Shar2 Posted November 27, 2015 Share Posted November 27, 2015 Vought OS2-U KingfisherKittyHawk 1:32 The Vought OS2-U Kingfisher was an American catapult-launched observation floatplane. It was a compact mid-wing monoplane, with a large central float and small stabilizing floats. Performance was modest, because of its light engine. The OS2U could also operate on fixed, wheeled, tail dragger landing gear. The OS2U was the main shipboard observation aircraft used by the United States Navy during World War II, and 1,519 of the aircraft were built. It served on battleships and cruisers of the US Navy, with the United States Marine Corps in Marine Scouting Squadron Three (VMS-3), with the United States Coast Guard at coastal air stations, at sea with the Fleet Air Arm of the Royal Navy, and with the Soviet Navy. The Royal Australian Air Force also operated a few Kingfishers from shore bases. The Naval Aircraft Factory OS2N was the designation of the OS2U-3 aircraft built by the Naval Aircraft Factory in Philadelphia, Pennsylvania. The OS2U first flew on 1 March 1938.In the late 1930s, Vought engineer Rex B. Beisel was tasked with designing an observation monoplane aircraft for the U.S. Navy suitable for a multitude of tasks including directing battleship fire. In replacing the standard biplane observation aircraft with a more modern monoplane design, Beisel incorporated innovations becoming the first production type to be assembled with spot welding, a process Vought and the Naval Aircraft Factory jointly developed to create a smooth fuselage that resisted buckling and generated less drag. Beisel also introduced high-lift devices, spoilers and in a unique arrangement, deflector plate flaps and drooping ailerons located on the trailing edge of the wing were deployed to increase the camber of the wing and thus create additional lift. One of the more famous pilots flying the Kingfisher was one Douglas Fairbanks Jnr, when he was posted to the USS Washington.For combat missions, the pilot had a .30-caliber machine gun while the radio operator/gunner manned another .30-caliber machine gun (or a pair) on a flexible ring mount. The aircraft could also carry two 100 lb bombs or two 325 lb depth charges. Additionally, the "Kingfisher", as it was designated, served as a trainer in both its seaplane and landplane configurations. Beisel’s first prototype flew in 1938, powered by an air-cooled 450 hp Pratt & Whitney R-985-4 Wasp Junior radial engine.The ModelIt was with great joy hearing that Kittyhawk were going to release a big Kingfisher. Whilst not the most glamorous of aircraft, it did carry out an important job throughout WWII and was certainly one of the better looking floatplanes in the Allies arsenal. The kit comes in a colourful top opening box, with an artists impression of the aircraft sitting on its cradle atop a battleships catapult. Unfortunately the backdrop seems to show the aircraft at the time of the attack on Pearl Harbor. On opening, the modellers eye is drawn to a small brown box, which contains the clear parts. There are also five large sprues of light grey styrene two decal sheets, one very large and one small, and a small sheet of etched brass. All the parts are very well moulded, with few signs of imperfections other than some flow marks on the fuselage and on the wings. There is a small amount of flash and quite a few moulding pips throughout the sprues. Whilst the clear parts are very clear, there is a very slight distortion on the curved top panels of the canopies. Whilst there is quite a lot of detail, it doesn’t look to be overly complicated, which for this reviewer a good thing, particularly if you are trying to break out of a period of modellers block. Construction begins with the engine and the assembly of the rear mounted ancillary drive casing, which comes in three parts, and to which the alternators and air intake pipes are fitted. The two pieces of the cylinder block are glued together and fitted with the push rod ring, panel mounting ring, rear drive assembly and the exhaust manifolds. The nose section of the cowling is then attached, along with what looks like a magneto coil. The three piece engine bearer is then attached. The fire wall also comes in two parts, which once joined together are fitted out with the with the forward firing 30 cal machine gun, its support and ammunitions tank on the rear side, whilst on the front, the oil tanks and what I presume is a fuel tank, and the machine gun barrel extension tube. On top of the firewall the instrument panel and coaming are fitted, with the IP having had several levers attached. The engine assembly can then be attached to the firewall assembly and put aside to set properly. Each of the two pilots lap straps are made entirely of etched brass and consist of the main straps, slipped through the clasps and attachment ring, before the main seat fittings are glued on top and the loose strap section glued to the upper section. The seat is then fitted with its support frame, the two straps and the seats front edging strip before being fitted to the seat bulkhead. The assembly of the rear cockpit begins with the construction of the rear mounted 30cal machine gun, which, if you include the mount consists of twelve parts. The gunners seat is attached to the seat frame, which includes the backrest and two more lap straps made up in the same way as the pilots straps. The gun mount track is made up of five parts and once assembled glued to the seat frame, followed by the fitting of the gun assembly. The shoulder level cockpit frame is fitted out with a radio set, a DF loop, electrical box, spare ammunition canisters and shelf, spent ammunition tubes and multipart end framework. A separate shelf is fitted with more radio boxes and selector box before begin glued to the underside of the cockpit frame. The gunner’s seat assembly is then fitted along with the rear bulkhead. Before going any further the modeller needs to decide which version they are going to build, the floatplane, or land plane. Depending on version, the respective holes need to be opened up in the fuselage and underside of the wings. Each of the two fuselage halves can then be fitted with the various ribs, footboards, oxygen bottles, electrical boxes and the pilots side consoles, side mounted controls, rudder pedals and joystick. The engine and cockpit assemblies are then fitted to one halve of the fuselage, after which the fuselage can be closed up. If making the landplane version, don’t forget to fit the two piece tailwheel. The canopy sections and windscreen are then attached, along with the tubular telescopic gunsight and engine cooling gills. The access steps are then fitted, along with the upper and lower cowlings, side cowlings, venturi tube, seven piece propeller, aerial mast and small side mounted aerial beneath the rear cockpit. The wings each come in upper and lower halves, with the fixing tang separate. The tang block needs to be glued to the lower wing before the unpper wing section can be attached. Each of the ailerons and flaps are separate and each made from two halves. On both upper and lower surfaces of the wings, several identification lights are fitted, as are the tip mounted navigation lights and the pitot probe, fitted to the port wing. The horizontal tailplanes, elevators and rudder are again assembled from two halves before being fitted to their respective positions. The kit is supplied with two 100lb bombs, which are assembled from two halves and fitted with the bomb crutches and a mounting beam. If the landplane version is beign built then the main wheel assemblies are built up from the main oleo, two support struts, separate scissor link, tie down ring and the two piece wheels. The undercarriage assemblies are then fitted to the fuselage, with the rear struts glued to a separate two piece bullet fairing that is fitted to the centreline of the fuselage. The two bomb assemblies are then glued into place. If building the floatplane version then the wingtip floats are built up, with each float provided as two halves, to which the N shaped strut is attached and the floats glued into position and supported by two separate inboard struts. The main float is also in two halves and the mouldings include the main struts and even the central cross bracing. The other bracing wires need to be provided by the modeller, but the kit does provide the attachment points for them, as well as the separate rudder and its control wire fixings. To allow the floatplane version to stand upright the kit supplies to dollies, with two piece wheels, one for each side of the main float, and a tailwheel mounted on the left hand at the end of the float. The completed float is then attached to the fuselage. The build is completed with the fitting of a crew access ladder.DecalsThere are two decal sheet included in the kit, one large and one small. The larger of the two contains all the national insignias for the six colour schemes included on the paint charts, along with the id markings for each option and the stencils for one aircraft. They are beautifully printed, they are really vivid, opaque and in register. The smaller decal sheet contains the instrument panel and side console decals, plus the Donald Duck logo for one of the options. The options provided are:- OS2U-3 Kingfisher, Naval Air Station Corpus Christi, Texas, 1942 in Light Blue over Gloss White, with Yellow upper wings. OS2U Kingfisher of VO-1 aboard USS Arizona 1941 in overall silver with yellow upper wings, red tail and red stripes on the nose and amidships OS2U-3 Kingfisher serving in the Soviet Union, based on the ex-Italian light cruiser Milwaukee, 1944 in grey over gloss white. OS2U Kingfisher, FN768 No 765 Squadron, Fleet Air Arm, based at Sandbanks, Dorset 1943 in dark green and medium sea grey topsides with sky undersides, (although the instructions call it hemp?). OS2U-3 Kingfisher US Navy 1941 in dark blue over white and with the Donald Duck emblem on the tail fin. ConclusionFor some strange reason I’ve always liked the old Kingfisher, although not so much as a landplane, as it just looks wrong, so it was with quite a bit of excitement that I heard Kittyhawk were going to release one in 1:32. As I said above, it is a very nice, well detailed kit, one that can easily be built straight from the box, and yet has the potential, particularly when the aftermarket guys get into gear, to be built into a super detailed masterpiece. Very highly recommended. Review sample courtesy of and available soon from major hobby shops 2 Link to comment Share on other sites More sharing options...
Beard Posted November 27, 2015 Share Posted November 27, 2015 (edited) I think there's an error in bit about the decals... wasn't the Milwaukee an ex-US ship, re-named 'Murmansk' when in Soviet service? Edited to correct mistakes caused by fat fingers and predictive text. Edited November 27, 2015 by Beard Link to comment Share on other sites More sharing options...
Antoine Posted November 27, 2015 Share Posted November 27, 2015 Thanks Dave, Nice little floatplane. Link to comment Share on other sites More sharing options...
Shar2 Posted November 27, 2015 Author Share Posted November 27, 2015 You could be right Beard. 1 Link to comment Share on other sites More sharing options...
Antoine Posted November 27, 2015 Share Posted November 27, 2015 (edited) ..... Edited November 29, 2015 by Antoine Link to comment Share on other sites More sharing options...
GMK Posted November 29, 2015 Share Posted November 29, 2015 Should the wings & fuselage be riveted like that? You mentioned that aircraft was spot-welded. Link to comment Share on other sites More sharing options...
Julien Posted November 29, 2015 Share Posted November 29, 2015 Spot welding will produce indentations in the surface the same diameter as the tool used. Whether or not you would see them or not in scale is another thing. Like a lot of models surface detail is subjective as to whether it would be seen in real life or not. Julien 1 Link to comment Share on other sites More sharing options...
Shar2 Posted November 29, 2015 Author Share Posted November 29, 2015 In addition to Juliens answer, the skins do appear riveted on the leading edge areas as per the kit parts. The float skins are also heavily riveted. You wouldn't see much after a couple coats of paint. 2 Link to comment Share on other sites More sharing options...
GMK Posted November 30, 2015 Share Posted November 30, 2015 Thanks guys. Link to comment Share on other sites More sharing options...
thepureness Posted December 12, 2015 Share Posted December 12, 2015 I think there's an error in bit about the decals... wasn't the Milwaukee an ex-US ship, re-named 'Murmansk' when in Soviet service? Edited to correct mistakes caused by fat fingers and predictive text. this is correct 1 Link to comment Share on other sites More sharing options...
ancient mariner Posted January 24, 2016 Share Posted January 24, 2016 This is my new project so I hope I can share my few opinions on the build. As much as I like this kit.it does seem to have a few pit falls for the unwary. Many of the locating pins dont line up and have to be removed(.The ones that do line up are really positive) The connections to the gates are robust(despite the plastic being softer than usual) to say the least and have to be carefully removed on most mating surfaces. Its all too easy to cut /scrape /sand too deeply. The instructions can be a bit vague in some areas and dont live up to the promise of the what at first look is a nicely produced booklet. The colour profiles seem a little garish but Im thinking that this kit is aimed at the modeller that will rely on the FS numbers. The photo below shows the float bracing attachment that I dont hold out much hope for,I think it will have to be replaced with wire. Link to comment Share on other sites More sharing options...
