raif Posted November 29, 2015 Share Posted November 29, 2015 I have used Humbrol varnish several times over Humbrol silver paint but they don't appear to get on very well, resulting in the silver paint lifting on some occasions and going all blotchy, what would be the best gloss varnish for brushing on top of Humbrol silver paint? Link to comment Share on other sites More sharing options...
Housesparrow Posted November 29, 2015 Share Posted November 29, 2015 Are you using enamel or water based products? I've been hearing that you can well mix enamel and acrylic, so how about using Humbrol Clear if you have been using Humbrol silver enamel paint? Link to comment Share on other sites More sharing options...
Mike Posted November 29, 2015 Share Posted November 29, 2015 Best way is to do a test swatch of your silver, and try acrylic gloss if it's enamel silver. They should coexist ok, but spraying will give a better result in my experience, as there's no pressure being applied to lift the existing paint. Link to comment Share on other sites More sharing options...
raif Posted November 29, 2015 Author Share Posted November 29, 2015 (edited) Yes I use Humbrol enamel varnish over Humbrol enamel silver, they hate each other! how about if I try acrylic varnish over enamel silver? what sort of finish does Humbrol clear give? is that an enamel gloss finish? Edited November 29, 2015 by raif Link to comment Share on other sites More sharing options...
Housesparrow Posted November 29, 2015 Share Posted November 29, 2015 Humbrol Clear is not enamel, but acrylic based. It gives a high gloss finish. Link to comment Share on other sites More sharing options...
raif Posted November 29, 2015 Author Share Posted November 29, 2015 OK thanks, will experiment before my next silver painted project! Link to comment Share on other sites More sharing options...
azureglo Posted November 30, 2015 Share Posted November 30, 2015 Here's a review of Alclad Gloss from some geezer called Mike on an obscure modelling forum. He talks about its effects on both shine reduction and spraying over enamels , seems to know a lot more than the "Mike" who posted here Seriously though, this stuff is pretty reliable and works over virtually everything, enamels, acrylics and lacquers so worth a punt at six pounds odd a bottle and you can dip canopies in it as well. Anil 1 Link to comment Share on other sites More sharing options...
colin Posted November 30, 2015 Share Posted November 30, 2015 Lakeland quickshine works very much the same as Alclad, similar price but 800ml as opposed to 120ml Not knocking Alclad as I have used it and is very good. Link to comment Share on other sites More sharing options...
