PhantomBigStu Posted December 1, 2015 Share Posted December 1, 2015 (edited) Dabblee in mixing previously but nothing more than minor colour shifting, now I need to create some new colours to match a specific colour as the paints I'm looking for are either only available in enamels The colours I'm looking to mix are all IRR Nato Green Lichen Green 3sqn Green any ideas where to start Edited December 3, 2015 by PhantomBigStu Link to comment Share on other sites More sharing options...
PhantomBigStu Posted December 3, 2015 Author Share Posted December 3, 2015 bump, picked up some paints to mix Link to comment Share on other sites More sharing options...
Jusjay Posted December 5, 2015 Share Posted December 5, 2015 Are you wondering a good way to mix or finding exact colours to mix mate? Link to comment Share on other sites More sharing options...
John Laidlaw Posted December 5, 2015 Share Posted December 5, 2015 If you want to try Tamiya acrylics (assuming you can get them, and like using them), the IRR NATO Green is XF-67, and the Lichen Green is close to XF-65 Field Grey or XF-13 J.A. Green. To me, the XF-65 is closer, but that's a purely personal opinion. Link to comment Share on other sites More sharing options...
PhantomBigStu Posted December 5, 2015 Author Share Posted December 5, 2015 Cheers for the quote, can get tamiya paints fairly easily, I think my local actually stocks them in small numbers, but I've heard there unbrushable, only suited for airbrushing Link to comment Share on other sites More sharing options...
John Laidlaw Posted December 5, 2015 Share Posted December 5, 2015 Ah, sorry - yes, they're best suited for airbrushing. Some have had success handbrushing them, but I never have. 1 Link to comment Share on other sites More sharing options...
stevehnz Posted December 6, 2015 Share Posted December 6, 2015 Tamiya acylics brush ok until you go to touch up or go over a bit already done & then they don't. The answer that was given to me was to use so flow enhancer/drying retarder. The are commercial ones availble but I was put onto using bubble mix, ie kids bubble mix which has appeared to work ok for me so far. It helps it the paint to level & avoid brush marks when painting the overlap with adjacent areas. It only takes a small drop/ small brush full mixed in with what you're using to do the job. I tend to take what I think I'll need from the bottle, either by dropper or brush fulls & then doctor it, rather than doctoring the bottle & maybe having it all go off over time. Steve. 1 Link to comment Share on other sites More sharing options...
Greenshirt Posted December 8, 2015 Share Posted December 8, 2015 Cheers for the quote, can get tamiya paints fairly easily, I think my local actually stocks them in small numbers, but I've heard there unbrushable, only suited for airbrushing Tamiya paint does airbrush easily and that's my preferred application means, but it can be used with a hairy stick. I've tried the others, which can work, but Tamiya's own retarder works best: http://www.tamiya.com/english/products/87114paint_retarder/index.htm. I put a few drops of paint into a milk lid, add a drop of retarder, which also thins the paint, and away I go. Very little retarder is needed, and it takes a bit of practice to get it consistent. And just like other paints when hairy stick brushing, let it fully cure/dry, I wait at least 48 hours. 2-3 thin coats works best. Tim Link to comment Share on other sites More sharing options...
