Converting the Airfix 1/32 E Type - Lightweight - How to do it
The Airfix 1/32 E Type Jaguar is undoubtedly an old, much in need of replacement, kit.
It is also without doubt one of the most accurate representations in terms of shape, of the actual car.
There is tons of scope for modifying this little kit and here I'm going to describe how to turn the little beastie into a nice representation of an aluminium bodied lightweight car.
There are a few things you will need:
1/32 Airfix E Type kit. (Difficult without this bit...)
Some 20-30 thou plasticard. (If all else fails - a thick butter or marge tub - preferably empty!)
A piece of 8mm dia plastic tube - a short bit of round Biro tube will suffice.
A Dremel or other power tool - Sandpaper and files will do, but a bit more time consuming.
Paints.
A printer - not obligatory, but if you want to print the (later) provided correct dashboard etc, it would help.
White Decal Paper - as above, if you want to print the (later) provided decals etc. (Details as to how to do it will be given)
A dressmaker pin. (You'll find out later...)
An nice bottle of wine - you only really need the foil cap, but the wine will be usefull too...
Some modelling filler/putty - not obligatory, but will help in some areas.
Some chrome sticky tape, or ally foil tape from a pound shop - you need all of 1"... (You could cope without it)
A sheet of chrome Bare Metal Foil - if you want a REAL metal finish...
A can of chrome spray paint if you don't want to try the above BMF (Which is actually really simple, looks better and costs about the same...)
Glue
Assorted paints.
4 x M5 washers. (If you REALLY get stuck, PM me. I'll send you them FOC.)
A black Sharpie pen. (Yes, really.)
You don't need all of the above right away, but the E Type kit would help at the start...
Most of the above - AND much of what follows also applies if you fancy jumping in with the Revell 1/8 model kit.
Roy.
Edited by roymattblack
First off - open your kit box.
If you have a recent re-pop of the kit you will have a little sheet of decals included for licence plates, a tax disc and two gauges.
Older kits won't have them.
No matter as they aren't needed anyway.
Put all the bits in a small box for ease of use.
I use an old Indian takeaway tub - empty and washed...
The body shell is neatly moulded but has some pretty big seam lines that need removing.
These are illustrated in the pictures.
Remove them by dragging a sharp blade backwards over them, and then smooth with fine wet and dry.
DO NOT remove the seam lines along the top edges of the bonnet. They are meant to be there.
Carefully smooth down the exaggerated step that runs across the width of the car just below the boot lid.
It should be a gentler curve, but take care not to eradicade the the line of the lid.
Trim off and smooth the injection peg below the drivers door.
Give the whole body a good check to remove any other flash.
Well, they say a picture says a thousand words...
Cut the tube neatly, and clean up the cut edge.
When the tubes are glued inside the car, get them as 'central' in the opening as you can.
The edges of the tubes may sit a little proud, but they should NOT poke through the light opening in the body.
Filler will be applied later to fill any gaps, and the proud edges of the tubes will be filed and sanded smooth.
Here endeth the second lesson...
Another bit - last for today.
For the wheel arch template below - 'print screen' and paste it into any document or art program.
Crop it down and scale it to the size shown.
Print it out and use it on thin plastic sheet - a butter tub will do.
Roy.
Onwards and upwards.
Please bear in mind that what I'm doing is making a nice, fairly simple model of the lightweight E Type that modellers with even fairly modest skills can make.
There is LOTS of scope for adding further details if you wish that I won't go into here.
Roy.
