RFindley Posted November 22, 2015 Share Posted November 22, 2015 Inspired by the Merit X-Craft in-progress chat here, I had to get one for myself. So far it has been a fun build and I want to finish it in the early submarine scheme of black decks/upper surfaces and grey vertical surfaces. Can any one provide a suggestion for the grey? Thanks Rick in Virginia Link to comment Share on other sites More sharing options...
whitestar12chris Posted November 23, 2015 Share Posted November 23, 2015 From my research i would suggest admiralty dark grey, lifecolor do a nice royal navy set.. regards Chris Link to comment Share on other sites More sharing options...
Jamie @ Sovereign Hobbies Posted November 24, 2015 Share Posted November 24, 2015 Would that be AP 507A Chris? Link to comment Share on other sites More sharing options...
whitestar12chris Posted November 24, 2015 Share Posted November 24, 2015 Yes that's the one 507A, from Paul Kemp's book Underwater warriors, the colour schemes where a trial with Mountbatten pink, then the standard submarine scheme of black upper surfaces and grey sides was adopted, The XE class was painted black all over, but its worth noting that the XE was nearly 2 foot longer than the other models of x-craft. the only exception to this scheme was the two x-craft involved in operation overlord (d-day landings), there were painted yellow ochre, stone and hookers green camouflage scheme. There is a photo of one of the early x-craft out of the water for maintenance in this book, photo next to page 65. it clearly shows the line between the two colours, not seen this photo anywhere else yet. The line runs just over half way down the hull, starting at the junction of the forward taper and the bow, its worth noting the saddle tank is all over black in this photo. Hope this helps Chris 1 Link to comment Share on other sites More sharing options...
RFindley Posted November 24, 2015 Author Share Posted November 24, 2015 Chris How does this compare with the photo? Is it the red or yellow line? Also, Black over Admiralty Dark Grey is quite dark.....do you think it could be Admiralty Dark Grey uppers over Admiralty Medium Grey? Having a lot of fun with the Merit kit....but making a few changes. Rick in Virginia Link to comment Share on other sites More sharing options...
whitestar12chris Posted November 24, 2015 Share Posted November 24, 2015 Rick your close, its below the yellow line in line with the rear dive planes, so grey underside black upper. The colours are correct, can be seen in some photos, generally very dark, hence some confusion as to being one colour but they are not. Paul Kemp is pretty good on his details re submarines etc so id take it as accurate. The only other area you will need to modify on the merit kit is the inaccurate prop, see photo. All the best Chris Link to comment Share on other sites More sharing options...
RFindley Posted November 24, 2015 Author Share Posted November 24, 2015 Please bear with me Chris Is this more in line with what you see? Dark Grey vertical surfaces and lower half with black horizontal surfaces? Link to comment Share on other sites More sharing options...
whitestar12chris Posted November 24, 2015 Share Posted November 24, 2015 Almost there Rick, the upper vertical surfaces were black as well, as these craft were mainly on the surface at night. Chris Link to comment Share on other sites More sharing options...
