GordonD Posted December 1, 2015 Share Posted December 1, 2015 I'm building Revell's 1:48 Messerschmitt Bf110 G-4 but I'm having problems interpreting the colour scheme in the instruction booklet. The fuselage is overall RLM65, with blobs of RLM74 on the upper part; the underside of the wings is also RLM65 and the upper surfaces are standard RLM74/75 splinter camouflage. But what colour is the upper part of the engine nacelles? There are blobs of RLM74 on there too but I can't see any demarcation on either the top or side views so I can't tell what the base colour is. Is it RLM65 or 75? In other words, does it match the remainder of the upper wing or the fuselage/lower nacelles? Link to comment Share on other sites More sharing options...
dazdot Posted December 1, 2015 Share Posted December 1, 2015 Gordon with the 110 g I would say rlm 76 undersides rather than 65. Then I would say RLM74/75 upper surfaces. With a mottle moving down the sides. Unless it's really late war or a nightfighter then I would say check any references you van find For those colours I would go for the gunze rlm colours they are to my mind spot on Link to comment Share on other sites More sharing options...
Jamie @ Sovereign Hobbies Posted December 1, 2015 Share Posted December 1, 2015 Does sound a little odd, I have to admit. RLM65 is the early baby-blue-ish colour; the Battle of Britain era one. Usually used with RLM70/71 on top (the greens). The 2-tone grey upper surfaces in RLM74/75 raises suspicion about RLM65. It might be right, but as above I'd check a few more references if possible. If it's blue underneath, it's more likely to be RLM76, the paler, greyer, very washed out looking blue. Link to comment Share on other sites More sharing options...
Troy Smith Posted December 1, 2015 Share Posted December 1, 2015 I'm building Revell's 1:48 Messerschmitt Bf110 G-4 but I'm having problems interpreting the colour scheme in the instruction booklet. The fuselage is overall RLM65, with blobs of RLM74 on the upper part; the underside of the wings is also RLM65 and the upper surfaces are standard RLM74/75 splinter camouflage. But what colour is the upper part of the engine nacelles? There are blobs of RLM74 on there too but I can't see any demarcation on either the top or side views so I can't tell what the base colour is. Is it RLM65 or 75? In other words, does it match the remainder of the upper wing or the fuselage/lower nacelles? As other have said, substitute RLM 76 for 65, the rest looks believable what actual plane? That would help. If you know the unit look here http://www.asisbiz.com/Bf-110.html Some late war bf110G had 76 undersides and solid 74 uppers, with the mottle applied at unit level here's a very faded wreck in the above scheme other side some were an overall 76, and then had squiggle over that Messerschmitt Bf 110G4 Zerstorer 6.NJG101 (9W+BO) Fritzlar 1945 there are colour pics showing this scheme as well http://ww2aircraft.net/forum/aircraft-pictures/captured-aircrafts-eeuu-32014-post1002995.html#post1002995 here's one from Falke eins blog http://falkeeins.blogspot.co.uk/2009/12/luftwaffe-colour.html this is 74 over high demarcation 76, note black lower wing on starboard only with any late war scheme, to find the photo it's taken from and work from that. HTH 2 Link to comment Share on other sites More sharing options...
Seawinder Posted December 2, 2015 Share Posted December 2, 2015 Some late war bf110G had 76 undersides and solid 74 uppers, with the mottle applied at unit level I could be wrong, but I thought the late scheme was solid 75 on top, with possible 76 squiggle/mottle stuff added later. Link to comment Share on other sites More sharing options...
Arniec Posted December 2, 2015 Share Posted December 2, 2015 (edited) There are so much variaties on the Bf-110 G. There wasn't one scheme, but many as Troy have shown you with his pictures. The late ones were indeed 76 underside and top 75. Mid war it seems that most were comming out of the factury in just 76 and some had mottle (small or big blobs) done in the field also some had a squiggle on them in green (81 or 82) or grey (75) so there are many schemes. If I were you I would have a look at a picture of the plane you want to build and take your own conclussions. I do know it's not much of a help, but if you are not sertain you can Always ask here. What was the aircraft code?! (example G9 + AA) Cheers, edit: after looking at the instruction plans I would say that the engine cover is rlm 75 with a 74 mottle. Edited December 2, 2015 by Arniec Link to comment Share on other sites More sharing options...
GordonD Posted December 2, 2015 Author Share Posted December 2, 2015 edit: after looking at the instruction plans I would say that the engine cover is rlm 75 with a 74 mottle. Thanks - that's what I'll go with. Link to comment Share on other sites More sharing options...
