-pillars?
Thst said, it is a bit refreshing for us mere mortals to know that even you sometimes make parts that don’t fit perfectly!!
Thanks All, You guys are great!
Welcome back Timmas.
Hey Everyone,
  The construction of the cab interior progresses.  I have built the interior door panels and installed the windscreen frame, along with some small items that needed tidying up.
  Once I got the windscreen installed and the gaps closed up, things were, not as stressful.  The bent and crooked cab walls are straightening up a bit and all looks to be a bit more encouraging.
pmtc77qCj
Looks to be a good time to putty the seams and corners.
Time to build some doors.
po1aQRPCj
You can see, this is just sheet styrene.  The handles are rod, and the, O.S.! handle, is bent tin solder.
Fresh back from the paint shop...
pnNTgf5qj
The photo seams to show much more red that green here.
po19aDfLj
pmmcgOyCj
Then the install of the Windscreen...
pmtc77qCj
I also had to install the interior corner posts...always test fitting...
pmAkU4ldj
Fresh painted interior corner posts...installed.
pmVkThKyj
The cab to date...
pm1hIYWpj
pmijtlpaj
pn6iKmm7j
More situations to arise, ensue, and overcome, I'm sure.  I'll be back later...Thanks All!
Rich, Another enjoyable catch up time, Thanks.
Maybe with all your problem solving skills you should move to Washington?
Regards
Pete
Hey Pete, I already live in Washington.  Just not the one that causes all the problems.
Hey I work in Washington Tyne and Wear and it does have some problems but the Makems are not that bad really. :footy:
Great work as usual there Richard
beefy
Made it as far as Bend, Oregon last summer, but haven’t made it up to Washington state yet.
beefy
I used to live in Rickleton and I'm a Makem and I stayed in the W hotel opposite the Whitehouse the other week, so beat that!!
Thanks you silly guys!
I have finished with building the interior roof.  I had a couple of fun items to build, and then close up the cab.
The first thing was to putty up the cab gaps and get it all ready for sanding.
pm0953NGj
Once the putty has dried, the sanding starts...
pouQ0Kgwj
I'm not going to finish this so clean.  The nature of the wrinkles and scabs will add to Betty's used look under the paint.
pmdLw0LPj
Looks like the cab is going to fit nicely.
The building of the interior roof was simple enough.  I had some details to add here.  It all starts with a flat sheet...
pnEZVuXYj
The making of the sun screens...
pmOB3Cegj
pnsoaonCj
pn7MeRvgj
The roof is not secured in this photo, but you can see how the sun screen looks.
pnqc2cOIj
I'm starting to consider the exterior paint job.  A few more exterior details, and it's off to the paint shop. It seems I see a light ahead and I'm now starting with the finishing faze of this build.
Once I get the roof installed and closed up, it will be a race to the finish line.  Until then I still have a bunch of small details to add.
Be back later All...........
