Alex1978 Posted January 5, 2016 Share Posted January 5, 2016 I recently bought my first Dreamliner as I am planning to do the All Nippon Star Wars Dreamliner. Now for that task I need to extend the fuselage of the Revell kit. I got the Braz Models coversion set Unfortunately it doesn't contain instructions on where the cuts have to be made on the model. Anyone has some information on where the cuts have to be made ? I am not familiar with the Dreamliner,as I actually do not like this aircraft much...but the Star Wars scheme beat me to it... Any help would be appreciated. Thanks, Alex Link to comment Share on other sites More sharing options...
Romeo Alpha Yankee Posted January 5, 2016 Share Posted January 5, 2016 Alex, F-DCAL included instructions on how to create a -9 from 2 kits. I think using the instruction as a reference you could figure where to make your cuts Link to ANZ B787 decal Ray 1 Link to comment Share on other sites More sharing options...
Jessica Posted January 5, 2016 Share Posted January 5, 2016 It appears as though both sections are the same size, so anywhere in front of the wing, and anywhere behind it (as long as you stay in the constant-diameter section of the fuselage) is probably sufficient. Make certain that you get the window spacing correct when you make the cuts. 1 Link to comment Share on other sites More sharing options...
Alex1978 Posted January 5, 2016 Author Share Posted January 5, 2016 Alex, F-DCAL included instructions on how to create a -9 from 2 kits. I think using the instruction as a reference you could figure where to make your cuts Link to ANZ B787 decal Ray Thank you Ray.Thats very helpful.Alex Link to comment Share on other sites More sharing options...
Alex1978 Posted January 5, 2016 Author Share Posted January 5, 2016 It appears as though both sections are the same size, so anywhere in front of the wing, and anywhere behind it (as long as you stay in the constant-diameter section of the fuselage) is probably sufficient. Make certain that you get the window spacing correct when you make the cuts.Thank you.I will take care of that matter.Alex Link to comment Share on other sites More sharing options...
RICHW Posted January 7, 2016 Share Posted January 7, 2016 Hi i usually make my cuts just behind the windows at the front before the second door and just in front of the 4 windows on their own at the back i have never used the Braz Conversion i usually extend mine with some plastic pipe plugs then fill the gaps with body filler i think if you cut where i describe there is an engraved line on the fuselage you can use so you cut straight Richard 1 Link to comment Share on other sites More sharing options...
Alex1978 Posted January 7, 2016 Author Share Posted January 7, 2016 Hi i usually make my cuts just behind the windows at the front before the second door and just in front of the 4 windows on their own at the back i have never used the Braz Conversion i usually extend mine with some plastic pipe plugs then fill the gaps with body filler i think if you cut where i describe there is an engraved line on the fuselage you can use so you cut straight Richard Thank you very much for this explanation Link to comment Share on other sites More sharing options...
RICHW Posted January 8, 2016 Share Posted January 8, 2016 you may be able to see from this picture where i cut my model Richard 1 Link to comment Share on other sites More sharing options...
